Browse Forums Building A New House Re: SLAB Wrong Dimension 2Dec 29, 2011 5:28 am The slab can be extended but the method depends on how much the dimensions are out. From comments I have seen here if you live in WA and are having a double brick house the builders put the outside brick skin on concrete footings so the slab is smaller than the overall house plan. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: SLAB Wrong Dimension 3Dec 29, 2011 9:36 am bashworth The slab can be extended but the method depends on how much the dimensions are out. From comments I have seen here if you live in WA and are having a double brick house the builders put the outside brick skin on concrete footings so the slab is smaller than the overall house plan. Thanks Bashworth. Is there a subject or post here about such so i too can have a read. yes we are in WA. I might need to go and have a look again at the site to verify such footing exist. angel Re: SLAB Wrong Dimension 4Dec 29, 2011 10:12 am Demolition August 2009, Construction Started September 2009, Completed December 2010 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10683 2 31344 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18298 |
