I'm building at Willowdale and our house has just been painted and we have all tiling except the main floor finished. As well as the kitchen and bathroom vanities installed.
Does anyone know what the next stage is?
Hi Nimsy,
We are at the same stage as you..
Did you find your bathroom tiling is sub par.. We found the tiler only applied glue blobs on the back of the tiles instead of applying it to the whole wall.. This leaves weak points in the times and looks horrible from the side..
We are very disappointed at the quality...
Nimsy what is the current practice I thought was standard to apply to wall not in blobs as you mentioned. How do you know that's what they did ?
I know this is a problem on floor as leaves hollow spots if stepped on over time cracks tiles.
Hi Swiftsport..
Last night we went and our bathroom has just been tiled..
When you look at the side of the tile it is hollow til the glue starts.. I could fit a paddle pop stick down there quite far til the glue started.. We have 20mmx600mm wall tiles in the bathroom so its easy to see...
When you tap the tile you can hear where the glue is and isn't as it sounds different..
Very disappointing...
We are also arguing with them over our laundry floor waste.. they positioned the floor waste 40 cms from the internal laundry door and not in the centre of the room.. Our laundy is 1.8m x 4.0m.. They said they will not fix it so we are going to fair trading..
