Browse Forums Building A New House 1 Dec 09, 2011 11:20 am Hi I am inclined to buy a house in Melbourne which is facing a creek ( no other houses in front) , the house price is marginally low as compare to other similar houses in that suburb , agent says owner wants to sell quickly. I don't have much knowledge about housing different aspects , therefore wondering if there is any pitfalls of buying creek close house may be thats the reason the price is slightly low. most importantly my concern is "from building or construction perspective is there any downside of "creek close" houses " ???? thanks Re: House Near Creek 2Dec 09, 2011 2:44 pm is it a new house? We were looking at an estate in Hampton park, it was near a stormwater run off and near a disused tip, $25k cheaper than other smaller blocks in the area.. The only things i would worry about is the '100 year high' flood level, mozzies and insects from the creek, if its not fast moving, could be stagnant water, where is it located? ___________ Started design Aug 2011 Plans submitted to council Dec 2011 Re: House Near Creek 3Dec 09, 2011 4:15 pm bom.gov.au just released a warning for thunderstorm, it says - “People need to stay clear of any fallen powerlines, and try to avoid driving through any flooded areas,” Mr Feren said. then follows by - “It would also be wise to secure any loose objects near the home and keep away from any creeks and drains.” Our standard double-glazed window is tested to achieve, Rw 34, and can be glazed to suit Rw 39. The price is good too... 3 9433 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7020 How good is Simeon?! Always taking time to help others out! Wish we were building in NSW and could work together. Thanks for all that you do! 7 6550 |
