Browse Forums Building A New House 1 Jul 14, 2011 12:13 pm Hi all, We have just moved last week in our brick veneer home and are quite happy and excited. I realised I forgot to include sound proofing my master bedroom wall with the adjacent bedroom wall. I can hear my housemate's baby in the night. Is there anything I can do now and what options do I have to insulate or reduce the noise across the new gyprock walls? Cheers ------------------------------------------------------- http://homeinkalina.blogspot.com Enjoying our new Concerto with Allworth Homes in Kalina, The Ponds Handover - 28/06/2011 Re: Sound proofing across newly built gyprock walls 2Jul 14, 2011 3:13 pm I'm pretty sure that to have any effective result you're going to have to remove and re-plaster one side of that wall. I would install rockwool batts such as Bradford Sound Screen and use Soundchek (plasterboard from Gyprock that helps reduce noise - here's a link: http://www.gyprock.com.au/resources/filemanager/datasheets.aspx?fileIteration=154). Thanks for clarifying. Sorry I misunderstood your point 7 6975 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15787 Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20650 |
