hi, just wondering what builders are charging for extra power points [doubles] and lights? We are going thru redink and dont know whether to add extra when we do prestart or wait until after build and get electrician to do it?
tia
Browse Forums Building A New House 1 Dec 15, 2011 3:08 pm hi, just wondering what builders are charging for extra power points [doubles] and lights? We are going thru redink and dont know whether to add extra when we do prestart or wait until after build and get electrician to do it? tia Re: Cost of extra power points/lights 2Dec 15, 2011 4:50 pm It's going to be a lot easier to get the builder to install them and cleaner. There is a lot more information at this link about rough costs and what you might need. http://www.anewhouse.com.au/?p=1133 The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Cost of extra power points/lights 3Dec 15, 2011 4:57 pm Our builder is charging 2 outlet $59 4 outlet - $94 Outdoor, 2 outlets - $122. We ended up spending $780 on electrical points but apparently a lot cheaper to put in while the house is being built Re: Cost of extra power points/lights 4Dec 15, 2011 5:59 pm thanks for that...exactly the info i needed. will def go with builder Re: Cost of extra power points/lights 6Dec 15, 2011 6:04 pm Our builder Bentley Homes were $46 for each extra double power point and battern light. Better to do it while building then afterwards where it costs alot more. A bank is a place that will lend you money only if you can prove that you don't need it... Re: Cost of extra power points/lights 7Dec 15, 2011 9:43 pm You could try getting it done through the builders electrician. That way you avoid the builders margin. Ask your builder if this is possible. We have done this and electrician will do builders work and also our extra add ons at same time. McKeachies Run, Aberglasslyn Deposit paid 11th April Land registered 6th June Land settled 20th June Colour selections and contract signed 5th August Commencement letter received 26th September Re: Cost of extra power points/lights 9Dec 16, 2011 6:45 am Some builders won't mind you approaching the sparky direct and getting them put in at the same time. But if they say no you have to go through us, it's not just a money grab on there part. As a past maintenance manager for one of qld's bigger buiders I had many instances of requests to fix a light or gpo that weren't working, only to find they weren't in the contract but done direct with the sparky. There is also the real risk of over loading a circuit, if you add additional lights or gpo's to it at a later date. Talk to your SS and ask them if it's ok. Re: Cost of extra power points/lights 10Dec 16, 2011 7:55 am hayreebean Our builder is charging 2 outlet $59 4 outlet - $94 Outdoor, 2 outlets - $122. We ended up spending $780 on electrical points but apparently a lot cheaper to put in while the house is being built Am I missing something? The cost of a 4 outlet power point is less than $10 more than a 2 outlet power point and labour is the same. Why the $35 difference! (Would be cheaper to only have 2 outlet power points and change over afterwards.) Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Cost of extra power points/lights 11Dec 16, 2011 10:26 am @ caz_770 - $122 per downlight including installation @ Casa2 - I don't know but considering we're building our first home and aren’t electricians we thought we'd just get this done by the builder. We've only got 2 of the 4 outlets, so $70 wasnt blowing the budget. Re: Cost of extra power points/lights 12Dec 16, 2011 5:35 pm The power points are ok but you can get cheaper quotes from external electricians. Also downlight points alone .. with private electricians will cost only about $40-60 each.. you will have to provide the lights. Redink will charge you double of that. With External light points.. Redink is reasonable $80 per point..which is about that price with private electricians. That's through my own research. So if you have heaps of downlights , it'll be cheaper to do it after. July 2011 Signed up with Redink Sep 2011 Titles for Land Dec 2011 Plans approved by council 30 Jan 2012 SLABBED! Re: Cost of extra power points/lights 13Dec 16, 2011 11:46 pm Casa2 hayreebean Our builder is charging 2 outlet $59 4 outlet - $94 Outdoor, 2 outlets - $122. We ended up spending $780 on electrical points but apparently a lot cheaper to put in while the house is being built Am I missing something? The cost of a 4 outlet power point is less than $10 more than a 2 outlet power point and labour is the same. Why the $35 difference! (Would be cheaper to only have 2 outlet power points and change over afterwards.) Cost of the powerpoint. I can buy a Clipsal double GPO for $6. I can't get a 4 gang GPO for less than $40 (commercial quantities). Re: Cost of extra power points/lights 14Dec 17, 2011 11:28 am ChargerWA Casa2 hayreebean Our builder is charging 2 outlet $59 4 outlet - $94 Outdoor, 2 outlets - $122. We ended up spending $780 on electrical points but apparently a lot cheaper to put in while the house is being built Am I missing something? The cost of a 4 outlet power point is less than $10 more than a 2 outlet power point and labour is the same. Why the $35 difference! (Would be cheaper to only have 2 outlet power points and change over afterwards.) Cost of the powerpoint. I can buy a Clipsal double GPO for $6. I can't get a 4 gang GPO for less than $40 (commercial quantities). In that case, it would probably make more sense to put two doubles near each other than one 4 way. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Cost of extra power points/lights 16Dec 18, 2011 2:10 pm I paid $40 or $50 for double powerpoints and $60 to changeover to downlights from batten lights. Re: Cost of extra power points/lights 17Dec 18, 2011 6:31 pm Yeah just make sure if you are looking at doing any electrical's after your build and you are using a different sparky, make sure you have them give you an idea of price before hand. It may not be a case of just throwing in a half dozen extra lights and gpo's. It may also require another circuit be run. Re: Cost of extra power points/lights 18Dec 18, 2011 7:21 pm It should be cheaper to get it done by the builder. Even with their 30% margin, once the ceilings are in it takes twice as long to do anything. Re: Cost of extra power points/lights 19Dec 18, 2011 8:49 pm Hello, ANything being installed after the house is done will cost more. This is because of the labour it will take to install new runs of cable down completed walls. So dont expect an electrician to still charge just 40-60 dollars per powerpoint in a finished home. They will charge a call out fee, hourly rate, parts plus a percentage profit. Another way around this is to get the electricians to run the cables but leave them in the wall, not connected to anything. you may even be able to negotiate some cash for the guys to chuck some extra wires in during rough-in. It really doestn take long, expect around 5-10 mins max per powerpoint.. except in extreme circumstances. Another note, to run cables later on Internal walls means cutting holes in the plaster.. so you may have to add to the cost of repainting etc... happy building chris Electrical - Automation - Smart wiring - New homes - Commercial - Data cabling] 1300 050 315 www.cenemelectrical.com.au www.facebook.com/cenemelectrical Cost of extra power points/lights 20Dec 19, 2011 10:52 pm We paid $55 per double. We could of had it done cheaper after hand over but it was much easier to have it all done at the same time plus I don't want messy/dirty tradies in my house when it's finished Jasmin Hickinbotham Belmont - modified Signed: February 2011 Slab should go down before 2012 My build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=52310&p=799483#p799483 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13863 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 14243 |
