Browse Forums Building A New House Re: Barker's Build - pegs, water tank and mini excavator 61May 25, 2012 9:36 pm Good luck. Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Barker's Build - pegs, water tank and mini excavator 62May 25, 2012 11:26 pm Thanks Dee, Should be fun. At least when this bit is done, the builders will be doing everything. Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: Barker's Build - pegs, water tank and mini excavator 63May 26, 2012 11:14 pm After your post of everything that needs to be done I was going to suggest dragging your visitors to the block for a hard days work Hopefully you don't need to get the whole tank filled tomorrow...... not fun filling that up Re: Barker's Build - bobcat fun 64May 27, 2012 7:48 pm Well I rounded up the old folks to come with me out to the block and between us and a 1.5ton Bobcat, we cleared 1200sqm (only needed to do 870 for the irrigation but now there can't be any complaints about the size if they need to go around the gum trees). Some pics of the clearing fun. http://i1260.photobucket.com/albums/ii575/tallong/2012-05-27133206.jpg http://i1260.photobucket.com/albums/ii575/tallong/2012-05-27133140.jpg http://i1260.photobucket.com/albums/ii575/tallong/2012-05-27133201.jpg http://i1260.photobucket.com/albums/ii575/tallong/2012-05-27133150.jpg The water tank is also full and ready to go. I also found out off a neighbour that the water tap at the front is bore water, but it goes through a treatment plant before being pumped out to the blocks so it is not 'bore water' in the traditional sense and so should be fine for building. I took a sample to have checked for acidity/alkalinity at a pool shop and then I will be onto the SS. It will make providing water a hell of a lot easier if it is ok. Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: Barker's Build - bobcat fun 65May 28, 2012 8:39 am Nice work, looked like you had fun. Fingers crossed that water is sweet and that Allworth get cracking soon 2 Re: Barker's Build - bobcat fun 66May 28, 2012 2:13 pm Got the water tested and it seemed to test better than normal drinking water in terms of calcium and acidity so yay for that. I also then had a look at the community association rules where it actually states that the reticulated water system is potable water (fine for humans) and so is not dirty bore water. If I had read that before speaking to Allworth, I could have avoided all of this drama with the water as there would have been no concerns with the water supply. Live and learn I suppose. Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Barker's Build - letter of commencement just in time! 67May 29, 2012 10:42 am Got the call from the bank and all loans have been approved and the letter of commencement will be emailed to the builder today. Which is lucky as if it was any later, it would have resulted in a possible price increase. So YAY!!! Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Barker's Build - AARGH! 68May 31, 2012 3:35 pm Builder claiming letter of commencement not valid. Bank needs my guarantor to sign a document and they are about to go on a 6 month holiday. Had to prove to builder that build can be paid for (more bleeding forms). All done now but man has it sapped my enthusiasm for the build. I think I need to play with another bobcat... Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Barker's Build - Excavation pics 69Jun 15, 2012 7:42 pm Got a phone call from the SS today and they will be doing the piers early next week and I have to be onsite. So today when I went to check on the water tank, I saw that the cut and fill has now been finished! So we have started. If everything stays within their projected time frames, it should be done by start of November! Here are some pics. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Barker's Build - Luck with the piers! (plus pic) 70Jun 21, 2012 7:51 pm So today I went out to measure the piers before the slab was laid. The builder allows for 65 lineal metres and we came in at...51.9 metres! So that means there should be a credit coming to us (have not checked out how much yet but is worth a few packets of Tim Tams and maybe some Mint Slices too). Here is a pic of the concrete guys hard at work. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ When we were measuring the holes, I realised that they were putting the heat pump just outside the main bathroom (which is the logical place to put it). However as these can be noisy, I had asked for it to be next to the laundry (also easier for plumbing) but they did not move it and as I was focused on the other plan changes that weren't done, I did not notice that it had been put back next to the bathroom. However, when I mentioned it, the concreter said he could put the pier hole for the heat pump next to the laundry and would talk to the SS about it. If the builder has a problem with it changing (don't know why it should be), the other slab bit is next to the bathroom anyway. But hopefully, all good to be near the laundry. Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: Barker's Build - Excavation pics 71Jun 21, 2012 8:14 pm Are you getting an M or H slab? I have got 80lm on my quote so i would be super happy to get around the same and get a nice credit 2 Re: Barker's Build - Excavation pics 72Jun 22, 2012 10:07 am M class slab. My soil is sand on bedrock so s class soil but because there could have been trees there before it was recommended to get m class slab anyway. This should save me about 1800 bucks. The venefit was that for half the slab they hit bedrock at 700mm so nice short pier holes Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: Barker's Build - Excavation pics 73Jun 23, 2012 12:47 pm Plumbing for slab done and reo and waffle pods delivered. Concreter said he would be doing that saturday and slab poured probably on tuesday. Although note there is no reinforcing pier for heat pump either near laundry or bathroom so hopefully will be sorted next week. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I can only get to the site on thursdays or fridays so will se what is happening next week Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Barker's Build - Slabbed (with pics) and security guard 74Jun 29, 2012 10:27 am Well the slab is down and the temporary fence is up! The slab looks good (not that I have any technical experience). I could not see any cracking or chipping off the corners. There are small depressions around each of the pipes where it looks like the concrete has sunk a bit that is normal isn't it? It has also made me appreciate the cool slippery slide we can have out the side door as the cut and fill puts it about a metre off the old land level for a bit of a down hill slope. I am thinking deck...(after lotto maybe...) Here are some piccies. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ They have moved the heat pump to where I wanted it originally so yay! Although the little slab for the heat pump does not look entirely level, it may just be my viewpoint. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And finally, here is the security guard hired to look after the site. There are heaps of magpies around but this guy just follows you around, walking behind you and lets you get very close. He has a sore foot at the moment, but can still swoop any vandals. He is also a pretty fat magpie so given his current job, I think I will call him 'Chubb' Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: Barker's Build - Slabbed (with pics) and security guard 75Jun 29, 2012 10:39 am Chubb looks as if he takes his job seriously! Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Barker's Build - Slabbed (with pics) and security guard 76Jun 29, 2012 9:33 pm Don't mess with Chubb, looking forward to how everything goes for you. My land settled today so about 6 weeks before I start. Re: Barker's Build - Slabbed (with pics) and security guard 77Jun 29, 2012 10:01 pm I think you might be calling 'HER' Chubb Re: Barker's Build - Slabbed (with pics) and security guard 78Jun 29, 2012 10:33 pm catjim I think you might be calling 'HER' Chubb What makes you think the bird is a female? Do you think the large size is because the magpie is pregnant? I just figured he was guarding a building site, so he had a good and proper beer gut. Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: Barker's Build - Slabbed (with pics) and security guard 79Jun 29, 2012 10:34 pm dvestate Don't mess with Chubb, looking forward to how everything goes for you. My land settled today so about 6 weeks before I start. Good luck dv. I have a colleague down this way that is also building with Allworth, we keep comparing progress but he is not up to pier holes yet. That's what happens when council approves your house a few days earlier than the other! Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: Barker's Build - Slabbed (with pics) and security guard 80Jun 30, 2012 8:59 am barker catjim I think you might be calling 'HER' Chubb What makes you think the bird is a female? Do you think the large size is because the magpie is pregnant? I just figured he was guarding a building site, so he had a good and proper beer gut. Female magpies have grey feathers on their back whereas males have white. Babies also have grey feathers but an all black beak. Chubb has a lot of white on her beak so I'm guessing an adult female. We fed a pair of magpies and their various offspring for ten years or more at our old house. Somewhere there's a photo of 'Mrs Moo' standing on my knee being fed but I can't find it. Damn! Anyway, here's a few of our photos. Mrs Moo Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ DH & Mr Moo Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Mrs Moo & a baby. Baby on the left with the all black beak. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ If you can get really up close and personal, females have longer eyelashes Yes well there solution is to blame everyone else while I a 65yr old woman with major medical problems have to just continue to boil water and wash myself in a bucket… 2 15984 If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20228 13 6602 |
