Browse Forums Building A New House Re: Independent Building Inspections 21Jun 03, 2012 4:37 pm Hi Nicole, I'm so sorry that your SS is trying to bully you, he probably knows that he's in the wrong is trying to scare you. HOWEVER, as per contract, you can't withold payment for a stage they have completed. My advice is contact the DoFT & explain the situation to them, & I'm sure they can lead you to right path. Also, if you can, get legal advice. Re: Independent Building Inspections 22Jun 03, 2012 4:54 pm springtime Hi Nicole, I'm so sorry that your SS is trying to bully you, he probably knows that he's in the wrong is trying to scare you. HOWEVER, as per contract, you can't withold payment for a stage they have completed. My advice is contact the DoFT & explain the situation to them, & I'm sure they can lead you to right path. Also, if you can, get legal advice. Thanks for the advice. Can builder say they finish a stage with having issues to fix ? I'm in Victoria and what is DoFT ? Is it in VIC ? Nicole1983 Re: Independent Building Inspections 23Jun 03, 2012 6:55 pm soccermum Does anyone know of one in the Wollongong area (or even south Sydney if there prepared to travel) Try Howard & Ryan or John Worthington... They're about $490-595 each stage. Re: Independent Building Inspections 24Jun 03, 2012 6:58 pm Nicole1983 springtime Hi Nicole, I'm so sorry that your SS is trying to bully you, he probably knows that he's in the wrong is trying to scare you. HOWEVER, as per contract, you can't withold payment for a stage they have completed. My advice is contact the DoFT & explain the situation to them, & I'm sure they can lead you to right path. Also, if you can, get legal advice. Thanks for the advice. Can builder say they finish a stage with having issues to fix ? I'm in Victoria and what is DoFT ? Is it in VIC ? Sorry to know your problem, Nicole, you have to report it... The independent inspector should back you up with legal action... What's the builder (head office) said about that? DoFT- Department of Fair Trading. Not sure what it's called in Vic. Re: Independent Building Inspections 25Jun 04, 2012 10:37 am Hi Nicole Wow, tough and frustrating situation. You need to find a way to get it back on track so you're not off side with the builder and run into any more problems down the track. Did you instruct the builder to make the changes in the report? If not, I'd be questioning why he's gone ahead with making changes without getting clear instruction from you. I'd suggest you ask to meet with him and the building inspector you engaged and work your way through each of the recommendations in the report and agree on what will or won't be remedied. The building inspector can explain what he's put in the report and why and should be able to cover any of the technical details that you don't understand. Failing that if you can't get a clear resolution then look to get some legal advice on your contractual options. Good luck! Cheers Donna Re: Independent Building Inspections 26Jun 04, 2012 12:26 pm Thanks guys for all your help...Now dr5ama begins... Which one is structurally more superior than another,Bulkhead above the kitchen cupboards is MDF or Plaster boards (frame) ? 2550mm ceiling height and this is new construction. Originaly my Builder has done Bulkhead above the kitchen cupboards using Plaster (Frame). After Pre plaster inspection done by private inspector, his report says, "There have not been any noggins installed between the wall studs under the bulkhead/drop ceiling trimmers to the Kitchen to pick up and support the edges of the plaster wall sheets.The relevant Australian Standard AS/NZS 2589.1 Gypsum Linings In Residential and Light Commercial Construction – Application and Finishing , clause 7.6.2 Spacing, requires that ‘Plasterboard shall be fastened at a maximum of 300mm centres for internal angles, external corners and around openings’. Given the spacing of the existing studs, noggins will need to be installed so that the edges of the wall sheets can be securely fixed to the wall framing at their required centres." So what my builder did was he removed whole bulk head done by Plaster and he is telling me he will do it using MDF . So i don't know which method is good. Please help me on this. Thanks. Nicole Nicole1983 Re: Independent Building Inspections 27Jun 04, 2012 5:33 pm Sorry, Nicole, can't help here.... Can you ask some kitchen shop or google it? Re: Independent Building Inspections 28Jun 04, 2012 10:10 pm Call your Inspector and ask them if the method they are going to use is acceptable..... if not go above the SS and complain.... Re: Independent Building Inspections 29Jun 29, 2012 4:55 pm Nicole1983 Thanks guys for all your help...Now dr5ama begins... Which one is structurally more superior than another,Bulkhead above the kitchen cupboards is MDF or Plaster boards (frame) ? 2550mm ceiling height and this is new construction. Originaly my Builder has done Bulkhead above the kitchen cupboards using Plaster (Frame). After Pre plaster inspection done by private inspector, his report says, "There have not been any noggins installed between the wall studs under the bulkhead/drop ceiling trimmers to the Kitchen to pick up and support the edges of the plaster wall sheets.The relevant Australian Standard AS/NZS 2589.1 Gypsum Linings In Residential and Light Commercial Construction – Application and Finishing , clause 7.6.2 Spacing, requires that ‘Plasterboard shall be fastened at a maximum of 300mm centres for internal angles, external corners and around openings’. Given the spacing of the existing studs, noggins will need to be installed so that the edges of the wall sheets can be securely fixed to the wall framing at their required centres." So what my builder did was he removed whole bulk head done by Plaster and he is telling me he will do it using MDF . So i don't know which method is good. Please help me on this. Thanks. Nicole MDF won't be a nice finish unless it has a laminate on it... so ask your SS about the finish... Strength won't matter if he follows the standard I think... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Independent Building Inspections 30Jul 04, 2012 2:16 pm CC101 AubinGroveFan Can someone recommend IBI south of the river in Perth? Thanks I sent a pm with details Hello good afternoon, Could someone as well recommend IBI north of Perth-Darch area? Many thanks in advance Re: Independent Building Inspections 31Jul 29, 2012 10:28 pm Nicole1983 Thanks guys for all your help...Now dr5ama begins... Which one is structurally more superior than another,Bulkhead above the kitchen cupboards is MDF or Plaster boards (frame) ? 2550mm ceiling height and this is new construction. Originaly my Builder has done Bulkhead above the kitchen cupboards using Plaster (Frame). After Pre plaster inspection done by private inspector, his report says, "There have not been any noggins installed between the wall studs under the bulkhead/drop ceiling trimmers to the Kitchen to pick up and support the edges of the plaster wall sheets.The relevant Australian Standard AS/NZS 2589.1 Gypsum Linings In Residential and Light Commercial Construction – Application and Finishing , clause 7.6.2 Spacing, requires that ‘Plasterboard shall be fastened at a maximum of 300mm centres for internal angles, external corners and around openings’. Given the spacing of the existing studs, noggins will need to be installed so that the edges of the wall sheets can be securely fixed to the wall framing at their required centres." So what my builder did was he removed whole bulk head done by Plaster and he is telling me he will do it using MDF . So i don't know which method is good. Please help me on this. Thanks. Nicole Hi Nicole Just wondering how you got on regarding your kitchen bulkhead issue with your builder? We built the Wisdom Majestic 40 - moved in! Our blog - http://ourwisdommajestic40.blogspot.com.au/ Our H1 thread - viewtopic.php?t=54156 Re: Independent Building Inspections 32Dec 09, 2012 7:04 pm bumping this thread again if you have not voted before... Knockdown and rebuild - Metr1con Nolan 45 Plantation Our Build Blog @ http://ournolan.wordpress.com Our Build Thread @ viewtopic.php?f=31&t=52812 Re: Independent Building Inspections 33Jan 29, 2013 8:00 am I have created a blog thread on this topic with links to several inspectors: http://ournolan.wordpress.com/2013/01/2 ... spections/ Knockdown and rebuild - Metr1con Nolan 45 Plantation Our Build Blog @ http://ournolan.wordpress.com Our Build Thread @ viewtopic.php?f=31&t=52812 Re: Independent Building Inspections 34Jan 29, 2013 9:00 am South of the river - Perth Baldivis... IBI please??? Re: Independent Building Inspections 35Jan 29, 2013 8:19 pm Just thought I'd add my appreciation for building inspectors within the building process. I'm on my 3rd build now, I would NEVER go without one. Apart from the fact that they do a great job, they put a buffer between you and your builder, which is important for your relationship with them, as you're simply 'passing the message on' so to speak. The way the building industry runs today you can simply never trust anyone. Getting things fixed post handover is brutal too. You simply don't have to go through that if you don't want to. Re: Independent Building Inspections 36Jan 29, 2013 8:30 pm I'm actually surprised more people don't get it done at every stage now I've realised the cost... Around $400-$500 at each stage - why not considering cost it can save later!! Definitely worth it in my books!! Re: Independent Building Inspections 37Jan 29, 2013 9:11 pm happytaurus I'm actually surprised more people don't get it done at every stage now I've realised the cost... Around $400-$500 at each stage - why not considering cost it can save later!! Definitely worth it in my books!! Hi HT. had no idea, that is quite reasonable as far as I'm concerned. If anyone pm's you the details, would you might sharing please? Or if anyone has details for IBI in and around Mandurah I would appreciate a pm. Thanks Re: Independent Building Inspections 38Jan 29, 2013 9:50 pm So if the inspector finds issues, what is the next step? Can I withhold payment for the stage until it is fixed or should I simply pay the stage asap (to avoid late payment and extra charges) and just ask them to fix it as per inspection? I'm just not sure what leverage we have to get the builder to make the required changes. Maybe the only thing that can be done is refuse the final handover payment until everything is fixed, but if there's issues at the frame stage for example, then the final stage would obviously be too late if it is still not fixed by then. Also, any recommendations for inspector in Brisbane area? Re: Independent Building Inspections 39Jan 29, 2013 10:00 pm I actually never thought about what would happen if your IBI picks up things that need to be rectified - I just assumed that the builder will just need to fix it! Re: Independent Building Inspections 40Jan 29, 2013 10:04 pm There's always that possibility that the builder won't take it well. I will be worried to upset them but at the end of the day it's such a big investment and I want to be be certain that nothing is going to crumble around us. And surely if there's valid reason for concern they have to attend to it. You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18063 That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 81883 It is true that a builder can ignore your independent inspection report as it is not part of the contractual arrangement but that is stupid because he cannot avoid fixing… 9 46854 |
