Browse Forums Building A New House 1 Feb 09, 2012 9:37 pm Thought Id start another thread for Masterton Homes as the other one was loaded with info (120+ pages) and 2.5 yrs old. I propose that the next thread after this one (2.1) be started in say 1 years time to try and keep it all up to date with the Masterton pricing structure and styles etc... Link to the old thread (Started by 'Beebob') - http://forum.homeone.com.au/viewtopic.php?f=31&t=22483&p=828931#p828931 Link to the older thread (Started by 'buildingadreamhome') - http://forum.homeone.com.au/viewtopic.php?f=31&t=10232&start=580 I will do my best to keep up with this thread and post up prices and links to products etc in the 2nd post. I will dedicate the 3rd post to links to other peoples Blogs and build threads. If you want a link to your blog/build thread posted, please PM me with the following info: - House type with facade and main features/key-points - single or double or split level - Location (State/Suburb or Town) - Link to thread/Blog Would be good to get this info more unified and I look forward to conversing with you all and good luck to everyone with your projects!! Masterton Sirocco 7 2012-13 30.01-SITE CHECK 29.05-CONTRACTED 28.06-APPROVED 21.08-SCRAPED 13.09-SLABBED 02.10-FRAMED 24.10-BRICKED 28.11-PLASTERED 03.12-LOCK-UP 05.02-PAINTED 21.02-PCI 25.02-KEYS Blog-Thread Re: Masterton Homes - The new thread 2.0 2Feb 09, 2012 9:37 pm Pricing from 01.06.11 onwards (as quoted from other H1 users - guide only): Firstly, whatever base price Masterton give you add on approximately $100,000 on top of that. That will get you a completed house. Each variation after signing first tender - $1,000 Extra internal gas point - $232 each (12.07.11) External gas point - $284 each (12.07.11) TV antenna - $396 (12.07.11) Extra Air con zones about - $315 - $450 each (10.08.11 & 03.08.11 respectively) Extra Air con vents about $300 (03.08.11) Extra data points - $110-$125 each (08.08.11) A/C- $1940 to upgrade to 20 kilowatt (from 13.5 kilowatt) and $220 per zone (10.08.11) Flat terracotta tiles about $9,400 (15.08.11) Sarking - $2,500. (15.08.11) 40mm stone upgrade to Kitchen bench - around $1600 - $3000 (28.09.11 & 26.09.11 respectively) Stone to each bathroom - around $600 (26.09.11) 900mm: range-hood upgrade - $450 + ext ducting $600 (24.10.11) 900mm cook-top - $238 (24.10.11) 900mm oven - $780 (24.10.11) Under-mount sink - $770 (24.10.11) Overhead cupboards -$500 (24.10.11) Pot drawers - $450 - $550 (24.10.11 & 15.11.11) Canopy - stainless steel and glass canopy - $585.00 (25.10.11) To vent outside - around $550.00 (25.10.11) Draining board cut into the stone top - over $300 (25.10.11) 20mm Waterfall ends – $1,727.00 (25.10.11) 900 mm built in cook top and oven – over $1,200.00 (25.10.11) Extra TV points - $80 each (09.11.11) Extra Ethernet points - $125 each (10.11.11) Tiles to the ceiling in the both bathrooms - $3300 (14.11.11) External siren to slimline type - $50 (15.11.11) Standard alarm code pad to a voicenav type $50 (15.11.11) Water filter - $404 (17.11.11) Brushed Aluminium Kick-boards - $176 (17.11.11) 2740 ceilings - $7208 (17.11.11) Bulkhead above kitchen cupboards and external ducting to rangehood - $1175 (17.11.11) Insulation above garage - $252 (17.11.11) Set of drawers to bath vanity - $280 (17.11.11) Upgrade range-hood to Baumatic BAH91 - $290 (17.11.11) Mirrored sliding doors to robe (1 set) - $428 (17.11.11) Additional shower head - $357 (17.11.11) Upgrade Laundry tub to Platinum Including Mixer tap - $695 (17.11.11) Soundproof Gyprock to Theater - $240 (17.11.11) Custom Water Tank - $360 (17.11.11) Double sliding cavity door to ensuite - $705 (17.11.11) 22.5 degree roof - $790 (17.11.11) Door to Study - $175 (17.11.11) Bulkhead to theater - $1050 (17.11.11) Extra linen cupboard - $1023 (17.11.11) Recess to shower - $438 (17.11.11) External Gas BBQ Bayonet - $284 (21.11.11) Upgrade staircase from wooden to vertical s/s balustrades and round maple handrail - $1,740 (29.11.11) Phone connection from meter box to the street - $443 (29.11.11) External ducting of range-hood - $385 (29.11.11) 2mm quantum quartz stone tops to bathroom and ensuite vanities - $390 x 2 (29.11.11) Upgrade all three toilets to wall-faced toilets - $255 each (29.11.11) Adjustment of internal kickplates and skirtings to allow for 34mm floorboards to be installed post-handover - $450 (29.11.11) One additional wall colour (for the rumpus plus a few other walls) - $250 (29.11.11) Upgrade to pyrolytic oven - $252 (29.11.11) Convert bathroom and ensuite to 4 lamp fan light heater - $380 each (29.11.11) Upgrade meter box to 3-phase - $480 (29.11.11) Dimmer switches for rumpus - $90 each (29.11.11) 4 x LED down-lights (wiring only) - $50 each (29.11.11) Upgrade to Daikin 20kw inverter system - $4,800 (29.11.11) 3 additional zones - $400 each (29.11.11) Upgrade to Diamond range bricks at PGH - $7,369 (29.11.11) Terracotta roof tiles (Nouveau) - $6,280 (29.11.11) Medium duty sarking - $2,527 (29.11.11) 2 x whirlybirds - $540 (29.11.11) 4 x snap vents to eaves - $180 (29.11.11) 40mm stone benchtops to kitchen - $1,600 (29.11.11) Soundscreen acoustic insulation batts to rumpus ceiling and walls - $710 (29.11.11) Double-sliding door to rumpus (in lieu of sq set opening) - $780 (29.11.11) Single Power Point - $55 (13.12.11) Double Power Point - $65 (13.12.11) Weatherproof Power Point - single $115, double $125 (13.12.11) Internal lights (bayonet fitting) - $50 (13.12.11) External light point on brickwork (junction box only) - $70 (13.12.11) Downlight points (wiring only) - $50 (13.12.11) Supply and install low voltage downlight - $80 (in addition to wiring cost of $50) (13.12.11) Wiring for future light sensor $75, or supply and install external light sensor $125 (13.12.11) Supply and install indoor motion light sensor (eg. in WIR or large pantry) - $145 (13.12.11) Exhaust fan - $130 (13.12.11) Dimmer switches from - $90 each (13.12.11) Weatherproof junction box for future garden lighting - $90 (13.12.11) Surge protection to meter box - $170 per phase (13.12.11) External under eave lights - $50 (08.01.12) Additional light circuits (required if adding lighting points over the standard circuit allowance) - $240 each (08.01.12) Additional power circuits (required if adding power points over the standard circuit allowance) - $250 each (08.01.12) 1 additional power light circuit - $240 (08.01.12) Upgrade the meter box to 3 phase - $480 (08.01.12) Internal CFL downlights - $60 (10.01.12) Internal LV downlights - $60 (10.01.12) 2700mm ceilings - 2740mm to ground floor only - $6350 (09.02.12) Ducted Glass canopy range-hood. - ducting is about $500 (09.02.12) Tiled Recess to showers in both the bathroom and ensuite - $970 (09.02.12) Enviroseal wall wrap - around $800 (09.02.12) Triple stacker sliding doors - 2 for $4369 (09.02.12) Extended garage width by 900mm - $5845 (09.02.12) Air Con - two extra zones - $828 (13.02.12) Colourbond roof (including anticon blanket) - $5800 (13.02.12) Upgrade bricks to Diamond Collection - $7,647 (21.02.12) Provide LIN1 internal hung door with traslucent glazing to Pantry (1x) and Bedroom 1 (2x) - $1,200 (21.02.12) Provide aluminium Bi-Fold door to rear of Family Room (similar to display home) (Type DABF5L1R 2448) in lieu of standard sliding door - $3,900 (21.02.12) colourbond roof and anticon blanket upgrade - $5800 (03.03.12) upgrade to 3 phase wiring in meter box - $470 (This varies with different providers) - (24.07.12) Extra Light Circuit and Extra Safety Switch - $240.00 each - (24.07.12) Light Points - $50.00 each - (24.07.12) Two Way Switch - $50.00 each - (24.07.12) Twin Para Flood with Sensor - $125.00 each - (24.07.12) Extra Power Circuit and Extra Safety Switch - $250.00 each - (24.07.12) Single Power Point - $55.00 each - (24.07.12) Double Power Point - $65.00 each - (24.07.12) Weatherproof Double Power Point - $125.00 each - (24.07.12) Internal lights or external under eave lights $50.00 - (24.07.12) o External light point on brickwork (this will be fitted off with a junction box only) $70.00 - (24.07.12) o Downlight Points (wiring only) $50.00 each - (24.07.12) o Supply & Install white fluro downlight $60.00 each (in addition to the wiring cost of $50.00) Please note that a greater number of fluro downlights will be required than traditional low voltage downlights. Please check BASIX certificate to see if fluro lighting is required in some or all rooms. - (24.07.12) o Supply & Install Low Voltage Downlight $80.00 each (in addition to the wiring cost of $50.00). This includes fire resistant enclosures to meet new regulations. The price also includes electronic transformers. - (24.07.12) o Wiring for future light sensor $75.00 or supply and install light sensor $125.00 (external) - (24.07.12) o Supply & Install Motion Sensor (Indoor) e.g. walk in robes/large pantries etc $145.00 - (24.07.12) o Exhaust Fans $130.00 - (24.07.12) o Fan Light Heaters-2 Lamp $320.00 or 4 Lamp $380.00 (includes extra circuit and extra safety switch as per new regulations). These prices are over and above a standard exhaust fan (if applicable). (If you require these to be ducted externally please notify consultant for pricing). - (24.07.12) o Dimmer switches (to dim up to 6 lights) from $90.00 each. Price varies depending on the number of lights connected to them. - (24.07.12) o Two Way switching $50.00 or Three Way switching $90.00 – useful for accessing a light switch from two or three different entry points e.g hallways or main living areas - (24.07.12) o Additional light circuits - $240 each (necessary if adding lighting points over the standard circuit allowance – see consultant for more details) - (24.07.12) o Additional power circuits - $250 each (necessary if adding power points over the standard circuit allowance – see consultant for more details - (24.07.12) o 20 amp Pool Circuit with Safety switch - $340.00 - (24.07.12) o Weatherproof Junction Box for future garden lighting $90.00 - (24.07.12) o Upgrade meterbox to 3 phase - $480.00 (This does not include the upgrade of aerial sections etc - if applicable). Additional costs may apply. 3 phase may not be available in your area. If you are having ducted air conditioning please check if 3 phase power has been included in your tender before your electrical appointment. Generally, it will need to be upgraded. - (24.07.12) o Surge protection to Meterbox - $170.00 per phase (i.e $510.00 for 3 phase meter box) - (24.07.12) Payment schedule: 5% Deposit 1/ Floor slab complete 20% 2/ Frame and roof truss delivery 20% 3/ Brickwork complete 15% 4/ Roof tile complete 20% 5/ Lock-up complete 10% 6/ Practical completion 7% 7/ Settlement and handover 3% Standard Masterton Product Links: Bricks (PGH) - http://www.pghclay.com.au/Bricks/Default.aspx with, Roof tiles (CSR Monier) - http://www.csrroofing.com.au/ Bricks (Austral) - http://www.australbricks.com/au/nsw with, Roof tiles (Bristle) - http://www.bristileroofing.com/au Garage Doors (Gliderol) - http://www.gliderol.com.au/?articleSet=59&article=475&articleSub=626 Doors (Hume doors) - http://www.humedoors.com.au/ Aluminium doors & windows (dowell) - http://dowell.com.au/docs/Product/products_by_state.asp?AUD=&site=Dowell Paint (Taubmans) - http://www.taubmans.com.au/public/colour/explore-your-options.aspx Stone Benchtops (Quantum quartz) - http://www.wk.com.au/ Cupboards & benchtops (Polytech - Createch) - http://www.polytec.com.au/createc_intro Appliances (Baumatic) - http://www.baumatic.com.au/smart/ Please PM me if you have more to add. Masterton Sirocco 7 2012-13 30.01-SITE CHECK 29.05-CONTRACTED 28.06-APPROVED 21.08-SCRAPED 13.09-SLABBED 02.10-FRAMED 24.10-BRICKED 28.11-PLASTERED 03.12-LOCK-UP 05.02-PAINTED 21.02-PCI 25.02-KEYS Blog-Thread Re: Masterton Homes - The new thread 2.0 3Feb 09, 2012 9:38 pm Heres a list of H1 forum members blogs/ build threads. Hope its a use-full reference and well done to everyone for all your hard work and perseverance squashedrex's Single story Sonata with Ivy facade in Newcastle, NSW: Masterton - http://www.masterton.com.au/Designs/tabid/60/agentType/View/PropertyID/15/Default.aspx Blog- http://jtsonata.blogspot.com.au/ Added 9th of feb 2012 PS-Sirocco7's Single story Sirocco 7 with traditional facade in Mystery Bay, NSW: Masterton - http://www.masterton.com.au/Designs/tabid/60/agentType/View/PropertyID/14/Default.aspx Blog- http://ps-sirocco7.blogspot.com.au/ Added 22nd of March 2012 Try not to post your interest to this post in this thread. It will just add congestion to the thread. Please PM me if you want your Blog/Build thread added to this post. Masterton Sirocco 7 2012-13 30.01-SITE CHECK 29.05-CONTRACTED 28.06-APPROVED 21.08-SCRAPED 13.09-SLABBED 02.10-FRAMED 24.10-BRICKED 28.11-PLASTERED 03.12-LOCK-UP 05.02-PAINTED 21.02-PCI 25.02-KEYS Blog-Thread Re: Masterton Homes - The new thread 2.0 4Feb 10, 2012 5:25 am Hi Paul Im going to be the first subscriber to your post I will let you know any prices we get when we receive our final contract Cheers and look forward to following your build Dani viewtopic.php?f=31&t=46741 Clovelly - Masterton Homes 5% to M 290312 CDC 21/06 20 days 29/08 Slab 17/09 Frame 26/09 Bricks 24/10 Roof tiles 20/11 Re: Masterton Homes - The new thread 2.0 6Feb 10, 2012 9:22 am Hi All I'm hoping someone can help me with this query. When we signed our contracts on the 13.1.12, there is a clause which states that we have 3 months to get the plans approved, otherwise we will have to pay the current base price of the house. I have been chasing them and they haven't even put it through to be approved yet. If they take say six weeks to put the plans into CDC, and then we end up going over the 3 months are we liable for that? It just seems they have these clauses with time limits on them and then they go and take their time so we have to pay the increase. They already tried to get us to pay $2800 because we went over the 2 months to sign the contract, but they didn't even have the contract ready within the two months, otherwise we would of signed it. It's a joke! We got out of that one, but we would of walked and lost our deposit if they made us pay that, but now we have signed contracts and can't walk. Re: Masterton Homes - The new thread 2.0 7Feb 10, 2012 9:38 am BTW - Great work! It must have taken ages. Re: Masterton Homes - The new thread 2.0 8Feb 10, 2012 9:02 pm Hi all, ive been reading over the older 2 threads these last couple of weeks and have found then very helpful! Excellent idea PS_S7 with this new thread as you said old one had too much outdated info and was getting to long. A little bit about myself: Building Villina 36 in Fairfield/Liverpool area, made some alterations, we have extended the first floor level bedrooms 4,3 & 2 by 1 meter, extended ground floor garage and study by 1.2 meter, added an alfresco area at 7x4 meters. Some prices for whoever is interested High ceilings ground floor $6,328 Increase garage/study by 1.2m $6,054 Extend bedrooms 4,3 & 2 by 1m $6,175 Alfresco 7.3m x 4m $8,446 Glazing to staircase window $189 Upgrade bricks to diamond range $7,114 Medium duty sarking and anti flap pads $2,429 Provide brick face ILO lightweight cladding to front of house $1,530 Provide door to study $175 100mm skirting & 75mm architraves $980 Provide 3 step cornice $3,579 Soft close drawers Complimentary Provide 40mm stone bench tops to kitchen $2000 Ducting to outside for rangehood $875 Stone benchtops to powder room, bathroom & ensuite Complimentary Gas point for bbq on alfresco $284 A/C special offer $5990 260 litre solar hot water with gas boost $4,211 Got the mansion package $4990 PRICES AS OF 8/2/12 Happy building to everyone!! Villina 36 $3K Fee Paid 10/1/2012 Contract Signed 20/4/2012 Council Approval 18/7/2012 In Construction 13/9/2012 Re: Masterton Homes - The new thread 2.0 9Feb 10, 2012 9:17 pm KDLEN Hi all, ive been reading over the older 2 threads these last couple of weeks and have found then very helpful! Excellent idea PS_S7 with this new thread as you said old one had too much outdated info and was getting to long. A little bit about myself: Building Villina 36 in Fairfield/Liverpool area, made some alterations, we have extended the first floor level bedrooms 4,3 & 2 by 1 meter, extended ground floor garage and study by 1.2 meter, added an alfresco area at 7x4 meters. Happy building to everyone!! Interesting I live in Fairfield/Liverpool area would love to do a drive by one day So what stage are you at? Im building in South and M had a moment on Thursday when they realised it took them 10 weeks to provide us with preliminary plans They said they werent sure what happened and that the house will take 13 months from when we paid our deposit in Oct 11. Thats not going to pan out for them not my problem there was a stuff up and they lost 10 weeks! I had better be in by Nov or they can pay my rent. They said theyll try and speed it up and I believe them cause Ill be calling them every day till they do viewtopic.php?f=31&t=46741 Clovelly - Masterton Homes 5% to M 290312 CDC 21/06 20 days 29/08 Slab 17/09 Frame 26/09 Bricks 24/10 Roof tiles 20/11 Re: Masterton Homes - The new thread 2.0 10Feb 11, 2012 8:03 am Well we got a nice surprise when we went to our block yesterday. Someone has illegally dumped fill on our land. Details in the blog. jayliam - If they are holding up the process they cant charge you. Re: Masterton Homes - The new thread 2.0 11Feb 11, 2012 9:27 am [quote="squashedrex"]Well we got a nice surprise when we went to our block yesterday. Someone has illegally dumped fill on our land. Details in the blog. That just sucks And your right as they have held up our process so they just moved the date forward Hope you find the bugger that did it! viewtopic.php?f=31&t=46741 Clovelly - Masterton Homes 5% to M 290312 CDC 21/06 20 days 29/08 Slab 17/09 Frame 26/09 Bricks 24/10 Roof tiles 20/11 Re: Masterton Homes - The new thread 2.0 12Feb 11, 2012 12:18 pm squashedrex Well we got a nice surprise when we went to our block yesterday. Someone has illegally dumped fill on our land. Details in the blog. Did any of the neighbouring houses see who did it? Re: Masterton Homes - The new thread 2.0 13Feb 12, 2012 7:17 am Of the few neighbouring houses we have at the moment 2 saw them dumping it on Wed. Unfortunately neither of them took much notice as they didn't think it was out of the ordinary. Albeit one had to move his car for the truck to get in. One said it was no more then 10mins between loads, so it had to be from our estate. I just don't understand why they picked our block, literally 200m down the road there is an open area that Landcom have been using to dump fill from the soccer grounds they are building nearby. The thing is a small mountain. If they wanted to dump it illegally that would be the place to do it, nobody would ask questions. They have dumped it so neatly across the back of our lot.. I'm starting to think someone has made a mistake and that fill was needed for another lot. Anyhow we had another discussion with the Landcom consultant yesterday and she says they will get rid of it but it will take 10 days. Not sure if this will affect us as we have been released to construction apparently. Will keep you all posted. Re: Masterton Homes - The new thread 2.0 14Feb 12, 2012 7:41 am [quote="squashedrex"]Of the few neighbouring houses we have at the moment 2 saw them dumping it on Wed. Unfortunately neither of them took much notice as they didn't think it was out of the ordinary. Albeit one had to move his car for the truck to get in. One said it was no more then 10mins between loads, so it had to be from our estate. You know as I was reading your post I was thinking to myself bet that was meant for another block and they've made a mistake. You might find they will come back and get it? I suppose the best thing is that even if it takes 10 days your not paying to have it removed. just trying to cheer you up dont know if its working Best of luck mate Cheers Dani PS Chose our bricks today what do you think? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ viewtopic.php?f=31&t=46741 Clovelly - Masterton Homes 5% to M 290312 CDC 21/06 20 days 29/08 Slab 17/09 Frame 26/09 Bricks 24/10 Roof tiles 20/11 Re: Masterton Homes - The new thread 2.0 15Feb 12, 2012 7:51 am No your're right Dani, at least we aren't paying for it. The dark brick looks awesome, we had a hard time choosing our brick colour as we wanted dark but it was another $5k roughly. Re: Masterton Homes - The new thread 2.0 16Feb 12, 2012 10:26 am squashedrex No your're right Dani, at least we aren't paying for it. The dark brick looks awesome, we had a hard time choosing our brick colour as we wanted dark but it was another $5k roughly. Yeah I know and to b honest it's been hard to justify but we bit the bullet as we just couldn't agree on anything else and it was cheaper than a divorce viewtopic.php?f=31&t=46741 Clovelly - Masterton Homes 5% to M 290312 CDC 21/06 20 days 29/08 Slab 17/09 Frame 26/09 Bricks 24/10 Roof tiles 20/11 Re: Masterton Homes - The new thread 2.0 17Feb 12, 2012 10:27 am viewtopic.php?f=31&t=46741 Clovelly - Masterton Homes 5% to M 290312 CDC 21/06 20 days 29/08 Slab 17/09 Frame 26/09 Bricks 24/10 Roof tiles 20/11 Re: Masterton Homes - The new thread 2.0 18Feb 13, 2012 9:06 am dsa39 we neighbours we are living in fairfield west at the moment! Still early stage for us, we should get our first set of plans next week or two. You pick of bricks and external colours looks good very similar to us, we have gone for the Blue Steel Flash from PGH. Has anyone had a price from Masterton on doing shadowline ceilings? And would anyone know if Masterton will put in a polyeurathene kitchen instead of the createc Im prepared to pay extra for it but no one at Masterton can give me an answer if it can be done. Villina 36 $3K Fee Paid 10/1/2012 Contract Signed 20/4/2012 Council Approval 18/7/2012 In Construction 13/9/2012 Re: Masterton Homes - The new thread 2.0 19Feb 13, 2012 10:20 am KDLEN dsa39 we neighbours we are living in fairfield west at the moment! Hi KDLEN Hello neighbour, we are probably going to be going through this at the same time so nice to have someone to bounce off. hey with your first set of plans make sure you stay on them ours took 10 weeks and when we had our appointment to go throught them our coordinator said he couldnt understand why it had taken so long should only take a couple of weeks. We called and called but they kept putting us off. The end result is that we wont start till June and he reckons will take 8 moths to build which means a 13 month process. Our customer service manager Garry is in hospital at the moment so when he gets back we are going to ask them to speed up the process cause we were told we would be in in 12 months which is NOV 12 not FEB 13. Is there any reason you want a poly kitchen instead of a createc? Createc is much more durable product Poly chips really easily. My sister got Poly with Clarendon and its been a nightmare. Chips everywhere. Also if you want to change your kitchen design you can have a kitchen appointment for $450. I highly recommend it as they have great ideas its somewhere near Raby the guy Ben was great but be prepared to spend a bit more. Is the shadowline ceiling the one without cornices? If so I understand its terribly expensive but NICE! look forward to following your build. PS LOVE Blue Steel Flash but for our design we needed a less blended look as theres alot of brick cant wait to see yours. Good luck! Cheers Dani viewtopic.php?f=31&t=46741 Clovelly - Masterton Homes 5% to M 290312 CDC 21/06 20 days 29/08 Slab 17/09 Frame 26/09 Bricks 24/10 Roof tiles 20/11 Re: Masterton Homes - The new thread 2.0 20Feb 13, 2012 4:01 pm Hi Everyone, We had our Air Con appointment today. We added two extra zones for a total of $828. We have our colour appointment on Friday so I'm looking forward to that. Also our plans were sent to the Certifyer today. Also PS_Sirrocco7, if you want to add to the list, we upgraded our roof to a colourbond for a total of $5800 which includes the anticon blanket. 4 16735 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11117 Hi there! Putting the feelers out there for those who have (or almost) built with Arli homes! Interested in your experiences who've built from their stock home designs… 0 23482 |
