I agree, very well put snoofie
Browse Forums Building A New House Re: Porter Davis homes 1702May 05, 2011 7:15 pm Site cut: 2 June 2010 Slab Poured: 2 Oct 2010 Frame Stage: 12 Oct 2010 Lock up: Dec 2010 Fixing Stage: March 2011 http://karasdreamhome.blogspot.com/ Re: Porter Davis homes 1703May 05, 2011 7:18 pm __________________________________________ Built Camberwell 29 with PD - Hand Over was on 22/12/10 http://ssazcamberwell29.blogspot.com/ Re: Porter Davis homes 1704May 05, 2011 7:23 pm Site cut: 2 June 2010 Slab Poured: 2 Oct 2010 Frame Stage: 12 Oct 2010 Lock up: Dec 2010 Fixing Stage: March 2011 http://karasdreamhome.blogspot.com/ Re: Porter Davis homes 1705May 05, 2011 7:41 pm ![]() they can extend if the delay isnt the builders fault - but the delay had nothing to do with neighbours disputes or anything like that - they were wrong with the engineering of retaining walls due to the nieghbours garage being build just on the boundary Then in my opinion that is within the builder's direct control & they shouldn't be able to claim extension of time. __________________________________________ Built Camberwell 29 with PD - Hand Over was on 22/12/10 http://ssazcamberwell29.blogspot.com/ Re: Porter Davis homes 1707May 05, 2011 8:00 pm ![]() Next question.. has anyone built using a canterbury facade? Would love to take a look. I'll play, not quite finished, still rendering to be done, and a real front door ![]() It's an Ivanhoe Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My building thread : viewtopic.php?f=31&t=36059 Paid initial deposit 24/7/10 Tender appointment 20/8/2010 Flooring and tile appointment 25/9/10 Colour and Electrical appointment 13/9/10 December site start delayed Site start (YAY!) 17/1/11 Slab pour 1/2/2011 Re: Porter Davis homes 1708May 05, 2011 8:04 pm Hi SSAZ, I was wondering if you could give me some more info on your site costs and what the costs related to?? I think you said yours ended up being $28K. We have just been given site costs of $43K and I wonder if you have 42 piers what am I going to have!!!!! Any info would be appreciated. Re: Porter Davis homes 1709May 05, 2011 8:17 pm ![]() Hi SSAZ, I was wondering if you could give me some more info on your site costs and what the costs related to?? I think you said yours ended up being $28K. We have just been given site costs of $43K and I wonder if you have 42 piers what am I going to have!!!!! Any info would be appreciated. Hi tcorn, It included cut & fill, Slab Upgrade to P, Concrete piering, upgrade stormwater & agri drain. That's pretty much the lot. Do you have to do a lot of retaining wall? Because retaining wall alone can cost you $20k+ __________________________________________ Built Camberwell 29 with PD - Hand Over was on 22/12/10 http://ssazcamberwell29.blogspot.com/ Re: Porter Davis homes 1710May 05, 2011 8:36 pm Hey guys, I have a question.. Did you guys have your external door furniture (eg front door handles) installed at lockup and then found that these were damaged? Ours were put on when the doors went on and we now find that the front door set has black acid stains (from the brick cleaners) and the laundry door set is starting to rust. Has anyone else experienced this and had them replaced without question? Re: Porter Davis homes 1711May 05, 2011 8:43 pm ![]() ![]() Hi SSAZ, I was wondering if you could give me some more info on your site costs and what the costs related to?? I think you said yours ended up being $28K. We have just been given site costs of $43K and I wonder if you have 42 piers what am I going to have!!!!! Any info would be appreciated. Hi tcorn, It included cut & fill, Slab Upgrade to P, Concrete piering, upgrade stormwater & agri drain. That's pretty much the lot. Do you have to do a lot of retaining wall? Because retaining wall alone can cost you $20k+ The retaining wall is only $8K of that $43K and they mentioned all the other things you did. The huge cost seemed to be the concrete piering and I just don't really understand that if we both needed them how come ours is so much more?? Re: Porter Davis homes 1712May 05, 2011 8:52 pm ![]() ![]() Next question.. has anyone built using a canterbury facade? Would love to take a look. I'll play, not quite finished, still rendering to be done, and a real front door ![]() It's an Ivanhoe Thanks Heaps! ![]() Re: Porter Davis homes 1713May 05, 2011 9:16 pm My site costs were roughly 45k too. 18k just for the retaining wall! Arghhh I've learn to accept now! Mel Re: Porter Davis homes 1714May 05, 2011 9:41 pm ![]() Hey guys, I have a question.. Did you guys have your external door furniture (eg front door handles) installed at lockup and then found that these were damaged? Ours were put on when the doors went on and we now find that the front door set has black acid stains (from the brick cleaners) and the laundry door set is starting to rust. Has anyone else experienced this and had them replaced without question? Yes, they installed ours & it rusted & they replaced everything without question. __________________________________________ Built Camberwell 29 with PD - Hand Over was on 22/12/10 http://ssazcamberwell29.blogspot.com/ Re: Porter Davis homes 1715May 05, 2011 9:43 pm ![]() The retaining wall is only $8K of that $43K and they mentioned all the other things you did. The huge cost seemed to be the concrete piering and I just don't really understand that if we both needed them how come ours is so much more?? Get them to give you a break down. Did they give you the drawings for the piering? Check the specification. __________________________________________ Built Camberwell 29 with PD - Hand Over was on 22/12/10 http://ssazcamberwell29.blogspot.com/ Porter Davis homes 1716May 05, 2011 10:04 pm ![]() ![]() Hey guys, I have a question.. Did you guys have your external door furniture (eg front door handles) installed at lockup and then found that these were damaged? Ours were put on when the doors went on and we now find that the front door set has black acid stains (from the brick cleaners) and the laundry door set is starting to rust. Has anyone else experienced this and had them replaced without question? Yes, they installed ours & it rusted & they replaced everything without question. Great news, thanks! Re: Porter Davis homes 1717May 06, 2011 8:37 am ![]() ![]() The retaining wall is only $8K of that $43K and they mentioned all the other things you did. The huge cost seemed to be the concrete piering and I just don't really understand that if we both needed them how come ours is so much more?? Get them to give you a break down. Did they give you the drawings for the piering? Check the specification. We didn't sign the Tender or pay the deposit so they didn't give us the breakdown or any drawings. They didn't show us any drawings for the piering. Did you get those? I'm sure I will get used to the idea, its just put us way over budget and I'm not sure if we should scale back a bit. We put an extra room and huge corner alfresco onto the Camberwell 29 so its huge and beautiful but expensive! Re: Porter Davis homes 1718May 06, 2011 9:01 am ![]() We didn't sign the Tender or pay the deposit so they didn't give us the breakdown or any drawings. They didn't show us any drawings for the piering. Did you get those? I'm sure I will get used to the idea, its just put us way over budget and I'm not sure if we should scale back a bit. We put an extra room and huge corner alfresco onto the Camberwell 29 so its huge and beautiful but expensive! I got the drawing for the piering when they send me the final construction drawings to be signed, that's how I found out how many & what sort of piering they did. I was going to put the grand alfresco but was told it would push our site cost a lot higher, in the end we went for a smaller one. __________________________________________ Built Camberwell 29 with PD - Hand Over was on 22/12/10 http://ssazcamberwell29.blogspot.com/ Re: Porter Davis homes 1719May 06, 2011 10:56 am ![]() Hey guys, I have a question.. Did you guys have your external door furniture (eg front door handles) installed at lockup and then found that these were damaged? Ours were put on when the doors went on and we now find that the front door set has black acid stains (from the brick cleaners) and the laundry door set is starting to rust. Has anyone else experienced this and had them replaced without question? Hi snoofie, I'm sorry to hear about these issues that you've noticed. If you haven't done so already, I highly recommend contacting your Customer Care Administrator or Site Supervisor to discuss this & get their advice. Perhaps you can put this in writing and include some pictures so that they understand the issue fully. Let us know how you go. Cheers, Jess. Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: Porter Davis homes 1720May 06, 2011 11:44 am Ah, the hoops I have to jump through.. talk about frustration. Land Developer wants a deposit, bank have not completely confirmed, mortgage broker decides to take a 4 day weekend (without notice) Great start not.. ![]() Hi there! Putting the feelers out there for those who have (or almost) built with Arli homes! Interested in your experiences who've built from their stock home designs… 0 96121 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 23584 Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 25444 |
