Browse Forums Building A New House Re: Who else is building with Eden Brae? 13808Sep 10, 2016 9:29 pm Just a reminder in the build stage for anyone that asks for extra noggins for the wall mount TV . If possible, you should check your site when they do framing because I paid to get the extra noggins which I found nothing have been added to my Master bed and Home Theatre. Perhaps I should check for whatever I have added to the variations because our SS can't always remember what's in it due to high volume of jobs they have to deal with. Re: Who else is building with Eden Brae? 13810Sep 11, 2016 9:35 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I came pass yesterday afternoon and seen this, the fence was open at the time but nobody was working I guess. In this photos, there should be a few more extra timber in the middle where next to the entry door which I found nothing at all. This is where I will have mount TV install. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ this one too, should of had some extra timber in the middle but found nothing. This is just what we can see if we were able to get inside , what If we can't find out ? Noone would know what EBH has done if we were not able to check. We are paying for the service but we are not getting that service. EBH not allow us to come onsite while they build, but we don't know if they are doing exactly what is in the contract if we can't come visit it. Lucky, I didn't ask for more noggins in games and living otherwise I wasted my $$$ I think, its the best for someone that can get a site inspector for every stages, it's sure costing you $$ but you'll get a house that you want. Re: Who else is building with Eden Brae? 13811Sep 11, 2016 9:59 am Steven, If you needed to do a wall mount for the TV did you actually bring it up at your first appointment? It was brought to our attention at that stage recently as we are building the Waldorf 50. We've spent an extensive amount of time deciding on the placement of TV, powerpoints, two way switches and light points at the Home Display in Kellyville. It's something I can recommend to all people before they go to their first appointment. Kind Regards, Bruce Re: Who else is building with Eden Brae? 13812Sep 11, 2016 10:14 am @ Wrongbruce I did it with Clipsal in the 2nd appointment I think. However, I changed the electrical plan a few times during the time waiting for land registered. Clipsal people were alright . So if you haven't got an idea where to put it , you can ask for advice from them. You'll have plenty of time to change the plan. Cheers Steven Re: Who else is building with Eden Brae? 13813Sep 11, 2016 11:00 am Steven_La @ Wrongbruce I did it with Clipsal in the 2nd appointment I think. However, I changed the electrical plan a few times during the time waiting for land registered. Clipsal people were alright . So if you haven't got an idea where to put it , you can ask for advice from them. You'll have plenty of time to change the plan. Cheers Steven Hi Steven, any idea how the extra noggins looks like. I also have wall mount TV in living and home theatre for my Livingstone single storey. I asked this to my SS during framing and he said noggins will be done during electrical. Here is my living Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here is my Home Theatre Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Livingstone23 with Eden Brae Homes Re: Who else is building with Eden Brae? 13815Sep 11, 2016 1:05 pm Steven_La You'll have to get a stud finder which should allow you to find studs (and noggins) after lining... Who else is building with Eden Brae? 13816Sep 11, 2016 1:11 pm cheeku Hi was wondering i EDH does any negotiations at all? I want to upgrade from range A to range H bricks and they have given me 8K quote. Bigger door cost qouted by them is $1200-can I get the door from somewhere else instead? Also they have advised that I get H class slab which is another $3600 cost-do I need this or is M class ok? saline soils requirement $3400 water service check $1300 facade treatment (bag and paint) $2500 NBN connection $1300 these are big costs and was wondering is there anyway to get around these? Thanks for your help in advance Hi If you have not signed the contract, would recommend try getting tender from other builders with similar requirements. And you will be surprise how EB charge you high. Good luck. Re: Who else is building with Eden Brae? 13817Sep 11, 2016 1:31 pm sudu Yes that is true to an extent. But make sure you compare apples with apples. Quality of finish is also important. I've built several houses in my lifetime and I can tell you that each builders finishing is different. Bruce "Building the Eden Brae Waldorf 50 in North Kellyville" Re: Who else is building with Eden Brae? 13818Sep 12, 2016 4:25 pm Steven_La Steven_la My electrical rough-in will start shortly at my build, I included provision for wall mount TV with HSI who are charging me $165 for it. I am waiting for an answer from them to my question that $165 provision includes wiring as well as making sure when I install TV I will get right studs at the centre of wall. If HSI says NO to the studs then I will get my SS to do it for me.Studs are usually spaced 600mm apart and I need 2 more at 300mm on either side from the middle stud vertically oriented. ----------------- Eden Brae Cremorne Blog : http://newhouse.gores.com.au Re: Who else is building with Eden Brae? 13819Sep 12, 2016 4:41 pm Steven_La mikegrg1 Steven_La Has anyone got the Buildwatch ? I have been asking my Admin and SS but they are trying to ignore the question . Is this standard feature with every build or something you have to pay for or apply for? I think this will be available from lifestyle series and up only. Accordingly my SS, currently it is kind of lucky dip due to limited number of Buildwatch cams available. They give priority usually to install it at the sites where they think there is high risk of thefts. ----------------- Eden Brae Cremorne Blog : http://newhouse.gores.com.au Re: Who else is building with Eden Brae? 13820Sep 12, 2016 9:11 pm Ausman Steven_La Steven_la My electrical rough-in will start shortly at my build, I included provision for wall mount TV with HSI who are charging me $165 for it. I am waiting for an answer from them to my question that $165 provision includes wiring as well as making sure when I install TV I will get right studs at the centre of wall. If HSI says NO to the studs then I will get my SS to do it for me.Studs are usually spaced 600mm apart and I need 2 more at 300mm on either side from the middle stud vertically oriented. I am on the same boat , plz let me know how you go Ausman . Cheers I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 23277 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223610 |
