Browse Forums Building A New House 1 Feb 01, 2008 9:34 am Hi Guys,
I would like to know, does custom builder build cheaper home then other well known builder after considering all inclusion like carpet, tiles and all other requires for complete home? If anyone knows any good custom builder building at reasonable price please let me know. Thanks guys. Regards, Chirag Re: Does custom builder build cheaper home ? 2Feb 01, 2008 9:46 am I think generally a custom builder is more $$ per square metre than a "project" builder. That's my experience.
I also think generally a custom builder will build a higher quality house. Generally:) Specific builders may be better or worse quality and or price than another. Re: Does custom builder build cheaper home ? 3Feb 01, 2008 9:53 am I'd say definately not. Custom builders are much more likely to be dearer than a project home builder.
If you have a custom design and get it quoted by a project home builder or an custom home builder and if your lucky enough to have the project home builder not show you the door you'll probably find that they will still be a bit cheaper depending on who they are. Project home builders generally only like to build their own designs because that what they are set up for. Generally you will also get a better job and better finishes from a custome home builder. They tend to cater for the section of the market that is above (read more $$) a project home builders. Project home builders, on average range from about $500-$750 per square metre where as a custom home builder would be well above the $1000 per square metre and probably averaging $1500-$1700 p s/m. Re: Does custom builder build cheaper home ? 4Feb 01, 2008 2:48 pm Certainly dearer per sqm for us to go custom, but we also got to set the size of rooms, layout etc to match how we wanted to live rather than just picking the most suitable plan.
It's a big gamble, cause we dropped about 15sqm in total floor area to go custom for the same money (at the same specification/inclusions level), but I think we made the right choice for us. Re: Does custom builder build cheaper home ? 5Feb 01, 2008 7:18 pm Build it yourself ... only way to get decent quality and exactly what you want!
Better still, buy an existing house, and then at least you can SEE what you are getting. Sorry, I am completely over building today! Re: Does custom builder build cheaper home ? 6Feb 01, 2008 7:37 pm ![]() Build it yourself ... only way to get decent quality and exactly what you want! Better still, buy an existing house, and then at least you can SEE what you are getting. Sorry, I am completely over building today! ![]() ![]() ![]() Love it….after I just read your other post Lyn!!! I prefer custom builders, then you don't get as many cranky clients like Lyn here, who has just had a very bad day with her PROJECT builder! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Does custom builder build cheaper home ? 7Feb 02, 2008 10:58 pm I personally think it depends on what you mean by custom build. We are having our home custom built by a small firm - from a standard plan with LOTS of changes made - to the extent it's almost a completely different house. Ergo - custom built home.
If you mean commissioning a builder or architect to specifically design based on nothing but your wants/desires in a house - then it's probably going to cost you more per sqm than via a nationally-known company. Personalised service and all that, yada, yada.... In our case, going through a small but reputable building firm has been a compromise, and we've found the costs compare very well with all the same 'extras' - down to carpet, tiles, window treatments, etc. - that we would have gotten from the national companies. Fiona Re: Does custom builder build cheaper home ? 8Feb 03, 2008 1:54 am Similarly to Fiona we have a custom designed house with a small builder and used one of his existing designs. We modified this until it was nothing like the original. He was happy to do this but he is unusually patient & easygoing. It has taken us close to 10 months to get the plan right and lay the slab.
We had quotes from project builders but at the end of the day it was very difficult trying to compare apples with apples. Unless you are in the trade and research every selection and specification you would find it difficult to compare i.e. airconditioners, type of foundation, reo, wall thickness etc. Each builder has their own preferred supplier and there are lots of hidden costs. We ended up going with our builder because his specification was higher ... and we liked the look of the houses he builds + he seemed open about his additional costs and inclusions. If you can find a project builder who has a spec and home you like then go with that. Otherwise you are taking a small risk (as we are) by building a custom home that you haven't seen. It is critical to trust your builder and have good communication if you are building a custom design. In our experience project builders were cheaper for the base product until you started playing with the design and spec. Re: Does custom builder build cheaper home ? 9Feb 03, 2008 7:31 am We had our house designed to our needs from scratch and we are having a master builder project manage the construction..so I guess it is custom. It will be more expensive, but cheaper/ or the same as getting a project home builder to build from our custom plan.
We are able to make modifications along the way and organise certain things ourselves to reduce the cost a little. We haven't started building yet and it will be 18 months or so from initial design to completion, so might take longer than project homes as well. Re: Does custom builder build cheaper home ? 10Feb 03, 2008 10:13 am Oh! - I should add that smaller building companies often offer things as standard that bigger firms might not. Our chap includes three coats of paint, all carpets and tiles throughout, flyscreens and window treatments, 4.0/2.5 Batts....etc.
He also gave us eight-point evaporative cooling for $2000 two months after this deal was over because we had first contacted him prior to the end of the sale. I think there's more flexibility with smaller firms - whether it costs you more or less depends on the builder. Fiona Re: Does custom builder build cheaper home ? 11Feb 03, 2008 10:46 am DeeElle,
Totally off topic, but I'll be brief. Where did you get your avatar from? It's absolutely beautiful and would look great for wall pictures. Cheers, Casa Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Does custom builder build cheaper home ? 12Feb 03, 2008 12:26 pm ![]() DeeElle, Totally off topic, but I'll be brief. Where did you get your avatar from? It's absolutely beautiful and would look great for wall pictures. Cheers, Casa Hi Casa I agree the colours and imagery is beautiful. The artist is Camilo Villanueva. We have sent an enquiry re: purchasng some artwork. Let me know how you go if you follow up. http://www.camilovillanueva.com.ar/engl ... works.html Cheers I've heard good things about Ridgewater Homes and Omnia, but you might want to also check out XYZ Builders. They did an awesome job on a friend's place in a similar situation 6 7270 ![]() Hi, can anyone recommend a custom home builder who can build in north east area? Looking to build a custom 4-br energy-efficient home with a max budget of 750k. If they… 0 1137 Sorry but you have a crap builder. Probably too late now. For our last build I only spoke to builders who would allow me easy access (at no cost). I used my own sparky… 10 3071 |
