Browse Forums Building A New House 1 Oct 09, 2011 6:59 pm what's the ideal height for a garage suitable for 4X4's or Hatchbacks? we already have ours at 28C. Thanks Prelim Contract to Build - 31/07/2011 Building contract and Plans - 21 Sept 2011 Pre-start - 13 Oct 2011 Settlement - 14 Oct 2011 Earthworks - 5 Dec 2011 SLABBED - 13 Dec 2011 Roof Framed -7 Mar12 Re: garage height for 4X4 or hatchbacks? 3Oct 10, 2011 11:26 am To get teh tail gate all teh way open on a hatch back you will be fine with 2400mm high ceiling in Garage, 2550 maybe rewuired for some random higher riding ones (Nissan Dualis) but most will be OK. For a 4x4 it really depends on the car itself. Is it modified? If so by the time you add a roof rack and bigger tyres you probably won't fit through the door let alone open the tailgate. We have 9ft (2700mm) ceiling in our house and so does the garage, but we made the door openings 2400(minus a little for the plate on the bottom of the door) So we should finish with a 2300ish door opening. You should get most 4x4 through that don't have bigger tyres+ more than 2 inch lift in there. Your biggest problem will probably be depth. By the time you park, add space at front to walk around it, space at rear to open tail gate and walk around, you really need 7m of depth to comfortably get around a 4x4 (Patrol/LandCruiser/RangeRover) in a garage. We added an extra foot of width, but I wanted to make it 7w x 7 deep, just ran out of room on the block to keep other rooms of good size. If you have the room go for a min of 7m wide x 7m deep for a double garage. Adding ceiling height in the house SHOULD also raise garage height. Get the max possible door opening you can. Re: garage height for 4X4 or hatchbacks? 4Oct 11, 2011 9:44 am If you can, extend the depth of the garage. We had the standard size, didn't think much of it. My partner has a commodore size car (maybe a fraction longer) and it JUST squeezes in. There is less than a hand length between his car and the wall and his car and the garage door. There is enough room width way but it could do with some more room to get in and out more easier. I would have extended it a metre if i knew about it then. Never thought of measuring it as i have a small car! Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10658 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7731 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9551 |
