Browse Forums Building A New House 1 Feb 11, 2012 6:58 am Hi guys, I am very new to house construction. I bought a residential lot. It is 3 feet high than the road level. Two houses on both sides are built on the high level without lowering the lot level. So if I level it to road level or atleast removing 1 or 11/2 feet top soil, will that affect my foundation or their foundation? I don't want the drive way steep. thank you! Re: Leveling the lot to road level 2Feb 11, 2012 7:20 am brenda Hi guys, I am very new to house construction. I bought a residential lot. It is 3 feet high than the road level. Two houses on both sides are built on the high level without lowering the lot level. So if I level it to road level or atleast removing 1 or 11/2 feet top soil, will that affect my foundation or their foundation? I don't want the drive way steep. thank you! You are looking at a massively expensive operation there - the cut itself and the haulage of spoil will cost enough to begin with, but then you will also be up for the cost of structural (engineered) retaining walls all the way around your block. Then you can throw in some hefty drainage costs as well because water on all three sides is going to naturally flow down into the hole that would be your block. Given that the existing houses are built up at the natural ground level I'm not even sure if the council will give you approval for such a deep cut that is out of character with the surrounding blocks. Your desire to have a driveway with a shallower grade is going to cost you a bomb (if you can get it done at all), so think it over carefully. Some people apparently have nothing better to do than comment on other people's sigs. I brought terry road box hill in June 2022 House was meant to be completed Nov 2023 That did not happen I had to chase them so much to the land Registration and… 0 2503 Would anyone on this forum know of a builder/company in Brisbane with house designs for a shallow block. I have a block 20 x 20 so with front and rear set backs I need a… 0 4743 You must be new to the internet. You're also the only person anyone here has ever heard of washing their garage wall. I hate to break it to you, there are insects and… 6 4844 |
