Browse Forums Building A New House 1 Feb 07, 2012 11:38 am Hi everyone Some builders apppear to advertise 'superior' inclusions such as: - 300mm (floor) joist system (as opposed to 250mm standard?) - 90mm internal/external frames (as opposed to 70mm/75mm standard?) Are these inclusions really superior? Thoughts anyone? Building ??? with ??? Re: Builder 'superior' inclusions ?? Floor joist and frames 2Feb 08, 2012 4:52 pm Bumping this thread .... Anyone know anything? Building ??? with ??? Re: Builder 'superior' inclusions ?? Floor joist and frames 3Feb 08, 2012 7:43 pm They would be superior over the standard, but not necessarily a necessity. For instance in WA, some builders do 100mm slabs as standard which is better than the common 80mm slab. It's usually not a necessity, but considered superior. The home will be fine with 80mm, but 100mm might mean it being less prone to cracking, more structural integrity etc which is important to some people. Hope this helps! Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 31702 1 10101 Seconded; we just used these last weekend to build a small deck. They worked perfectly as we have bluestone in the area where we wanted to build so digging down was not… 8 9034 |
