Roshi, ask your rep! Mine has a big circle on the side with a tile & that says tile!!
Mel
Browse Forums Building A New House Re: Porter Davis homes 2081Jun 04, 2011 12:58 am Roshi Karmaz, as according to my memory you have mentioned in this thread that you did not get the contract drawing for the balcony right? I have looked at my documentation & just found the drawing of the Balcony. I have selected the same facade as yours, which is Ashmont. By the way by just looking at it I have no idea how to find out whether it will lead to a leaky porch or not. Roshi, ask your rep! Mine has a big circle on the side with a tile & that says tile!! Mel Re: Porter Davis homes 2082Jun 05, 2011 12:56 am Mel - you got lucky. IMHO, PD might have fixed the design flaw later on, but seems to not want to fix the error with those who signed up earlier. Roshi, if you pm me with your email add, i can send you what ours looks like. At first glance, it looks like there is brick underneath as well as sufficient drainage, but apparently that is not the case. Shuffling through paperwork now. Humble, I will get to those pictures today/tomorrow. Been a bit busy. Now: Building another new home Settlement: 8 July 2021 Construction due to start: In two months Re: Porter Davis homes 2084Jun 05, 2011 2:02 pm Mine are in the cupboard under the trough, with a hole drilled through the side of the cabinet for the hoses. Can't see them but it's easy access so you don't have to move the washing machine to get to them. We have the bench extending the whole way across with a front loader under the bench, so we couldn't have had them up high anyway. But even if we had a top loader, I think I still would have hidden them. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Porter Davis homes 2085Jun 05, 2011 6:47 pm FINISHED GROUND LEVEL AROUND YOUR HOME ? Hello All, May I ask what was the approximate height of the finished ground level after your home had been built? I ask, as on three sides of our home (Front and 2 sides) the ground level is approximately at the same level as the underside of our slab. Consequently, on these 3 sides we can clearly see the full thickness of the exposed slab. In addition, in one area over a length of 2m the ground level is actually around 50-100mm below the underside of the slab!!! Is this normal, or has PD removed too much soil during the site excavation stages of our build?? Many Thanks in advance, Chorlton TIMING OF BUILD 25Feb - Site Start 25Mar - Base Stage Complete 31Mar - Frame Completed 11Apr - Roof Tiles 20Apr - Brickwork Started Re: Porter Davis homes 2087Jun 05, 2011 9:09 pm Chorlton FINISHED GROUND LEVEL AROUND YOUR HOME ? Hello All, May I ask what was the approximate height of the finished ground level after your home had been built? I ask, as on three sides of our home (Front and 2 sides) the ground level is approximately at the same level as the underside of our slab. Consequently, on these 3 sides we can clearly see the full thickness of the exposed slab. In addition, in one area over a length of 2m the ground level is actually around 50-100mm below the underside of the slab!!! Is this normal, or has PD removed too much soil during the site excavation stages of our build?? Many Thanks in advance, Chorlton Chorlton, when they did your site scrape have they moved the soil back?? If they have I would bring it up with your SS. Before they handed over our house they poured crushed rock around the perimeter to stop water from getting into our foundations Re: Porter Davis homes 2088Jun 05, 2011 10:06 pm Jewelbaby I agree with everything you said Snoofie, I just wish I could say the same things in terms of having a positive experience. In all this we have been painted as some kind of freaks who expect our home to be entirely pristine, without so much as a fiber of carpet out of place, when nothing could be further from the truth! Our SS actually made the comment that perhaps we ought to go and buy a house in Toorak if we expected such good quality I don't care about the small things, like the fact that we have different coloured mortar in places, but I do care about things like the fact that our walls look and feel like they glued sandpaper down prior to painting and that the paint itself is bubbling away in many places due to extensive water damage because the roof leaks in the whole front end of the house! I know your post wasn't meant as a rebuff to those of us who have had a less than stellar experience thus far and I can absolutely appreciate that credit ought to be given where it is due, but the less rational side of me does feel a bit of a sting when I read posts like yours. I can assure you we've done all the right things, we have been extremely patient given the problems we have had, we have compromised over things we should not have had to compromise over, paid for things we should not have had to pay for and through it all I've contained myself immensely in the few posts I've made on the forums here, if I allowed myself to rant about it and really said it all it would be a wall of text that went on for multiple pages All that aside, we had a meeting with whom I think is the manager for Lifestyle East today. As it turns out it wasn't an official PCI, we will still have to go and do another one in a couple of weeks I think, sign the paperwork and then wait at least another week for handover. I'm not fussed by that, I just want them to get the job done properly and if that means taking a month instead of a week, for example, then so be it. The manager seemed very nice and reasonable, I was a bit reserved at first as the first thing he did was start a spiel about how things that our independent inspector said should be fixed were usually just him being overly fussy and not really necessities. We ran out of time to really go over the paintwork, one of my main areas of concern, because of the fading light and he said he would return and give it a thorough inspection himself on Thursday. I would have been dubious about this, but when he clarified that we would still do another PCI prior to handover it didn't seem to be an issue. He seemed to have a much better attitude to the job than some others we have dealt with, as though he took pride in the job done even though it wasn't his home. I was very pleased that he himself marked the visible plaster joins in the walls to be fixed in some areas because I'm not happy with them but hadn't made a fuss over it because I didn't think it was something they would fix. I really hope it's at least relatively smooth sailing from here on in. Well, I'm disappointed (but not terribly surprised) to report that things have not improved in the slightest. On Tuesday it will have been two weeks since our second "PCI" (and FIVE weeks since our first) and once again we have not sen or heard hide nor hair of anyone resembling a PD employee. We visited our build today to see that the only noticable thing that has been done in all of that time is that a new mirror has been put up in our bathroom (and the wall has been damaged in the process). All of the markers we put up during the second PCI almost two weeks ago are still there, showing that none of the work has been carried out. Once again our SS has not answered or returned calls, with the exception of the eleventh hour message he left my OH on Friday to say that he was finishing up for the day and as such we would not be able to contact him and that he would contact us on Monday about how the house was going. Among other things we will be asking our CSC what the process is to make a claim for late building works since our final contract date is next Friday. We will also be putting together a complaint of all of the problems we have had thus far (and this will take me a long time to prepare), so if anyone has any contact details for those that are higher up in responsibility within the company I'd really appreciate if you could PM them to me. I'm sick of having all of our complaints fielded by the lower levels and neither of the people who have contacted us after making complaints have been any better than those we were complaining about. With 5 days to go until our contracted build period expires, I'd still take it all back and start from scratch with another builder if I could. Never ever ever do I want to have anything to do with PD ever again ETA I just thank god that we didn't listen to our CSC and SS ages ago when they told us, on multiple occasions, that we would be moving in well before now and give notice on our current rental, had I done that we would be out on the street right now! Re: Porter Davis homes 2089Jun 05, 2011 11:06 pm flagstaffIV Chorlton FINISHED GROUND LEVEL AROUND YOUR HOME ? Hello All, May I ask what was the approximate height of the finished ground level after your home had been built? I ask, as on three sides of our home (Front and 2 sides) the ground level is approximately at the same level as the underside of our slab. Consequently, on these 3 sides we can clearly see the full thickness of the exposed slab. In addition, in one area over a length of 2m the ground level is actually around 50-100mm below the underside of the slab!!! Is this normal, or has PD removed too much soil during the site excavation stages of our build?? Many Thanks in advance, Chorlton Chorlton, when they did your site scrape have they moved the soil back?? If they have I would bring it up with your SS. Before they handed over our house they poured crushed rock around the perimeter to stop water from getting into our foundations Hi Flagstaff, Thanks for the reply. Our block was on a gradient so a "cut & Fill" was required. This resulted in all the excavated earth being used for the fill. Regarding the crushed rock, in your case did they have to pour it on all sides of the home? If so, I will see if I can also request that. I'd also still be interested to hear from others on on how sites were left..... TIMING OF BUILD 25Feb - Site Start 25Mar - Base Stage Complete 31Mar - Frame Completed 11Apr - Roof Tiles 20Apr - Brickwork Started Re: Porter Davis homes 2090Jun 06, 2011 10:28 am Hi all, I've been reading through alot of the reviews and they have been very helpful. We are building the Ivanhoe 36. Just to let you all know, we went to Austral Bricks on Saturday and as of Thursday last week alot of the bricks have been discontinued including all of the Melbourne series. We have gone to tender not knowing this and contract is next week. We are at loss as the bricks that are left to choose won't suit our facade. Also went to Carpet Court in Oakleigh on Sunday and the guy also mentioned that Porter Davis will stop dealing with them in the next couple of weeks. Before any of you go to tender or contract make sure and query all this. My partner and I are not happy as we went to tender knowing these bricks were available and now most of them won't be. We have colour selection this Wednesday. My partner will being calling PD today to find out what is going on because this is not acceptable and we won't be picking bricks we don't like. Ivanhoe 36 Dep:18-4-11 Tender:26-5-11 Colour/Electrical:8-6-11 Contract:29-6-11 Building Permit:6-7-11 Site Start:16-8-11 PCI:10-1-12 Handover:24-1-12 http://eli-kay-ivanhoe36.blogspot.com/ Re: Porter Davis homes 2091Jun 06, 2011 12:16 pm Jewelbaby Jewelbaby I agree with everything you said Snoofie, I just wish I could say the same things in terms of having a positive experience. In all this we have been painted as some kind of freaks who expect our home to be entirely pristine, without so much as a fiber of carpet out of place, when nothing could be further from the truth! Our SS actually made the comment that perhaps we ought to go and buy a house in Toorak if we expected such good quality I don't care about the small things, like the fact that we have different coloured mortar in places, but I do care about things like the fact that our walls look and feel like they glued sandpaper down prior to painting and that the paint itself is bubbling away in many places due to extensive water damage because the roof leaks in the whole front end of the house! I know your post wasn't meant as a rebuff to those of us who have had a less than stellar experience thus far and I can absolutely appreciate that credit ought to be given where it is due, but the less rational side of me does feel a bit of a sting when I read posts like yours. I can assure you we've done all the right things, we have been extremely patient given the problems we have had, we have compromised over things we should not have had to compromise over, paid for things we should not have had to pay for and through it all I've contained myself immensely in the few posts I've made on the forums here, if I allowed myself to rant about it and really said it all it would be a wall of text that went on for multiple pages All that aside, we had a meeting with whom I think is the manager for Lifestyle East today. As it turns out it wasn't an official PCI, we will still have to go and do another one in a couple of weeks I think, sign the paperwork and then wait at least another week for handover. I'm not fussed by that, I just want them to get the job done properly and if that means taking a month instead of a week, for example, then so be it. The manager seemed very nice and reasonable, I was a bit reserved at first as the first thing he did was start a spiel about how things that our independent inspector said should be fixed were usually just him being overly fussy and not really necessities. We ran out of time to really go over the paintwork, one of my main areas of concern, because of the fading light and he said he would return and give it a thorough inspection himself on Thursday. I would have been dubious about this, but when he clarified that we would still do another PCI prior to handover it didn't seem to be an issue. He seemed to have a much better attitude to the job than some others we have dealt with, as though he took pride in the job done even though it wasn't his home. I was very pleased that he himself marked the visible plaster joins in the walls to be fixed in some areas because I'm not happy with them but hadn't made a fuss over it because I didn't think it was something they would fix. I really hope it's at least relatively smooth sailing from here on in. Well, I'm disappointed (but not terribly surprised) to report that things have not improved in the slightest. On Tuesday it will have been two weeks since our second "PCI" (and FIVE weeks since our first) and once again we have not sen or heard hide nor hair of anyone resembling a PD employee. We visited our build today to see that the only noticable thing that has been done in all of that time is that a new mirror has been put up in our bathroom (and the wall has been damaged in the process). All of the markers we put up during the second PCI almost two weeks ago are still there, showing that none of the work has been carried out. Once again our SS has not answered or returned calls, with the exception of the eleventh hour message he left my OH on Friday to say that he was finishing up for the day and as such we would not be able to contact him and that he would contact us on Monday about how the house was going. Among other things we will be asking our CSC what the process is to make a claim for late building works since our final contract date is next Friday. We will also be putting together a complaint of all of the problems we have had thus far (and this will take me a long time to prepare), so if anyone has any contact details for those that are higher up in responsibility within the company I'd really appreciate if you could PM them to me. I'm sick of having all of our complaints fielded by the lower levels and neither of the people who have contacted us after making complaints have been any better than those we were complaining about. With 5 days to go until our contracted build period expires, I'd still take it all back and start from scratch with another builder if I could. Never ever ever do I want to have anything to do with PD ever again ETA I just thank god that we didn't listen to our CSC and SS ages ago when they told us, on multiple occasions, that we would be moving in well before now and give notice on our current rental, had I done that we would be out on the street right now! Hi Jewelbaby, It is truly disappointing to hear that you have experienced such difficulties throughout your build and that you are disappointed with your service from your BC and SS. PD really need to know about your troubles so I will pass on your feedback to the PD office. Please know that I am here to assist you where I can. Regards, Ebony Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: Porter Davis homes 2092Jun 06, 2011 12:28 pm eli-kay123 Hi all, I've been reading through alot of the reviews and they have been very helpful. We are building the Ivanhoe 36. Just to let you all know, we went to Austral Bricks on Saturday and as of Thursday last week alot of the bricks have been discontinued including all of the Melbourne series. We have gone to tender not knowing this and contract is next week. We are at loss as the bricks that are left to choose won't suit our facade. Also went to Carpet Court in Oakleigh on Sunday and the guy also mentioned that Porter Davis will stop dealing with them in the next couple of weeks. Before any of you go to tender or contract make sure and query all this. My partner and I are not happy as we went to tender knowing these bricks were available and now most of them won't be. We have colour selection this Wednesday. My partner will being calling PD today to find out what is going on because this is not acceptable and we won't be picking bricks we don't like. Now thats very interesting.. I just finished my tender appointment this morning, and have final colors in 12 days. Tell you what it pays to be prepared, at our tender we got the complete price. No changes from us required to move forward, and we have our electrical price already based off what people have stated here. So we are stoked, coming in about 7k under budget. Re: Porter Davis homes 2093Jun 06, 2011 12:36 pm humble eli-kay123 Hi all, I've been reading through alot of the reviews and they have been very helpful. We are building the Ivanhoe 36. Just to let you all know, we went to Austral Bricks on Saturday and as of Thursday last week alot of the bricks have been discontinued including all of the Melbourne series. We have gone to tender not knowing this and contract is next week. We are at loss as the bricks that are left to choose won't suit our facade. Also went to Carpet Court in Oakleigh on Sunday and the guy also mentioned that Porter Davis will stop dealing with them in the next couple of weeks. Before any of you go to tender or contract make sure and query all this. My partner and I are not happy as we went to tender knowing these bricks were available and now most of them won't be. We have colour selection this Wednesday. My partner will being calling PD today to find out what is going on because this is not acceptable and we won't be picking bricks we don't like. Now thats very interesting.. I just finished my tender appointment this morning, and have final colors in 12 days. Tell you what it pays to be prepared, at our tender we got the complete price. No changes from us required to move forward, and we have our electrical price already based off what people have stated here. So we are stoked, coming in about 7k under budget. Really good result. From experience you can eat into that $7k quite fast the your tiles and electrical selections. Were your site costs reasonable? Cheers T Re: Porter Davis homes 2094Jun 06, 2011 12:41 pm tstr1a humble eli-kay123 Hi all, I've been reading through alot of the reviews and they have been very helpful. We are building the Ivanhoe 36. Just to let you all know, we went to Austral Bricks on Saturday and as of Thursday last week alot of the bricks have been discontinued including all of the Melbourne series. We have gone to tender not knowing this and contract is next week. We are at loss as the bricks that are left to choose won't suit our facade. Also went to Carpet Court in Oakleigh on Sunday and the guy also mentioned that Porter Davis will stop dealing with them in the next couple of weeks. Before any of you go to tender or contract make sure and query all this. My partner and I are not happy as we went to tender knowing these bricks were available and now most of them won't be. We have colour selection this Wednesday. My partner will being calling PD today to find out what is going on because this is not acceptable and we won't be picking bricks we don't like. Now thats very interesting.. I just finished my tender appointment this morning, and have final colors in 12 days. Tell you what it pays to be prepared, at our tender we got the complete price. No changes from us required to move forward, and we have our electrical price already based off what people have stated here. So we are stoked, coming in about 7k under budget. Really good result. From experience you can eat into that $7k quite fast the your tiles and electrical selections. Were your site costs reasonable? Cheers T See my thread, costs were 12k. Need a p class slab (3 piers) but we got a 10k discount through the current promotions (so 2k actual cost) Re: Porter Davis homes 2095Jun 06, 2011 12:46 pm Tell you what it pays to be prepared, at our tender we got the complete price. No changes from us required to move forward, and we have our electrical price already based off what people have stated here. So we are stoked, coming in about 7k under budget. [/quote] Really good result. From experience you can eat into that $7k quite fast the your tiles and electrical selections. Were your site costs reasonable? Cheers T[/quote] See my thread, costs were 12k. Need a p class slab (3 piers) but we got a 10k discount through the current promotions (so 2k actual cost)[/quote] humble can't find the link to your thread Re: Porter Davis homes 2097Jun 06, 2011 2:25 pm I would assume most of you know those who are building Access or Lifestyle pick bricks thru Boral. Those of you who are with Prestige pick their bricks from Austral. Why I don't know because we do like bricks from the Boral range but we aren't allowed to go thru them as we are Prestige. What the hell!!!! As far as I know with Austral, the Homestead collection is still there. So you will be ok with that and a few others if you stick with that range. Some of the discontinued bricks that I can remember and we wanted are: The Lawson, Canterbury, Cotham, Newport, and The Hawthorne brick will be replaced with the Hawksburn, but when we went to the Deer Park display centre they didn't have a sample of the Hawksburn which we found very disappointing because this could be the brick we may like and Wednesday is our colour selection. Those of you who are close to Tender I would go down or ring Austral Bricks first to see what bricks are available. Hopetoun Interiors may not know 100% what's discontinued. I wouldn't trust the girls there anyway. At least this way if your choice of bricks are discontinued you know that you will have to look at others. Ivanhoe 36 Dep:18-4-11 Tender:26-5-11 Colour/Electrical:8-6-11 Contract:29-6-11 Building Permit:6-7-11 Site Start:16-8-11 PCI:10-1-12 Handover:24-1-12 http://eli-kay-ivanhoe36.blogspot.com/ Re: Porter Davis homes 2099Jun 06, 2011 2:37 pm humble I had my tender this morning, and was quoted Hawthorn bricks, either HQ dont know or I am up for a drama very very shortly! I just called Austral bricks head office for you and the Hawthorne has been discontinued. Its replaced with the Hawksburn or the Burleigh???? Better you know now. Also the may have heaps of stock to clear so if you build soon you may be lucky. Re: Porter Davis homes 2100Jun 06, 2011 2:38 pm tstr1a humble I had my tender this morning, and was quoted Hawthorn bricks, either HQ dont know or I am up for a drama very very shortly! I just called Austral bricks head office for you and the Hawthorne has been discontinued. Its replaced with the Hawksburn or the Burleigh???? Better you know now. Also the may have heaps of stock to clear so if you build soon you may be lucky. Well the hawksburn is the skinny version. Hmm.. this is gonna *** me off. Wow that is terrible about the insurance! I guess ideally proof of insurance should be provided prior to first deposit but I'd imagine they would refuse to be out of… 17 14232 There isn't any need to. As I wrote previously, there isn't a set term, there is just commencement based on earlier of contract signing or building permit issue and… 24 13385 Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 6491 |
