Browse Forums Building A New House 1 Dec 16, 2011 3:46 pm My house concrete slab just finish. When I measured it on site, it comes short by 240-300mm around the side where the double brick cavity wall located. Is that normal? Do they do the Double brick cavity on top of a strip footing around the slab perimeter??? Re: Slab smaller size than the internal floor plans 2Dec 17, 2011 1:08 am For double brick cavity walls, the internal leaf of bricks will sit on the slab, but the external leaf will sit down on the footings - therefore the slab should only be to the size of the internal bricks, so all sides of the slab will be approx 250mm smaller than the external dimensions shown on your plans. Re: Slab smaller size than the internal floor plans 3Dec 17, 2011 7:56 pm And don't stress if the slab looks small on the ground, they usually do. Once the walls go up you will be surprised how much fit's on. Re: Slab smaller size than the internal floor plans 4Dec 17, 2011 8:43 pm The "top" of your slab should be 320 mm smaller than the external dimensions. The "bottom" of your slab should be at least the external dimensions. Demolition August 2009, Construction Started September 2009, Completed December 2010 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 47157 Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4788 |
