Browse Forums Building A New House 1 Oct 22, 2011 6:49 pm A member of the family is a retired builder. He has a good eye, understands how to build a quality house and can pick up faults. However, he does not know the current regulations anymore. Do independent building inspections need to refer to building regulations for the builder to acknowledge the fault and fix it? Thanks Chris Knockdown and rebuild - Metr1con Nolan 45 Plantation Our Build Blog @ http://ournolan.wordpress.com Our Build Thread @ viewtopic.php?f=31&t=52812 Re: Building inspections - do you need to quote building reg 2Aug 28, 2012 8:14 am no a fault is a fault. builder should see that but it sometimes helps because builders dont always know. e.g. meter box exposed to weather should now be flashed not sealed (old way) according to bca. not all builders know so they wont accept a view without the quote to regs. leighton at clark new homes You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18064 hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20909 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14314 |
