Browse Forums Building A New House Re: Porter Davis homes 6401Dec 09, 2012 3:43 pm Anyone here have double basins in the ensuite/bathrooms? Is it normal for one to take heaps longer to drain? I mentioned this at our 3 month inspection and was told its normal cos 1 drain has to bend to join with the other sink or something.. But it just doesn't seem right if u filled the sink and opened the plug (even if u unscrewed the plug all together) you can literally go make a cup of coffee and come back before all the water has drained. I'm starting to feel like I was * to about this! Re: Porter Davis homes 6402Dec 09, 2012 6:49 pm Hi all, The Christmas and New Year break is just around the corner & we hope you’re all prepared for a lovely holiday. We would like to take this opportunity to highlight the opening hours for Porter Davis over the break: Display Centres Close Sunday 16th December at 5pm Re-open Saturday 5th January 2013 at 11am New Home Care Close Friday 21st December at 12pm Re-open Monday 7th January 2013 at 9am For urgent enquiries over the closure period, please call 1300 744 833. Offices Close on Friday 21st December at 12pm Re-open Monday 7th January 2013 at 9am 1800 Porter Close Friday 21st December at 5pm Re-open Monday 3rd January 2013 at 9am With the exception of 27-30 December – phone lines will be open from 10am to 4pm. If you have any questions, feel free to call our office on 1800 PORTER. I will also be offline from Friday 21st December and will be returning on Monday 7th January. From all at Porter Davis, we’d like to wish you a safe and happy Christmas and all the best for the new year. Cheers, Helen Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: Porter Davis homes 6403Dec 09, 2012 9:34 pm Wateman Anyone here have double basins in the ensuite/bathrooms? Is it normal for one to take heaps longer to drain? I mentioned this at our 3 month inspection and was told its normal cos 1 drain has to bend to join with the other sink or something.. But it just doesn't seem right if u filled the sink and opened the plug (even if u unscrewed the plug all together) you can literally go make a cup of coffee and come back before all the water has drained. I'm starting to feel like I was ****** to about this! I would pull off the pipes and have a look in them they should drain the same. My parents had on where the painter poured excess paint down there when cleaning or there could just something trapped in there possible pvc glue plumbers can go nuts with that stuff eithere way you can remove and refit those pipe easy enough to rule it out. Building the Montague 21 by Porter Davis at The Estuary, Leopold. Our Blog: http://porterdavismontague21.blogspot.com.au/ Re: Porter Davis homes 6404Dec 10, 2012 6:26 am J & C How come there is a fence at the side of your garage slab...shouldn't the garage wall be built on the end of your ridge line... my suggestion to you is get all issues rectified early before the next stage...else they never will...in our case so far it has only been talking the talk...mistake after mistakes being made but we were very adamant not to accept the house until some of the major issues were resolved...we are left with a handful such as the end point of our crossover and drive not meeting (yeah PD did do our driveway and crossover). I couldn't build to the ridge line. Closest my neighbours and council would allow was 150mm from the ridge line... Thanks for the advice. After all the dramas with the slab, will now refuse to move to the next stage until mistakes are rectified. PD really need to lift their game! Re: Porter Davis homes 6405Dec 10, 2012 9:47 am Wateman Anyone here have double basins in the ensuite/bathrooms? Is it normal for one to take heaps longer to drain? I mentioned this at our 3 month inspection and was told its normal cos 1 drain has to bend to join with the other sink or something.. But it just doesn't seem right if u filled the sink and opened the plug (even if u unscrewed the plug all together) you can literally go make a cup of coffee and come back before all the water has drained. I'm starting to feel like I was ****** to about this! That sound like rubbish. Are the blocked ? Sometimes the metal thing under the plug blocks up as the holes are not too bug. If they were not blocked they should drain almost the same. If they are not blocked under the plug then it sounds like they washed too much grout down the drain and don't want to look at it... Re: Porter Davis homes 6406Dec 10, 2012 10:25 am At PCI (6 months ago) I logged an issue with a missing roof tile above the rear garage rollerdoor. There was flashing there and it was sealed, but it still needed a roof tile as the flashing area was HUGE. Tile was added, I was happy. Flash Forward to this weekend… I was on the garage roof washing the cobwebs off the second story walls and noticed on the rear roofline that touches the house that the tile they used was a DIFFERENT COLOUR. They slotted it in on the lowest row away from the window so I couldn’t see it when I looked out the window, and it was just behind the wall so you couldn’t see the different coloured tile from the ground. In fact you’d never see it if you were not on the roof… And guess what colour this rouge roof tile is ??? The same colour as my neighbour’s (different builder). So do I assumed the guy who installed this tile it just mistakenly got the wrong colour from another PD site and failed to notice as he swaped 2-4 tiles on my roof, or do I assumed they stole the tile from the next door building site ? No wonder I had so many of their tiles in my yard. I assumed the neighbour’s builder just chucked the broken ones in my yard before the fence went up… Poor form either way ! Look closely people ! Mikey Re: Porter Davis homes 6407Dec 10, 2012 9:41 pm Got a call from my Slab Supervisor today to tell me we had our site cut done! Finally after waiting since Feb for our land to title, we have some action on our land. So happy to finally see some dirt moved Re: Porter Davis homes 6408Dec 11, 2012 10:24 am pdkallara33 Got a call from my Slab Supervisor today to tell me we had our site cut done! Finally after waiting since Feb for our land to title, we have some action on our land. So happy to finally see some dirt moved Well Done... man land settlement can take ages !! Re: Porter Davis homes 6409Dec 12, 2012 6:59 am Just wanted to compliment Porter Davis.. After my previous post I had a message on my phone saying they had booked a plumber for maintenance and they have been through today and the sink is now working fine. They said it was blocked with hair but I know it wasn't because it was like that from day one.. I don't care though, it's fixed and I'm impressed with PDs service.. Credit where it's due! Re: Porter Davis homes 6410Dec 12, 2012 7:41 am Wateman Just wanted to compliment Porter Davis.. After my previous post I had a message on my phone saying they had booked a plumber for maintenance and they have been through today and the sink is now working fine. They said it was blocked with hair but I know it wasn't because it was like that from day one.. I don't care though, it's fixed and I'm impressed with PDs service.. Credit where it's due! Hi Wateman, Thanks so much for the feedback and I’m glad the issue has been sorted for you . Cheers, Helen Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: Porter Davis homes 6411Dec 12, 2012 9:26 pm I got a mail from developer a month after my move saying that couple of the things in which the build has been done is non-compliant with the developer. Wouldn't PD have verified that before doing the build? Has anyone has similar issues like this before? TAMU Building PD Marbella 38 Deposit:31 Dec 2011 Tender:08 Feb Tile/Col/Elect: 22 Feb Contract: 29 Feb Slab: 24 Apr Frame: 17 May Lock up: 02 Aug Completion/PCI: 31 Oct Move in: 17 Nov 2012 Re: Porter Davis homes 6412Dec 12, 2012 10:25 pm tamugrg I got a mail from developer a month after my move saying that couple of the things in which the build has been done is non-compliant with the developer. Wouldn't PD have verified that before doing the build? Has anyone has similar issues like this before? Hey like what ? And Which estate (generally) Not sure why they care... Our developer has all these guidelines but everyone is doing what they want after they move in... Re: Porter Davis homes 6413Dec 13, 2012 6:51 pm PD should have followed the guidelines, well if you want to maintain the value of your house I would suggest that you stick to the guidelines. Get the developer to provide you with details and forward it to PD. Re: Porter Davis homes 6414Dec 13, 2012 7:59 pm tamugrg I got a mail from developer a month after my move saying that couple of the things in which the build has been done is non-compliant with the developer. Wouldn't PD have verified that before doing the build? Has anyone has similar issues like this before? Hi tamugrg, I understand that you have contacted your B/C direct regarding this matter, which was the right thing to do. They are looking into this for you and will be back in touch ASAP. Regards, Helen Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: Porter Davis homes 6415Dec 15, 2012 9:22 am I've got my selections appointment next Tuesday. Can anyone tell me where I can select what type of bath I want. I also want a different toilet to the 2 that they have on display at hopetoun. In my standard specifiations it says Imperial Cleo suite, does that mean they are using Imperial as the brand and that I can choose any from this brand from their website? The bath states Decina bath, I do not want acrylic I want china, so can I choose my own from the Decina range? Thanks guys Re: Porter Davis homes 6416Dec 15, 2012 8:18 pm they have started to frame my house.... bcos of the weather they only managed to do the theatre room and galley Re: Porter Davis homes 6417Dec 15, 2012 8:34 pm chrystee I've got my selections appointment next Tuesday. Can anyone tell me where I can select what type of bath I want. I also want a different toilet to the 2 that they have on display at hopetoun. In my standard specifiations it says Imperial Cleo suite, does that mean they are using Imperial as the brand and that I can choose any from this brand from their website? The bath states Decina bath, I do not want acrylic I want china, so can I choose my own from the Decina range? Thanks guys it depends... somethings can be outside what they have at Hopetoun, somethings can't. There are a few things PD have in the display homes that aren't available at hopetoun eg Showerheads,Shower rail, sink n toilet suites. These I managed to upgrade even though it wasn't displayed at Hopetoun. The bath may not be upgradable (I managed to get the Decina range and there are no china baths there). you may have to get approval from your BC if you want to upgrade. Highly unlikely you will get full freedom of choice on the Imperial and Decina bath since PD gets bulk discounts for buying thousands of the same type of fitting (eg bath/toilet etc).. Even with the tiling, PD tile boutique sources tiles from National Tiles, but a lot of the National Tile range is not available as a selection choice with PD (they just flatly refuse). Re: Porter Davis homes 6418Dec 19, 2012 9:35 am Had my electrical and colour selections yesterday. All went really well, very happy with the selections, the colour consultant was awesome. Very exciting! I have started a blog, the link is http://chrysteeporterdavis.blogspot.com.au/ Re: Porter Davis homes 6419Dec 20, 2012 3:26 pm chrystee Had my electrical and colour selections yesterday. All went really well, very happy with the selections, the colour consultant was awesome. Very exciting! I have started a blog, the link is http://chrysteeporterdavis.blogspot.com.au/ Lovely floor plan! What a huge pantry you'll have! Looking forward to following your progress! We've just this week got our dates for our tender and colour appointments - in March. Can't wait! Re: Porter Davis homes 6420Dec 20, 2012 11:01 pm ma2531 PD had given us R6.0 batts in the celing, and R2.5 in walls and sisalation, and all double glazed windows in the lounge/study/dining windows. so hoping it will be good enough. ill let u know whenever the house is finished! keep up the good work......................... Is there a way of confirming the windows are double-glazed? My plans say PD to supply as double glazed windows as well so I was wondering if there was a way of visually confirming they are double-glazed. Do your double-glazed windows look different to the standards? Don't suppose you have a picture of the double glazed window (close up of the glass) as I couldn't see one on you blog... Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 12337 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 74702 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 105564 |
