Browse Forums Building A New House 1 Oct 03, 2011 2:45 pm Hi All, Building a new house, the kitchen glass splash-back has been installed and we have a PCI coming up very soon. The splash-back is meant to be 650mm high, but after having a look at the installed splash-back, it is at-least 4-5mm short at the bottom and has been filled with sealant/glue( 4-5 mm thick glue). The splash-back is 10mm short horizontally. Does anyone know what the standard and tolerances are with regards to the size of splash-backs. Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 15303 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7005 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5152 |
