Browse Forums Building A New House Re: Porter Davis homes 10741Jan 04, 2015 2:15 pm Blog post with pictures published - unfortunately we failed to take pics of some of the key things like new stair case, laundry shape, master ensuite.. Still might be a good sneak peak for people interested in the Hoffman Build blog - http://hasslingthehoff.wordpress.com/ Re: Porter Davis homes 10742Jan 04, 2015 3:34 pm Could any with a blog please share their links? I love seeing progress shots as we only have a slab so far. Visited Harcrest today and was hoping to see some darker colours. PD always seem to do their displays in neutral colours. Re: Porter Davis homes 10743Jan 04, 2015 3:38 pm ![]() Could any with a blog please share their links? I love seeing progress shots as we only have a slab so far. Visited Harcrest today and was hoping to see some darker colours. PD always seem to do their displays in neutral colours. Sure... http://bendigowaldorf.blogspot.com.au Re: Porter Davis homes 10744Jan 04, 2015 4:52 pm Anyone with Brivis refrigerated cooling get a high pitched whine in their unit when AC is on? Re: Porter Davis homes 10745Jan 04, 2015 5:57 pm ![]() Anyone with Brivis refrigerated cooling get a high pitched whine in their unit when AC is on? Have you checked the Heating and Cooling sub-forum? Re: Porter Davis homes 10746Jan 04, 2015 5:58 pm Jackula... can you give us an overview of your home theatre system setup? Re: Porter Davis homes 10747Jan 05, 2015 9:27 am ![]() Jackula... can you give us an overview of your home theatre system setup? Love to. Equipment: Front & centre channels: 3 x Seaton Catalyst 8C Surround Left/Right channels: 2 x JBL LSR305 Subwoofers: 2 x Seaton Submersive HPi+ Pre-Amplifier: Marantz AV7702, all speakers are active / powered so there is no need for an amplifier. Player: Oppo BDP-103Au (region free modded) TV: LG 65UB980T NAS: QNAP TS-451 (2 x 4TB) HDMI Extender: Generic HDBaseT HDMI 1.4 extender Power: 20A dedicated circuit 1: Front & centre channels 20A dedicated circuit 2: Front subwoofer and TV 20A dedicated circuit 3: Back subwoofer and surround channels 10A general circuit: Pre-Amplifier, player Placements: Listening position: approx 38% from the back of the room, that's roughly 1.8 to 1.9m from the back wall. Front channels: 600mm from front wall, 30 degrees to listening position, turned 15 degrees outwards off axis. Centre channel: 800mm from front wall (ideally should be 400mm), on axis. Surround channels: 1200mm from back wall, 120 degrees to listening position, on axis. Front subwoofer: 350mm from front wall, same distance to side walls, on axis. Back subwoofer: 350mm from back wall, aligned to the front subwoofer, on axis. Treatments: None yet, but the plan is: Acoustic diffusers at 1st reflection points. Acoustic absorbers at room corners. Absorbers will be made with plywood frame, acoustisorb2 foam, hessian cloth and speaker cloth. Diffusers will be made with MDF. Any questions? ![]() Re: Porter Davis homes 10748Jan 05, 2015 2:21 pm Jackula... thanks for the post on your blog about the electrical wiring recall. I know what I'm doing tonight! http://waldorf44oakleigh.blogspot.com.a ... ables.html Re: Porter Davis homes 10749Jan 05, 2015 2:23 pm Jackula... why are the Marantz pre-amps so good? Why should people go out and buy super expensive cabling? Why is Seaton Sound better? Re: Porter Davis homes 10750Jan 05, 2015 3:50 pm ![]() Jackula... why are the Marantz pre-amps so good? Marantz uses higher quality components (capacitors, power supply, internal cabling, higher-end Burr Brown chips) which results in lower noise, more stable and better quality output. Compared to Denon which are from the same factory with almost identical designs. Marantz AV7702 also uses Audyssey XT32, a room calibration system which IMO is better than YPAO (Yamaha), ARC (Anthem), MCACC (Pioneer), DCAC (Sony), AccuEQ (Onkyo). Primare SP33 would sound better but it doesn't have room calibration, so unless your room is fully treated, Marantz is still better. Trinnov Altitude and DataSat rs20i would be the next step up from Marantz AV7702 (though some people in the US have compared the AV7702 against a rs20i and found no difference). ![]() Why is Seaton Sound better? The subwoofers go deeper and louder than any other subs I know of, and with zero vibrations. The catalysts (L/C/R speakers) are internally tri-amplified (rather than passively amplified as most other speakers), this gives them better separation between the lows, mids and highs. The L/C/R are the same speakers, which provides better consistency and timbre between channels. Seaton's material cost for Catalysts 8Cs are about $1500 and they sell them for $3000 each, which is already a small markup, they cut out the distributor and retailer so you're effectively saving another 70%. Other than that, I can't explain why they sound so good. Revel Ultima Salon2 are the next best on my list, but they are definitely better than the Seatons for music though. ![]() Why should people go out and buy super expensive cabling? Because they're gullible. Speaker cables makes a difference to passive speakers to a degree. There are two commonly used materials for speaker cables, copper and silver. Their difference in conductivity, inductance, the way they are threaded, length, thickness all changes the sound, it doesn't make it better, it just changes it. Copper tend to be warmer sounding and silver tend to have more details (I don't know why, it's just personal experience). I am using copper because it helps tame my slighly bright system. You don't need to buy super expensive cabling to get the most of your speakers, for speakers < $1k/pair, you won't hear much difference going beyond Selby stocks. Speaker cables make zero difference to the home theatre experience, it's mainly for the critical listening of music. Re: Porter Davis homes 10751Jan 06, 2015 9:47 am ![]() ![]() Jackula... why are the Marantz pre-amps so good? Marantz uses higher quality components (capacitors, power supply, internal cabling, higher-end Burr Brown chips) which results in lower noise, more stable and better quality output. Compared to Denon which are from the same factory with almost identical designs. We have a lovely Marantz amp and have been very happy with it.. that said, 98% of music played these days is mp3 or spotify ![]() Pop quizz - who has gone for 6 stages of independent inspection? I'm thinking given our concern with drainage issues for our site and lack of faith in the buildign surveyor thus far (who has got every drawing slightly wrong) that we would be well placed to do a pre-slab inspection. Build blog - http://hasslingthehoff.wordpress.com/ Re: Porter Davis homes 10752Jan 06, 2015 11:03 am ![]() Pop quizz - who has gone for 6 stages of independent inspection? I'm thinking given our concern with drainage issues for our site and lack of faith in the buildign surveyor thus far (who has got every drawing slightly wrong) that we would be well placed to do a pre-slab inspection. We had opted for the pre-slab pour inspection and found it definitely worth it. Our inspector picked up 6 defects which the tradies were able to rectify on the spot. He nonetheless said it was "one of the best jobs" he has seen in months, so I don't want to know what a poor job looks like. We're building the Montague 21 and have a waffle slab system btw. I am currently reconsidering of getting an extra inspection after the fixing stage. We originally only opted for 4 inspections (pre-slab pour, slab+frame, lock-up, and PCI), we're just coming up to lock-up next week. For peace of mind I think it's worth it. Re: Porter Davis homes 10753Jan 06, 2015 12:33 pm just wondering if it is normal for the building co-ordinator to request proof of finances (ability to pay contract payment) such as a statement, before they pour the slab? thanks built the Dunedin 28 with Porter Davis. Re: Porter Davis homes 10754Jan 06, 2015 12:36 pm ![]() just wondering if it is normal for the building co-ordinator to request proof of finances (ability to pay contract payment) such as a statement, before they pour the slab? thanks They did for us, that said, all we provided was a letter from our bank saying they are happy to lend to us, as opposed to specifics. Our funds will only be drawn down and paid when we notify our bank to release funds to PD after each stage is complete. Also at the sales quote stage we had to briefly talk to the PD finance person to confirm we could finance the build and the mortgage after the fact. Build blog - http://hasslingthehoff.wordpress.com/ Re: Porter Davis homes 10755Jan 06, 2015 12:39 pm ![]() ![]() just wondering if it is normal for the building co-ordinator to request proof of finances (ability to pay contract payment) such as a statement, before they pour the slab? thanks They did for us, that said, all we provided was a letter from our bank saying they are happy to lend to us, as opposed to specifics. Our funds will only be drawn down and paid when we notify our bank to release funds to PD after each stage is complete. Also at the sales quote stage we had to briefly talk to the PD finance person to confirm we could finance the build and the mortgage after the fact. Same. My lender provided a signed ACC. I assume that is what they are after from you also Kateebee? My Waldorf 48 Blog: http://gisbornewillows.blogspot.com.au/ Re: Porter Davis homes 10756Jan 06, 2015 12:40 pm ![]() ![]() just wondering if it is normal for the building co-ordinator to request proof of finances (ability to pay contract payment) such as a statement, before they pour the slab? thanks They did for us, that said, all we provided was a letter from our bank saying they are happy to lend to us, as opposed to specifics. Our funds will only be drawn down and paid when we notify our bank to release funds to PD after each stage is complete. Also at the sales quote stage we had to briefly talk to the PD finance person to confirm we could finance the build and the mortgage after the fact. We had the same & they asked to hold 10% of build cost in trust with 4% interest rate. Re: Porter Davis homes 10757Jan 06, 2015 12:47 pm ![]() ![]() ![]() just wondering if it is normal for the building co-ordinator to request proof of finances (ability to pay contract payment) such as a statement, before they pour the slab? thanks They did for us, that said, all we provided was a letter from our bank saying they are happy to lend to us, as opposed to specifics. Our funds will only be drawn down and paid when we notify our bank to release funds to PD after each stage is complete. Also at the sales quote stage we had to briefly talk to the PD finance person to confirm we could finance the build and the mortgage after the fact. Same. My lender provided a signed ACC. I assume that is what they are after from you also Kateebee? we are actually paying a large shortfall from our bank accounts, rather than our loan. basically they want to know we have the money to do that. i just found it a bit odd. built the Dunedin 28 with Porter Davis. Re: Porter Davis homes 10758Jan 06, 2015 2:09 pm ![]() ![]() ![]() just wondering if it is normal for the building co-ordinator to request proof of finances (ability to pay contract payment) such as a statement, before they pour the slab? thanks They did for us, that said, all we provided was a letter from our bank saying they are happy to lend to us, as opposed to specifics. Our funds will only be drawn down and paid when we notify our bank to release funds to PD after each stage is complete. Also at the sales quote stage we had to briefly talk to the PD finance person to confirm we could finance the build and the mortgage after the fact. We had the same & they asked to hold 10% of build cost in trust with 4% interest rate. Just a tip, you can put more than 10% if you like. The best thing about their trust account is you don't need to tell them your TFN, so you can reap all the profits without having to pay any extra taxes on it ![]() At the time we built our house, we had 4.75% fixed, it was the highest interest rate at the time. Re: Porter Davis homes 10759Jan 06, 2015 8:58 pm I know this post goes back in time some way, but I'm interested to know how your imitation floorboards feel under your feet? My husband and I have been impressed with the solid feel underneath, meaning we don't seem to feel 'bouncy' walking on them. We are accustomed to real wood floorboards in our current 30yr old home, so can usually feel the bouncy feeling when we go into others homes, but we were really impressed with the feel of the PD displays. I was wondering if they do as good a job in customers homes as they do in their displays? Re: Porter Davis homes 10760Jan 08, 2015 10:39 am ![]() I know this post goes back in time some way, but I'm interested to know how your imitation floorboards feel under your feet? My husband and I have been impressed with the solid feel underneath, meaning we don't seem to feel 'bouncy' walking on them. We are accustomed to real wood floorboards in our current 30yr old home, so can usually feel the bouncy feeling when we go into others homes, but we were really impressed with the feel of the PD displays. I was wondering if they do as good a job in customers homes as they do in their displays? I have the standard bolero floorboards. http://prestigebuild.blogspot.com.au/20 ... alled.html Feels pretty solid. It is on top of concrete afterall. ![]() 'Remember not only to say the right thing in the right place, but far more difficult still, to leave unsaid the wrong thing at the tempting moment.' Blog: http://prestigebuild.blogspot.com.au Wow that is terrible about the insurance! I guess ideally proof of insurance should be provided prior to first deposit but I'd imagine they would refuse to be out of… 17 9784 There isn't any need to. As I wrote previously, there isn't a set term, there is just commencement based on earlier of contract signing or building permit issue and… 24 9437 Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 2849 ![]() |
