Browse Forums Building A New House Re: HIA building contract 2Aug 03, 2011 6:27 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: HIA building contract 10Aug 04, 2011 10:49 pm If on the plans and it has been signed off and accepted by you. Then that is what must be built unless you agree otherwise in writing and sign of on an amendment. If they made a mistake and added "extra's" in and didnt charge you then that is their bad luck. I had many errors on my plans which I found most prior to construction but some crept through. The ones that did creep through, for example a shower head 50mm off centre due to a typo on the plans. In the builders words "You signed off on those plans so any variations to that will cost you $x to change them" So the same works in reverse. If they stuffed it up and over specc'd somethign bad luck to the builder. They should take better care next time. If it was me I would stand my ground. Who is to say what was and wastn agreed to be in the plans at sale time. The only thing you have to rely upon is the plans as dran and your contract. . So basically if it is there in black and white, then it is included and you have every right to expect it https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow You talk about deletions, are they variations or PS and PC adjustments? pleas list them 1 12043 10 9787 Unless there is something in special conditions the builder does not have to give you timeline. If your demolition contractor has not removed Asbestos and it was found… 12 22639 |
