Browse Forums Building A New House Re: When to install ceiling fans during building? 2Oct 28, 2011 4:21 pm Hi babysaurs, I think it depends on the builder. Some builders charge a lot for the fans themselves, or they do not offer a wide selection. I am just getting provisions for ceiling fans put in by my builder so a batten light with nogging to support the fan, and we will purchase our fans from somewhere else afterwards and have them put in. Labour-wise was not a worry for cost, but our builder was charging around $400ish for a fan, and we didn't really like the fan they were offering anyway. If you're going with a smaller builder you may be able to provide your own fans and have them install it, I'm sure that would be cheaper. Re: When to install ceiling fans during building? 3Oct 28, 2011 4:47 pm We bought our bedroom fan and installed it later. Our friend did it, he is an electrician, so it was his gift to us. You would be better off buying your own fans, as the builder won't supply the best quality ones. You could buy them and ask the builder or electrician, to install them like Wateman said. 400ish for a fan sounds alot, the builder would buy the cheaper fans in bulk. Venn, For small pendants you can get some plasterboard anchors, that hold up to 10kg which should be sufficient, but for larger items I would cut a hole add timber and… 6 6610 Can you give advice on how to get missing certificates needed for a form 21? Our bank requires us to provide one but we are missing 4 building certificates from our first… 3 51072 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 71592 |
