Browse Forums Building A New House Re: Building the Monaco By Dechellis / SA / Frame started 121Nov 15, 2011 9:12 pm Yey Frame started this 1pm not too bad for 2 hours work Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Built the Monaco By Dechellis / SA https://forum.homeone.com.au/viewtopic.php?f=31&t=49855 Slab: 07/11/2011 Handover: 23/04/2012 Re: Building the Monaco By Dechellis / SA / Slabbed 122Nov 16, 2011 6:15 pm More frames Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ window and door frames Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Built the Monaco By Dechellis / SA https://forum.homeone.com.au/viewtopic.php?f=31&t=49855 Slab: 07/11/2011 Handover: 23/04/2012 Re: Building the Monaco By Dechellis / SA / Slabbed 123Nov 17, 2011 8:18 am Have you had a walk through and worked out where everything is? Can't wait to see the frame finished and windows in - then it's starts to get really exciting!! For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Building the Monaco By Dechellis / SA / Slabbed 124Nov 17, 2011 9:44 am Yes Annette so far everything is in the right place you can visualize where everything is now...we modified the back a bit instead of putting a slide door we put 2 windows with a feature wall in the middle and outside that wall that's where the aircon will sit because there is no point of putting another door as no more space at the back hopefully its not too dark by not putting a sliding door there Built the Monaco By Dechellis / SA https://forum.homeone.com.au/viewtopic.php?f=31&t=49855 Slab: 07/11/2011 Handover: 23/04/2012 Re: Building the Monaco By Dechellis / SA / Frames 125Nov 17, 2011 8:10 pm Ooooh a frame! Very exciting to see all your plans taking shape! Cassie 28/7/11 - Slabbed 15/8/11 - Framed 19/9/11 - LOCKED UP! 6/10/11 - Kitchen in! 11/11/11 - It's all OURS! Pg 12 Follow our build: The Noodle Family - Preston in the Hills Re: Building the Monaco By Dechellis / SA / Frames 126Nov 18, 2011 12:57 am Windows and front door frame are up Front door home theater and main bedroom Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Family room Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ dining/ kitchen Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Built the Monaco By Dechellis / SA https://forum.homeone.com.au/viewtopic.php?f=31&t=49855 Slab: 07/11/2011 Handover: 23/04/2012 Re: Building the Monaco By Dechellis / SA / Frames 127Nov 18, 2011 9:52 am It's slowly taking shape ... like your windows at the back of the house they are a bit different For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Building the Monaco By Dechellis / SA / Frames 128Nov 18, 2011 11:54 am that's the part we modified from the original plan supposed to be sliding door there... but we decided to put a feature wall there so you can watch tv when you are in the kitchen our floorplan Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Built the Monaco By Dechellis / SA https://forum.homeone.com.au/viewtopic.php?f=31&t=49855 Slab: 07/11/2011 Handover: 23/04/2012 Re: Building the Monaco By Dechellis / SA / Frames 129Nov 19, 2011 1:15 pm Wow, seems like it's moving along quickly Re: Building the Monaco By Dechellis / SA / Frames 130Nov 19, 2011 1:23 pm Trusses are up Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ skip starting to be filled up by neighbours rubbish there is bbq box inside Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Built the Monaco By Dechellis / SA https://forum.homeone.com.au/viewtopic.php?f=31&t=49855 Slab: 07/11/2011 Handover: 23/04/2012 Re: Building the Monaco By Dechellis / SA / Frames 131Nov 19, 2011 1:29 pm Hi WO yes we are surprised everyday with the quick progress although they dont work weekends we went past this morning and had the chance to look around and check again if everything is in the right place Built the Monaco By Dechellis / SA https://forum.homeone.com.au/viewtopic.php?f=31&t=49855 Slab: 07/11/2011 Handover: 23/04/2012 Re: Building the Monaco By Dechellis / SA / Trusses are up 132Nov 20, 2011 10:07 am looking nice Now that you have a better idea of where the house is, do you think the tree will still have to be moved? https://forum.homeone.com.au/viewtopic.php?f=31&t=43937&start=0 Bought a block in Golden Grove - Jan 2011 Finally finished our design, Mar 2012, *yay* Signed with ADH council consent June 12 Re: Building the Monaco By Dechellis / SA / Trusses are up 133Nov 20, 2011 11:50 am DCT we filed an application for tree removal and send a photo of the tree that is just infront of our garage to the council but dont know when will they reply. If they dont allow us to move or cut the tree we just live to it by having a funny s-shaped driveway Built the Monaco By Dechellis / SA https://forum.homeone.com.au/viewtopic.php?f=31&t=49855 Slab: 07/11/2011 Handover: 23/04/2012 Re: Building the Monaco By Dechellis / SA / Trusses are up 134Nov 21, 2011 10:28 am Oh it's so nice when you can see the roof line isn't it? Great progress .... For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Building the Monaco By Dechellis / SA / Frame almost fin 135Nov 28, 2011 8:45 pm Not much visible updates... i saw a guy puttting something maybe termimesh or salt damp proof along the edge of the frames this morning and i've seen also a dechellis ute leaving when i got there wondering if that's the SS or building inspector? checking if we can be billed with frame stage too http://i1215.photobucket.com/albums/cc508/JamieandGhie/DSC_0071.jpg kitchen bulkhead http://i1215.photobucket.com/albums/cc508/JamieandGhie/DSC_0073.jpg frames almost complete http://i1215.photobucket.com/albums/cc508/JamieandGhie/DSC_0074.jpg sliding door is in south side of house Built the Monaco By Dechellis / SA https://forum.homeone.com.au/viewtopic.php?f=31&t=49855 Slab: 07/11/2011 Handover: 23/04/2012 Re: Building the Monaco By Dechellis / SA / Trusses are up 136Nov 28, 2011 9:25 pm Sounds like the SS in the ute .. Pictures of frames are lovely aren't they ... You won't see them ever again once they're covered up so make the most of them .. For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Building the Monaco By Dechellis / SA / ROOFING Started 137Dec 02, 2011 6:01 pm Roofs Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Built the Monaco By Dechellis / SA https://forum.homeone.com.au/viewtopic.php?f=31&t=49855 Slab: 07/11/2011 Handover: 23/04/2012 Re: Building the Monaco By Dechellis / SA / ROOFING Started 139Dec 05, 2011 10:28 am It's looking bigger by the day ...... For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Building the Monaco By Dechellis / SA / ROOFING Started 140Dec 06, 2011 8:18 pm Roofs almost finished Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ looks like they will start the bricks tomorrow Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Built the Monaco By Dechellis / SA https://forum.homeone.com.au/viewtopic.php?f=31&t=49855 Slab: 07/11/2011 Handover: 23/04/2012 8 6156 5 6823 Hmmm, I have checked your past posts and it seems that you are in NSW, not WA as I had thought. It pays to show your State in your avatar. Retaining wall regulations… 5 7866 |
