Browse Forums Building A New House Re: Garage Ceiling 2Feb 02, 2012 5:14 pm I'm no expert but if you are talking about HardiFlex vs Plasterboard .... HardiFlex is a heavier material and it absorbs less moisture than plasterboard. Its extra weight may have minor implications in rafter/batten sizes. I'm not sure which is more fire resistant or which provides better thermal or sound insulation properties, can anyone comment? My guess is that it is probably better on both fronts. Finish wise, my gut feel is that plasterboard is easier to get a smoother finish as it is gypsum covered in paper. I'm sure a few others will have some much more insightful information!! Re: Garage Ceiling 3Feb 02, 2012 5:21 pm PS. Have a look at http://en.wikipedia.org/wiki/Cement_board (HardiFlex is a cement fibre board). It has some good points on advantages and disadvantages. Re: Garage Ceiling 4Feb 07, 2012 12:14 am Aesthetically, plasterboard looks nicer. Plasterboard will be finished to look like one big piece of sheeting with no joins (the same as the ceilings inside the house), whereas hardiflex will have strips joining each sheet (like your eave lining). It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17199 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5944 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2452 |
