Toward the end of the process. It is basically smoothing of the slab.
Ahh, im meaning screeding that is applied to the top of the dry slab..
I am also interested to know
Browse Forums Building A New House Re: Porter Davis homes 10041Jul 29, 2014 2:35 pm ![]() ![]() ![]() Toward the end of the process. It is basically smoothing of the slab. Ahh, im meaning screeding that is applied to the top of the dry slab.. I am also interested to know ![]() Re: Porter Davis homes 10043Jul 29, 2014 5:20 pm ![]() How can you screed a dry slab? I had it done at a shop before doing the flooring, The concrete floor was stuffed so they screed it to make it perfectly level http://www.concretecentre.com/technical ... creed.aspx Re: Porter Davis homes 10044Jul 29, 2014 5:52 pm Our slab is going to be fixed like this, in our family area. I think it is getting done sometime during the lockup stage? Ours needs to be done before the kitchen cabinets are installed I think. Our garage also needs to be done but this is being done towards the very end of the build. Re: Porter Davis homes 10045Jul 29, 2014 6:57 pm ![]() Our slab is going to be fixed like this, in our family area. I think it is getting done sometime during the lockup stage? Ours needs to be done before the kitchen cabinets are installed I think. Our garage also needs to be done but this is being done towards the very end of the build. Hi mali, How uneven was your slab? Did PD say they will do this as part of the process or did u notice the slab was uneven and push for it? Re: Porter Davis homes 10046Jul 29, 2014 8:08 pm ![]() ![]() Our slab is going to be fixed like this, in our family area. I think it is getting done sometime during the lockup stage? Ours needs to be done before the kitchen cabinets are installed I think. Our garage also needs to be done but this is being done towards the very end of the build. Hi mali, How uneven was your slab? Did PD say they will do this as part of the process or did u notice the slab was uneven and push for it? Well over 4mm (which I think is the maximum from memory) in the family area. It was picked up by PD but we thought something was up when we noticed rain pooling in that area. The garage isn't smooth enough and that was picked up by PD too. Re: Porter Davis homes 10047Jul 30, 2014 1:33 am I just realised that I haven't actually ever uploaded our final Hopetoun Interiors colour selections! So, here they are... http://bendigowaldorf.blogspot.com.au/2014/03/hopetoun-interiors-selections.html Re: Porter Davis homes 10048Jul 30, 2014 11:48 am Hi Baferreri, Following your post I have identified your job address and will follow up with New Home Care on your outstanding maintenance list. Please PM me if you would like to discuss further and I will assist where possible. Regards, Joanne Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: Porter Davis homes 10050Jul 30, 2014 4:38 pm Thanks Jackula for that detailed response. Did you or anyone else have access to PD's independant report and how easy was it to get it from them?[/quote] were you able to get a copy of PD inspection(BSS) ? Re: Porter Davis homes 10051Jul 30, 2014 6:24 pm If any one wants a inspector that pd dislike as he is very thorough http://darbecca.com.au He picked up over 50 odd defects in frame stage. Don't trust pd with their said building inspectors . Sent from my iPhone using Tapatalk Re: Porter Davis homes 10052Jul 30, 2014 8:20 pm ![]() If any one wants a inspector that pd dislike as he is very thorough http://darbecca.com.au He picked up over 50 odd defects in frame stage. Don't trust pd with their said building inspectors . Why do you say that they dislike him? Re: Porter Davis homes 10053Jul 30, 2014 8:35 pm For anyone that is currently doing their selections with PD. They have a new website dedicated to the new 'World Of Style' showroom. One of the coolest addition is a heap of selection/preparation guides and checklists. Check it out! http://www.worldofstyle.com/experience Re: Porter Davis homes 10055Jul 30, 2014 9:34 pm ![]() ss told me... they know him well I guess that can only be a good thing ![]() Re: Porter Davis homes 10056Jul 31, 2014 11:25 pm Electrical appointment tips wanted - those that did LED downlights, did you get prewiring done or just get PD to do it all? Anyone get extra heating vents in ensuite bathroom or laundry? Has anyone put insulation between ground floor and 1st floor roof? extraction fans in toilets vented into walls, how will this work if insulation insitu? Do people talk via BC or just bypass them and go SS? So far Im vague as what BC actually does? How long did your colour appointments last, is 3 hrs enough time? Thanks in advance Building Porter Davis Sandringham 45 + alfresco + extra dining room Melbourne Inner East http://knockdownrebuildjourney.blogspot.com.au/ Re: Porter Davis homes 10057Jul 31, 2014 11:53 pm ![]() Electrical appointment tips wanted - those that did LED downlights, did you get prewiring done or just get PD to do it all? Anyone get extra heating vents in ensuite bathroom or laundry? Has anyone put insulation between ground floor and 1st floor roof? extraction fans in toilets vented into walls, how will this work if insulation insitu? Do people talk via BC or just bypass them and go SS? So far Im vague as what BC actually does? How long did your colour appointments last, is 3 hrs enough time? Thanks in advance Hi Sandy45 LED Lighting, if you get PD just to do the wiring, it's approx $48.60 from memory, then you need to buy the LED transformer + LED itself which can range anywhere from cheapo $35 up to nicer $60+ ones. Then you need to hire a sparky to come in and install the lights and depending on his/her hourly rate, you are better off getting PD to do it. From memory PD charges approx $130? Extra heating vents in ensuite bathtoom or laundry...hmmm for ensuite I requeted for heated bathroom lights and I dont see any value add having a heated vent in the laundry. Unless you spend most of your time in there. No insulations between floors allowed as they deem it as a fire hazzard. They will ask you to opt for sound dampening underlay instead. Extraction fans in toliets are vented outside. not into walls. If you want any changes, you need to speak with BC......however I have heard of people paying SS on the side to get some extra things done. Not sure how that works. Colour appointment - how long is a piece of string, everyone is different. Just be prepared before you go in, more homework you do with color choices...the quicker and easier it will be. IF you walk in there with no clue....be prepare to spend the whole day....look at my blog..there's plenty of pictures of what Hopetoun has to offer. Re: Porter Davis homes 10058Aug 01, 2014 2:12 am Check out our potential dining settings for our small and grand alfresco areas... Small alfresco: http://bendigowaldorf.blogspot.com/2014/08/option-for-small-alfresco-dining-set.html Grand alfresco: http://bendigowaldorf.blogspot.com/2014/08/options-for-grand-alfresco-dining.html Re: Porter Davis homes 10059Aug 01, 2014 10:36 am ![]() Check out our potential dining settings for our small and grand alfresco areas... Small alfresco: http://bendigowaldorf.blogspot.com/2014/08/option-for-small-alfresco-dining-set.html We had a similar outdoor table to this, but without the tiled top. The horizontal frame brace was right at knee height for me, and copped many a bruise. It was ok when just casually sitting around, but not when needing to pull the chair in when eating. Re: Porter Davis homes 10060Aug 01, 2014 12:35 pm Hey does anybody know if the porter davis NBN pack does include the NTD? "The Basic NBNCo Fibre Pack (including Enclosure) is $1,432.53. This package includes x3 Phone or Data points throughout the home and the WSC (cabinet) on the wall in the garage. " I'm going to presume it doesn't, though nobody seems to know or if they possibly do, they dont return calls :/ ... what have other people done to get the NTD installed faster or before completion, I hear this NBNco is retarded... and takes months to install NTD's. Wow that is terrible about the insurance! I guess ideally proof of insurance should be provided prior to first deposit but I'd imagine they would refuse to be out of… 17 9679 There isn't any need to. As I wrote previously, there isn't a set term, there is just commencement based on earlier of contract signing or building permit issue and… 24 9360 Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 2767 ![]() |
