Browse Forums Building A New House 1 Dec 03, 2011 11:40 pm Hey guys. Desperately need help here. Just signed my building contract 2 weeks ago. Site start due to commence in 2 weeks or so. I was so sure I have asked all the queestions i need to ask until yesterday when i started thinking about driveway. I had another look at the site plan and realised that i don't even know what's the difference (in metres) between the highest point and the lowest point of my land. On the site plan, there is a contour line that runs through the pavement and it is marked 100. Then there is another one towards the back with 101.00 on it. And then there are a few more in between marked 100.2, 100.4, 100.6, and 100.8. I know 101 is the highest point and 100 is the lowest point, but what i really want to know is: how much higher is the back of my land compared to the front, in metres or centimetres? On the site plan, it also states that site would be 'cut and fill' to 106. Garage setback is 5.5m. So that means the highest point of my driveway would be around 100.6 and the lowest point 100. Just how steep is it, going from 100 to 100.6 in the space of 5.5m? I understand that I will be getting a retaining wall in my backyard as well as a result of 'cut and fill'. How tall would my retaining wall be, considering the highest point on my land is 101 and my house will be sitting on 100.6? Any help would be much appreciated. Raph Re: Site plan - highest point - lowest point 2Dec 04, 2011 5:17 am Height difference lowest point to highest point = 1 metre (100cm) Height difference (fall) from garage to road 0.6m (60cm) so its approx 1 in 9 Assuming you rear garden is flat the retaining wall should be 0.4m (40cm) The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Site plan - highest point - lowest point 3Dec 04, 2011 5:34 am Sounds like the height difference in your land from front to back is 1 meter (101.0-100.0). If they do cut ad fill to 100.6 it will mean you will require max retaining walls of 60 cm at where was you lowest point (100.0) and 40cm at where was your highest point (101.0). Re the driveway if your driveway starts at the 100.0 point and goes to the cut and fill level it means you will have a slope across going up 60 cm across your 5.5 meters (approx 11cm per metre) which doesn't sound too steep Re: Site plan - highest point - lowest point 4Dec 04, 2011 4:47 pm mr.21 Hey guys. I understand that I will be getting a retaining wall in my backyard as well as a result of 'cut and fill'. How tall would my retaining wall be, considering the highest point on my land is 101 and my house will be sitting on 100.6? Any help would be much appreciated. Raph how far is your built-in area from the boundary fence at the back. rathar than having a retaining wall at the back, can you not have that slop? Re: Site plan - highest point - lowest point 5Dec 04, 2011 10:27 pm Thanks guys for all your help and explanation. Taking into account approx. 250mm of slab, i guess i will have fairly steep driveway. CC101 mr.21 Hey guys. I understand that I will be getting a retaining wall in my backyard as well as a result of 'cut and fill'. How tall would my retaining wall be, considering the highest point on my land is 101 and my house will be sitting on 100.6? Any help would be much appreciated. Raph how far is your built-in area from the boundary fence at the back. rathar than having a retaining wall at the back, can you not have that slop? CC101, i am not sure having a slope in the backyard would be a good idea. Kind of making it unuseable in my personal opinion. distance between back of my house and the boundary fence is 5.85m. At the moment, the builder is going to put a 400mm retaining wall between back of my house and the boundary fence. I am not sure if this is a good idea? I prefer a flat backyard. But my main concern is, given that we have 1m fall in my land and we are going for 'cut and fill', are we going to have drainage problems in the future? Re: Site plan - highest point - lowest point 6Dec 04, 2011 11:23 pm i am having similar problems as well. my back side is 12.09, front 10.5, at road level 10.08, slab level 11.315 and floor level 11.400. distance from back of house to back fence is 6.3 meters and driveway is 7.2 meter. i got crossover over 5 meters as well. builder is not building any retaining wall at the back. so i have to look at few options now. Building Standards; Getting It Right! Hi All, We have a fall from road to garage front. But we cannot put a drain/grate because no discharge point put by the builder. Now they complain not enough space for… 0 9315 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6645 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17453 |
