here's some pictures so you know what I mean:
So what's with the random bits of plywood?
more specifically plywood is used for wind bracing
“Buildings are vulnerable to wind damage at all stages of their life cycle. They are particularly vulnerable during the construction phase, especially if roofed with terra cotta or concrete tiles prior to the installation of wall linings or cladding, which is common practice. The installation of plywood bracing, prior to roofing, protects the building during this vulnerable period. It also protects the finished structure from damage from wind during its design lifetime of over 50 years.
Plywood bracing provides an engineered solution using thin structural plywood panels nailed to the timber frame, providing structural shear walls which resist the horizontal racking loads applied to the building by the wind. The plywood panels can be used also to provide resistance to wind uplift by connecting the roof to the subfloor.”
source:http://oak.arch.utas.edu.au/tbia/view_article.asp?articleID=52
I have a box of quality drill bits that seem to be new but their engraved sizes covered by rust ,,,,I tried to sand them to see their sizes but still I am finding…
7/10/2023
1
Jimbo73 I would use heaps of adhesive on each sheet and screw rather than nail. use as many as you like cheers Simeon
