Browse Forums Building A New House Building a Sunnydale with Clarendon - build it up, build it 42Sep 18, 2011 8:13 am The frame started going up on Thursday, not much action on Friday (just some more deliveries, building the frame made some room for this!) The kitchen window and where the bench will be! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The alfresco looking into the study straight and meals to the left. Note, there is a small overhang of the frame in this area. Must speak with the SS about that. I know that tolerances allow for 10mm overhang....must get that checked. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The family room Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Entrance hall, garage to the left, powder room in front and laundry to the right Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon - build it up, build 43Sep 18, 2011 11:10 am looking good, katman. Yeah, definitely speak with your SS. Also, check the frames around the house where the frame meets the slab. i didnt and got bitten by the frame around the garage and entrance. 70mm overhang. makes me wonder whether the crew installing the frame use any brains at all. if they saw the overhang, they should have alerted the SS instead of just getting the frame in. Good Luck !! Re: Building a Sunnydale with Clarendon 44Sep 18, 2011 8:06 pm For all those building with Clarendon, how do you get on site to take photos / investigate what is being built? Do you meet with the SS at certain times, or have they given you the code for the security fence? I am keen to find out what is happening out there... Building a Sunnydale with Clarendon - week 4 summary 46Sep 21, 2011 9:30 pm So the frame is going up....well not much more that last I wrote, but it is the exciting thing for this week! The 'rust' spots were some mud or little bits of not very much to worry about (having extra people come in and inspect), so that is all good. The SS tells me that that overhang can be at least 20mm before engineering has to get involved and have created some concrete fill.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Not 100% sure of the purpose of it all...will find out. Other things worth considering (not that much can be done sometimes with volume builders, nor might it make much difference to the house as a whole)... There doesn't seem to be a standard width between studs and some are even 600mm apart (which must be OK)! Ideally, it would be nice if the noggings, at about 1300mm high, were flush with the studs to help with the protection of the plaster joins. Neither changes the structural integrity and there are a few blogs out there discussing the relative merits of both arguments. Who knew when you just want a to build a house! My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon 47Sep 21, 2011 11:12 pm katman, seems the 'overhang' is an issue with the frames which come 'pre-framed'. The people laying the slab have to be 100% accurate to get those 'pre-framed' frames in place. same goes the other way. I might try raising this as an issue with our builder, not going to help me, but something which they need to attend. They fixed my frames the same way they have done yours. I confirmed with my independent inspector and this seems to be an acceptable fix. So all good there. Like you said, we are learning as and how we come across things and will be a valuable lesson for our future builds Good luck. Keep those pics coming. Building a Sunnydale with Clarendon 48Sep 25, 2011 10:02 am So here is one way to get in good with the SS..... Rock up at 5 o'clock on a Friday afternoon, just to have a look, and find, to your great surprise, that the SS also happens to be there..... What happened?....the framer had called him early in the afternoon to find out that 3 of the joists were a bit short, so 6 phone calls later (you know how manufacturing can be on a Friday afternoon!), he had the joists made and was on site to deliver them himself, otherwise, it may have been until Wednesday next week that the framers could continue their work! So being the fellow that I am, I help the SS carry the joists onto the site myself (they really would have been too heavy - although do-able for one person, but really not practical!). Then have a good wonder around and a nice chat for about 30 minutes. Not bad for a Friday afternoon! Now for some update photos from the past few days: They have been doing the beams: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And some joists: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Still a little concerned about the overhang....what has happened is that a corner stud has been replaced with a steel beam and bolted to the concrete. When doing that, the framers must have chipped a bit of the the concrete grout filler (at its worst there is a 15mm overhang). SS said it should be fine and yet to be inspected, so not to worry. There is still time to fix it! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Building a Sunnydale with Clarendon 49Sep 28, 2011 9:16 am Upstairs floor boards done! Upstairs frame should be delivered today! My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Building a Sunnydale with Clarendon - week 5 summary 51Sep 28, 2011 12:54 pm The upstairs frame is up! Busy week on site.... Beams and joists have been fitted and, I can say I personally contributed to the labour of the house, by carrying in some joists. The upstairs floor and frame has been done, almost. The framer still had to plumb and brace the frame, but I think the rain beat him to the punch today Had a good chat with the framer and he is going to install some extra noggings for TV, towel rails and toilet roll holders. Love the beer economy! Looking good..... From the front Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ From the back Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon 53Sep 28, 2011 2:35 pm In Melbourne. My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon 54Sep 29, 2011 4:35 pm ope126 Katman, where are you building? State? etc... Where are you building? What style of house are you building? Where are you at with it? My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon 55Sep 29, 2011 4:45 pm katman ope126 Katman, where are you building? State? etc... Where are you building? What style of house are you building? Where are you at with it? We are in Brisbane QLD. Single story, Kentville 28 (upsized to a 30). This is a NSW plan, but we got approval to use in QLD. Site start 01/09. Today we have frames, roof next week (colourbond). Was advised that Roof, Electrical, Bricks and Gyprock should all be complete by end of October... Will keep you up to date. Building a Sunnydale with Clarendon 56Sep 30, 2011 3:51 pm The trusses have arrived, some have been craned onto the roof and ready to be fitted....(just waiting on some scaffold platforms). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Some of the upstairs frame Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The master robe and en-suite Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon 57Oct 03, 2011 2:48 pm Family room trusses, windows and sliding doors are done! The platform for the upstairs trusses are also installed. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Recieved the account for the frame today as well (dated last Friday).....rang the company, informed them the frame wasn't actually finished on Friday and I haven't seen the building surveyer report (as per contract...frame complete and approved by a building surveyer!). Apparently a common issue. They will sort it out!. My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Building a Sunnydale with Clarendon 58Oct 04, 2011 7:09 pm OK...so got a call today...frame should have been completed this afternoon and building surveyor coming to inspect Thursday next week....so that is when the frame is complete! The fascia gutter seems to have been installed on the upstairs eaves... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The bath frame is also installed! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Building a Sunnydale with Clarendon - week 6 summary 59Oct 05, 2011 10:14 pm 6 weeks after the start of the build and the frame is done, the trusses are up, fascias and gutters attached. A little delayed due to rain (but we all need the rain!), and the site has had its first clean, with a bit of soil and stones spread to the up slope to the garage and porch (doesn't look too bad!). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bring on the bricks! My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon 60Oct 07, 2011 2:59 pm Tiles and battens have been delivered! Choc-Royale, with shake profile Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And the ridge tiles Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 It is Genneral stairs, but they won't deal with anyone off the street. They will only work with clients of project home builders. I tried to but some of these exact… 3 8049 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 8388 I do enjoy the drama:-D In his latest two videos he has started bringing security guards to site, I am waiting for the punch on to begin lol 6 46355 |
