Browse Forums Building A New House 1 Sep 18, 2011 3:14 pm We are building a new house. The contract has 40mm ceaser stone to kitchen bench and to the servery/benchtop included. We casually measured the thickness of the ceaser stone for both kitchen bench and the servery benchtop. The edge is 40mm in thickness right across the perimeter, but right across the entire inside area it is 20mm only. Is it meant to be like this, 20mm right across and only 40mm at the edges???? Re: Ceaser stone thickness ??? 2Sep 18, 2011 3:56 pm Yep this is correct - Casesarstone doesn't come in thickness of 40mm - only 20mm and some colours are 30mm. We have the same as you - 20mm thickness with the 40mm edge. Hope this helps! Sleven Moved into our Atlantique MkII 36 by Carlisle Homes Re: Ceaser stone thickness ??? 4Sep 18, 2011 4:36 pm b0son so what makes up the other 20mm? i thought the 40mm benchtops are a laminate of 2x20mm? You can get a faux 40mm look by having an extra 20mm piece laminated onto the edge around your island cabinet or at the front of your wall-hung under-bench cabinets. It is also possible to have two 20mm slabs laminated (glued) together, but aside from that the info posted is correct - caesarstone mostly comes in a 20mm thickness with a few colours in the classico range coming in a 30 mm thickness as well. Some people apparently have nothing better to do than comment on other people's sigs. Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5644 |
