Browse Forums Building A New House 1 Nov 03, 2011 5:29 pm We are due to settle on our block of land tomorrow. Our builder has advised us that there is a discrepancy of 1m of fall between the engineering plans and the actual site survey. Engineering plans say 2.5 metre fall and the site survey is 3.5 metre fall. Our site costs have been estimated at $60K Our conveyancer sent a letter to them advising of the problem and the developers basically said "too bad", that the engineering plans are only a guide. This will cost us an extra $35K in fill and retaining walls. Do we have any recourse? Should I stop settlement? Re: HELP!! Discrepancy in site fall - Settlement is TOMORROW 2Nov 03, 2011 5:47 pm Plonk, That is terrible news, so frustrating. I'm sure you could pull out, but you would lose your full deposit, so you would have to decide if you are prepared to do that. I think unless you have a clause in the contract stating something along the lines of discrepency then your stuck. I know we had a clause around the actual size, unless there was more than 5% discrepency in sqm we were stuck with what the finished product was. Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4671 I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy… 0 18374 I am not sure whether Perth has its own way of doing things in regards to this. Most of Perth has class A (sandy soil), except for some areas near rivers or hills. 2 13053 |
