Browse Forums Building A New House Re: Who else is building with Eden Brae? 11082Jan 19, 2015 2:15 pm kellyville75 Hi Nik, We finished building our house with EBH, and it was handed over around 3 months back to us. We've got tiling done post handover throughout the house...and bamboo flooring in bedrooms. Worked out heaps cheaper in getting 600x600 tiles externally and getting it laid alongwith screeding. And we dont have splashback in the kitchen...we went with the transparent fixed splashback window behind the cooktop. Would you mind if I ask for a photo of the splash back? Re: Who else is building with Eden Brae? 11083Jan 19, 2015 9:13 pm Hi Nik, I understand what you mean about flying blind! That's been us the whole way through which is why I wanted to create a blog to try and help explain the process and share as many insights and watch points as possible So with the kitchen appointment there is no standard mockup of the kitchen in the HOG or even on display (hahah I wish). They'll probably just point out what you get which is what will be on your plans - so kitchen island, cooktop run, rangehood etc. They'll ask you what you want upgrading I.e. overhead cupboards, pot draws, splashback, bin draw, cutlery trays, soft closing draws etc. They'll quote everything on the spot so you'll get costs back straight away. Then later on, once you confirm what you want from the quote then they'll finish your kitchen drawings off. This took about a week or two after we confirmed what we wanted to go ahead with. I'd recommend just trying to get costs for everything you want and then cut out things later on that you can't afford or will manage post. The sketches on my blog are our dream fitout but with everything quoted it came in at 34k (inc. laundry fitout and stone in the bathrooms as well as shaving cabinets). Obviously very expensive. We only ended up going with half of the quote - which you'll see on the final Kitchen Culture drawings (which is under the 'colour selection appointment day 2' post) We'll manage the splashback post. We're looking at the black mirrored splashback. So it'll just be gyprock when we get our keys. Personally I think tiles throughout would be cold. Wood flooring would be better. We've done combination of tiles and carpet (home theatre + bedrooms). It just comes down to what you want. We did get all flooring done through Di Lornezo and it does add up $$$! Quite a few people organise flooring after, but I'm pretty sure EB make you complete flooring in the wet areas...a point to note! Also, with your paints choices see what the Colour Selection Consultant has to say, but I'd recommend buying some sample Pots after just to make sure your 100% happy. For example friends of ours chose Gemini Silver from the standard range which looks grey and it ended up coming out like a light blue colour vs. grey. They obviously weren't impressed! Anyway, let's us know how you go on Thursday. It can be quite overwhelming. Take your notepad and something to snack on incase you run out of time for lunch. Some people zip through the appointments but we took quite awhile even though we knew what we wanted! Best, Shayne Re: Who else is building with Eden Brae? 11084Jan 20, 2015 6:19 am Shayne-Livingstone23 Hi Nik, I understand what you mean about flying blind! That's been us the whole way through which is why I wanted to create a blog to try and help explain the process and share as many insights and watch points as possible So with the kitchen appointment there is no standard mockup of the kitchen in the HOG or even on display (hahah I wish). They'll probably just point out what you get which is what will be on your plans - so kitchen island, cooktop run, rangehood etc. They'll ask you what you want upgrading I.e. overhead cupboards, pot draws, splashback, bin draw, cutlery trays, soft closing draws etc. They'll quote everything on the spot so you'll get costs back straight away. Then later on, once you confirm what you want from the quote then they'll finish your kitchen drawings off. This took about a week or two after we confirmed what we wanted to go ahead with. I'd recommend just trying to get costs for everything you want and then cut out things later on that you can't afford or will manage post. The sketches on my blog are our dream fitout but with everything quoted it came in at 34k (inc. laundry fitout and stone in the bathrooms as well as shaving cabinets). Obviously very expensive. We only ended up going with half of the quote - which you'll see on the final Kitchen Culture drawings (which is under the 'colour selection appointment day 2' post) We'll manage the splashback post. We're looking at the black mirrored splashback. So it'll just be gyprock when we get our keys. Personally I think tiles throughout would be cold. Wood flooring would be better. We've done combination of tiles and carpet (home theatre + bedrooms). It just comes down to what you want. We did get all flooring done through Di Lornezo and it does add up $$$! Quite a few people organise flooring after, but I'm pretty sure EB make you complete flooring in the wet areas...a point to note! Also, with your paints choices see what the Colour Selection Consultant has to say, but I'd recommend buying some sample Pots after just to make sure your 100% happy. For example friends of ours chose Gemini Silver from the standard range which looks grey and it ended up coming out like a light blue colour vs. grey. They obviously weren't impressed! Anyway, let's us know how you go on Thursday. It can be quite overwhelming. Take your notepad and something to snack on incase you run out of time for lunch. Some people zip through the appointments but we took quite awhile even though we knew what we wanted! Best, Shayne Thankyou for your reply Shayne is it possible to do the splash back after? I'm hoping it's cheaper I just don't like tiles it's hard to clean Re: Who else is building with Eden Brae? 11085Jan 20, 2015 6:41 am Yes, absolutely possible to do splashback post handover. That's what we are doing. Re: Who else is building with Eden Brae? 11086Jan 20, 2015 7:43 am We're doing our splashback after handover too. Thoroughly uninspired by the selection at DiLorenzo and anything else from there cost an arm and a leg. We're tossing up between doing a pressed metal splashback or tiling it with a company close to us that have a much nicer selection. Building the Lawson24 Land Registered-4/2/15 Admin Complete-1/4/15 Slab Down-13/4/15 External Complete-27/5/15 PCI-12/8/15 Handover-18/8/15 Re: Who else is building with Eden Brae? 11087Jan 20, 2015 2:14 pm Correction - I meant under the post 'Colour Selection Appointment 1' in August. Not the day 2 appointment sorry! Re: Who else is building with Eden Brae? 11088Jan 20, 2015 5:46 pm Hey everyone Im building sheffield 25+2 Today I visited my tender signing appointment and paid $2500 deposit and next step is 2 weeks away where we pay 5%, I want to quickly get to selection step but have to wait because our land will registered in July or August so if we select colours and things too early, they might discontinue well thats what tender presenter said. Im wondering if there is anyone else in my position. Building Sheffield 27 North West First deposit - 20/12/14 Tender signed - 20/01 Buil contr sign - 04/02 PGH Appointment- 06/02 Re: Who else is building with Eden Brae? 11089Jan 20, 2015 6:01 pm razbeer Hey everyone Im building sheffield 25+2 Today I visited my tender signing appointment and paid $2500 deposit and next step is 2 weeks away where we pay 5%, I want to quickly get to selection step but have to wait because our land will registered in July or August so if we select colours and things too early, they might discontinue well thats what tender presenter said. Im wondering if there is anyone else in my position. Exciting anf frightening stuff!? I have a question for you, Our land isn't registered until oct/nov and we are waiting on our tender presentation, we haven't payed our $2500 yet until the presentation but we want to know can you then put off paying the 5% which gets the next step going, to give us time to save more money and seeing as we have that time until registration? Did they give you an indication on anything like that with unregistered land? Re: Who else is building with Eden Brae? 11090Jan 20, 2015 7:08 pm bugbos razbeer Hey everyone Im building sheffield 25+2 Today I visited my tender signing appointment and paid $2500 deposit and next step is 2 weeks away where we pay 5%, I want to quickly get to selection step but have to wait because our land will registered in July or August so if we select colours and things too early, they might discontinue well thats what tender presenter said. Im wondering if there is anyone else in my position. Exciting anf frightening stuff!? I have a question for you, Our land isn't registered until oct/nov and we are waiting on our tender presentation, we haven't payed our $2500 yet until the presentation but we want to know can you then put off paying the 5% which gets the next step going, to give us time to save more money and seeing as we have that time until registration? Did they give you an indication on anything like that with unregistered land? Hi Bugbos thats right it is exciting and frightening well according to my information you have to pay 5% deposit on house in couple of weeks after the tender and then another 10% for land in another 14 days, taking into consideration what you have paid to date. Land settlement take place within 14 days of land registration. which area and what house are you planning to build. Building Sheffield 27 North West First deposit - 20/12/14 Tender signed - 20/01 Buil contr sign - 04/02 PGH Appointment- 06/02 Re: Who else is building with Eden Brae? 11091Jan 20, 2015 7:12 pm razbeer Hey everyone Im building sheffield 25+2 Today I visited my tender signing appointment and paid $2500 deposit and next step is 2 weeks away where we pay 5%, I want to quickly get to selection step but have to wait because our land will registered in July or August so if we select colours and things too early, they might discontinue well thats what tender presenter said. Im wondering if there is anyone else in my position. Hi Raz, I have read in earlier posts that some posters have found that while waiting for their build to commence, their selections have been discontinued, resulting in a need to undertake reselections. I would tend to think that this would be due to a relatively early selection process. With my selections, I did my appointments in April last year, then my land registered in June, then build commenced in September. I kept in touch with my builder prior to each stage to ensure all selections I made in April was still current, which has helped Re: Who else is building with Eden Brae? 11092Jan 20, 2015 7:22 pm PixiGT razbeer Hey everyone Im building sheffield 25+2 Today I visited my tender signing appointment and paid $2500 deposit and next step is 2 weeks away where we pay 5%, I want to quickly get to selection step but have to wait because our land will registered in July or August so if we select colours and things too early, they might discontinue well thats what tender presenter said. Im wondering if there is anyone else in my position. Hi Raz, I have read in earlier posts that some posters have found that while waiting for their build to commence, their selections have been discontinued, resulting in a need to undertake reselections. I would tend to think that this would be due to a relatively early selection process. With my selections, I did my appointments in April last year, then my land registered in June, then build commenced in September. I kept in touch with my builder prior to each stage to ensure all selections I made in April was still current, which has helped Hi PixiGT Thanks for the information, im planning to do my selection in May. it should give me enough time to select i guess. Building Sheffield 27 North West First deposit - 20/12/14 Tender signed - 20/01 Buil contr sign - 04/02 PGH Appointment- 06/02 Re: Who else is building with Eden Brae? 11093Jan 20, 2015 7:46 pm razbeer bugbos razbeer Hey everyone Im building sheffield 25+2 Today I visited my tender signing appointment and paid $2500 deposit and next step is 2 weeks away where we pay 5%, I want to quickly get to selection step but have to wait because our land will registered in July or August so if we select colours and things too early, they might discontinue well thats what tender presenter said. Im wondering if there is anyone else in my position. Exciting anf frightening stuff!? I have a question for you, Our land isn't registered until oct/nov and we are waiting on our tender presentation, we haven't payed our $2500 yet until the presentation but we want to know can you then put off paying the 5% which gets the next step going, to give us time to save more money and seeing as we have that time until registration? Did they give you an indication on anything like that with unregistered land? Hi Bugbos thats right it is exciting and frightening well according to my information you have to pay 5% deposit on house in couple of weeks after the tender and then another 10% for land in another 14 days, taking into consideration what you have paid to date. Land settlement take place within 14 days of land registration. which area and what house are you planning to build. We have a holding deposit at Averys Rise at Heddon Greta NSW and are almost due to pay another deposit to hold until registration which will eat up a big chuck of our savings, hence wanting a few more months to save for the 5% to Eden Brae Ps..were you able to negotiate anything at your presentation? Re: Who else is building with Eden Brae? 11094Jan 20, 2015 8:39 pm We have a holding deposit at Averys Rise at Heddon Greta NSW and are almost due to pay another deposit to hold until registration which will eat up a big chuck of our savings, hence wanting a few more months to save for the 5% to Eden Brae Ps..were you able to negotiate anything at your presentation?[/quote] Hi Bugbos i understand how you feel about all this but don't take my word for it just double check or negotiate deposit time with your tender presenter i think they like to keep costomers happy. they will not give any discount as you know and i did ask them to throw things in it but i did a lot changes inside the house and got some extra doors like in ensuit, WIR door, widen my other wardrobes, render the porch pillars all for free. they couldn't do a lot, they said there isn't a lot of room in pachage. By the way im getting home and land package. sorry what house are you building. Building Sheffield 27 North West First deposit - 20/12/14 Tender signed - 20/01 Buil contr sign - 04/02 PGH Appointment- 06/02 Re: Who else is building with Eden Brae? 11095Jan 20, 2015 9:00 pm razbeer We have a holding deposit at Averys Rise at Heddon Greta NSW and are almost due to pay another deposit to hold until registration which will eat up a big chuck of our savings, hence wanting a few more months to save for the 5% to Eden Brae Ps..were you able to negotiate anything at your presentation? Hi Bugbos i understand how you feel about all this but don't take my word for it just double check or negotiate deposit time with your tender presenter i think they like to keep costomers happy. they will not give any discount as you know and i did ask them to throw things in it but i did a lot changes inside the house and got some extra doors like in ensuit, WIR door, widen my other wardrobes, render the porch pillars all for free. they couldn't do a lot, they said there isn't a lot of room in pachage. By the way im getting home and land package. sorry what house are you building.[/quote] Ok thanks, Yep i can only ask when it comes time for the presentation We're getting the Livingstone 20 Re: Who else is building with Eden Brae? 11096Jan 20, 2015 9:17 pm Hi everyone, Adam here - just joined. I'm looking at building a Saville 25 or 27, and I was wondering if someone can tell me whether EB normally charge for changes to a plan? If they allow some changes for free, what's the limit? I'm thinking about possibly shrinking the alfresco to extend the dining and living areas, and shrinking the 'media' room to extend the family room. Thanks, Adam Re: Who else is building with Eden Brae? 11097Jan 21, 2015 7:54 am Adam_C Hi everyone, Adam here - just joined. I'm looking at building a Saville 25 or 27, and I was wondering if someone can tell me whether EB normally charge for changes to a plan? If they allow some changes for free, what's the limit? I'm thinking about possibly shrinking the alfresco to extend the dining and living areas, and shrinking the 'media' room to extend the family room. Thanks, Adam Hi Adam, When I signed up with EBH (Jan 2014), I was able to make as many changes as I wanted, as long as all the structural changes (like the layout changes to the floor plan you have described) were done before the tender was signed, at no cost. Any layout changes after the tender was signed would incur a fee. This fee of course does not apply to your post contract variations (PCV's), where you make your selections for the colours, tiles, etc, as these are done later after both the tender & contract have been signed, but are done closer to your build start date to ensure that the selections hopefully don't become out of stock due to being superseded (in the case that you have a longer lead time until you build, due to waiting for land registration, for eg). I made about 25 changes prior to tender on my floor plan, but I've heard of other ebh customers making more. Hope that helps enjoy your build! Re: Who else is building with Eden Brae? 11098Jan 21, 2015 8:12 am PixiGT Hi Adam, When I signed up with EBH (Jan 2014), I was able to make as many changes as I wanted, as long as all the structural changes (like the layout changes to the floor plan you have described) were done before the tender was signed, at no cost. Any layout changes after the tender was signed would incur a fee. This fee of course does not apply to your post contract variations (PCV's), where you make your selections for the colours, tiles, etc, as these are done later after both the tender & contract have been signed, but are done closer to your build start date to ensure that the selections hopefully don't become out of stock due to being superseded (in the case that you have a longer lead time until you build, due to waiting for land registration, for eg). I made about 25 changes prior to tender on my floor plan, but I've heard of other ebh customers making more. Hope that helps enjoy your build! It does, thanks! Re: Who else is building with Eden Brae? 11100Jan 21, 2015 11:30 am PixiGT Adam_C Hi everyone, Adam here - just joined. I'm looking at building a Saville 25 or 27, and I was wondering if someone can tell me whether EB normally charge for changes to a plan? If they allow some changes for free, what's the limit? I'm thinking about possibly shrinking the alfresco to extend the dining and living areas, and shrinking the 'media' room to extend the family room. Thanks, Adam Hi Adam, When I signed up with EBH (Jan 2014), I was able to make as many changes as I wanted, as long as all the structural changes (like the layout changes to the floor plan you have described) were done before the tender was signed, at no cost. Any layout changes after the tender was signed would incur a fee. This fee of course does not apply to your post contract variations (PCV's), where you make your selections for the colours, tiles, etc, as these are done later after both the tender & contract have been signed, but are done closer to your build start date to ensure that the selections hopefully don't become out of stock due to being superseded (in the case that you have a longer lead time until you build, due to waiting for land registration, for eg). I made about 25 changes prior to tender on my floor plan, but I've heard of other ebh customers making more. Hope that helps enjoy your build! Hi, When we done our tender we changed and moved the walls and windows to suit our needs at no extra charge on the plans. We are also first time builders and thought we would be charged for it but shockingly we didn't pay anything happy days our tender presenter said we could change anything on the plans as long as we weren't adding things in like extra windows not sure about walls so as long as you stick to moving walls and windows you will be right. In our promo deal we are getting an extra 2 squares and can put in anywhere in our home but they stung us with paying an extra $500 for floor coverings to cover the extra 2 squares which i found rude as it was meant to be 2 squares for free in the promo so technically they should cover that cost anyway can't do anything about it now already signed the tender. With what your saying they might charge you a fee as they will have to draw new plans with ours it was only slight/minor wall and window movement you will need to find out before you sign off on your tender, make sure you get a copy of everything for backup aswell. Good Luck Our neighbor built the Saville 25 sq aswell looks nice from the front very similar to what our Sheffield will look like. Cheers Building the Sheffield 25 + 2 sq I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 23453 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223639 |
