*Anyone have an upgrade cost for LED downlights and whether the provided downlights are still only 4.5w? I'm thinking of asking PD to only rough in the downlights but am concerned that post handover when the electrician drills into the ceiling that there will be a beam in the way!
*I understand that PD uses Wattyl paint, anyone have an upgrade cost and whether they were able to change it to something else e.g. Dulux?
Thanks!
I wouldnt get porter davis to do your downlights, from memory its about 150 for a normal down light not a LED and around the 200 mark for LED, we are building the waldorf so downstairs we got all battans and they cost $65.00 each and we got our own LED lights and once we get them installed it still will be alot cheaper then they quoted!!
hope that helps
We did the same! I just found that when you added them all up there is such a lot. It will be a pain having to change them all over but probably about $50 per light less in the long run.
I was at Tender today and asked about changing paint suppliers. Answer was that can't change suppliers from Wattyl due to contractual reasons. My understanding is that they use Dulux on the exterior if this helps you out.
