If a garage wall is already located on the boundary line, is it technical possible to have a fence builds up on the boundary line too?
The garage wall and adjoining fence is overlapped about 8m in length.
Thanks all
Browse Forums Building A New House Re: A technical problem needs answer 2Oct 26, 2011 1:48 pm usually you can just remove the fence and you the garage wall as your new fence. Sometimes the garage maybe 100mm inside the boundary so you have still have a fence. Usually the garage is 100mm if the just use normal guttering on top (which sticks out). 2 5845 I don’t think so as the floor area over 300 square meters then it is class 3…. 12 17936 |
