Browse Forums Building A New House Re: Who else is building with Eden Brae? 10309Apr 08, 2014 9:44 am Slab – 31 Oct 2012 Frame - 15 Nov 2012 Bricks – 26 Nov 2012 Roof - 14 Jan 2013 Lock Up- 11 Feb 2013 PCI- 23rd May 2013 Settlement - 7th June 2013 Re: Who else is building with Eden Brae? 10310Apr 09, 2014 8:02 am thought DL gave us wrong carpet. went to DL yesterday and found that it was correct one but showroom one finishing more nicer and smooth. even sunlight can make confuse with the colour. can anybody tell me the final inspection Tyrells does, and after they issue certificate on settlement day, does that means all issues has been resolved. can i rely on that certificate before settlement ? Building Manchester 22 with EBH contract signed 17/05/13 land settled 08/07/13 cut & fill 12/11/13 slab 19/11/13 Frame 29/11/13 Brick 11/12/13 Roof 20/12/13 lockup 20/01/14 Re: Who else is building with Eden Brae? 10312Apr 09, 2014 9:08 am Oronno, I think Tyrells does one more inspection at presettlement to make sure that anything that they list on their PCI sheet has been done/rectified (maybe check with your SS about this??). You should also be going in for a presettlement inspection just before you go into the office to get your keys. You have to sign off on the PCI sheet to make sure that everything that has been listed has been done. If things are not done to your liking or fixed properly then you can delay settlement if you are not in a massive hurry to move. Slab – 31 Oct 2012 Frame - 15 Nov 2012 Bricks – 26 Nov 2012 Roof - 14 Jan 2013 Lock Up- 11 Feb 2013 PCI- 23rd May 2013 Settlement - 7th June 2013 Re: Who else is building with Eden Brae? 10313Apr 09, 2014 10:37 am BH thanks for getting back to me... well i looked at tyrells final inspection report...most of them marked as "Need attention" ...i spoke to my SS and he said he has fixed most of the problem and tyrells will do final check before provide certificate. we couldn't find anything major in our PCI apart from paint and gyprock issues. im guessing tyrells won't provide certificate unless the issues has been rectified otherwise they will be responsible later on. still i will give an inspection before pickup the key. Building Manchester 22 with EBH contract signed 17/05/13 land settled 08/07/13 cut & fill 12/11/13 slab 19/11/13 Frame 29/11/13 Brick 11/12/13 Roof 20/12/13 lockup 20/01/14 Re: Who else is building with Eden Brae? 10315Apr 09, 2014 9:32 pm Need2know Does anyone knows a good landscaper around Hills area or the ponds? Do it yourself and save lots of money.. check out our blog.. If I can help I will, just PM me.. Regards Phil The Reedman Home Building a custom design home with Modernview Homes. Architect: Brendan Duffy. BJD Design Pty Ltd At Waterfall 9: The Ponds The Blog http://thereedmanhome.blogspot.com/ Re: Who else is building with Eden Brae? 10316Apr 10, 2014 8:58 am Hi all, Council has come back with the DA for me approved, however I've noticed they applied a BAL 29 for my home. Has anyone experienced what EB does once they recieved the approval? Do they advise you of the requirements for your home? Do they give you options etc. Thanks. M Re: Who else is building with Eden Brae? 10317Apr 10, 2014 9:05 am I think they will look up what the requirements for bal 29 is and add the items into your tender / raise a variation for the additional cost. Re: Who else is building with Eden Brae? 10319Apr 10, 2014 9:20 am Not for bal 29, ours was bal 12.5, added 6-8k to the tender.... Re: Who else is building with Eden Brae? 10320Apr 10, 2014 2:14 pm mystro Do you have an indication in regards to costings? I would say aprox. 10K Regards, Building a custom Drysdale 27 at The New Rouse Hill Land Reg - Feb 15 2013 Tender Accepted – May 16, 2013 Contract Signed – June 13, 2013 Allocated Construction start date – October, 2013 I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 23374 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223632 |
