Browse Forums Building A New House 1 Jan 31, 2012 7:46 pm Hello, We are currently watching our house been build and have just reached lock-up. When looking through the house the other day I leant against one of our Jason Windows and the window frame moved 15mm away from the plaster at the bottom. I checked a few other windows and found 4 other windows seemed loose. Did I do something wrong or am I right in thinking that the window frames should not move from someone leaning against them? I would love to hear your opinions Thanks Re: Window frame movement in brick walls 2Jan 31, 2012 9:31 pm Are all the skirting's attached yet? I'd be telling the builder to check them, they really shouldn't be moving. Easier to fix before skirting and paint is done Re: Window frame movement in brick walls 3Feb 01, 2012 4:56 pm Sarah n Glen Hello, We are currently watching our house been build and have just reached lock-up. When looking through the house the other day I leant against one of our Jason Windows and the window frame moved 15mm away from the plaster at the bottom. I checked a few other windows and found 4 other windows seemed loose. Did I do something wrong or am I right in thinking that the window frames should not move from someone leaning against them? I would love to hear your opinions Thanks Say something... arcs and skirts are not supposed to hold windows in place. They should be firm enough to lean on now. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Window frame movement in brick walls 4Feb 01, 2012 5:43 pm Your windows and the reveals around them should be packed out and nailed or screwed into the studs beside them. This needs to be done right or you may face movement issues later in the life of the house. ----------------------------------------------------------- Monte Carlo Grande Elite with McDonald Jones http://mdjatvermont.blogspot.com/ Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20617 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8055 Are they stumps or screw piles ? How much fill is there, is the site a class "P" ? A "H2" site is not supposed to have stumps it is supposed to have grid beams according… 1 6955 |
