Browse Forums Building A New House 1 Jul 11, 2011 12:16 am Hi We sound out our building setback from the front of the property is a metre less we we told for a 10mx29m block this is a big deal The choice Is , leave house as is and our back yard goes from 5m x 10m (which i thought was too small) to 6m x 10m or add .5 metre to kids bedrooms and they go from 2.9 x 3.1m and become 2.9 x 3.6m and the backyard would be 5.5 x 10m we plan at this stage to live in the house at least 10 years but also want it to be "sellable" when the time comes. what would you do? Re: Just found a metre what would you do? 2Jul 11, 2011 1:31 am Hi, If it was me I would go for the bigger bedrooms. Ny reasoning is that an extra 50cm in a bedroom is huge but I think you would hardly notice it in a yard. Good luck with your build Re: Just found a metre what would you do? 5Jul 11, 2011 7:26 am Bigger bedrooms, the extra 0.5m will make a Hugh difference plus yOu are still gaining an extra 0.5m for your back yard!
Ps my back yard is only 4.5 x 13 so I understand the joy in finding more room Re: Just found a metre what would you do? 7Jul 11, 2011 8:27 am Another +1 for the bedrooms - another 50mm will make a noticeable difference inside and it would be the sort of thing that makes people go "oooh it looks nice and cosy from the outside but these bedrooms are actually a nice size!" and any pleasant surprises hidden behind your facade can only be a good thing when it comes to selling. I'd be thinking with a 10m wide block they would be on the absolute minimum side setback already. Some people apparently have nothing better to do than comment on other people's sigs. Re: Just found a metre what would you do? 8Jul 11, 2011 9:10 am cmhamilton I'd be thinking with a 10m wide block they would be on the absolute minimum side setback already. If you have very minimal side set backs you may actually want the extra open space. Just another way to look at it Re: Just found a metre what would you do? 9Jul 11, 2011 10:21 am Thanks for the replies guys, I am driving my wife crazy with this stuff your opinions help greatly I was thinknig along the same lines about more space in the bedroom, side set backs are 1m either side so not much we can do about that and 5.5 back yard is bigger than what I thought we would end up with so all good!!! now just to throw another question out there ,we have 3 minor bedrooms as mentioned currently 2.91 x 3.1 Due to the configuration of floor plan we have 2 options *Add the .5 to two of the bedrooms making 2 bedrooms 2.91 x 3.6 and leave the 3rd 2.91 x3.1 or *Add .3 in one .2 in another and .5 in another leaving 3 bedrooms - 2.91 x 3.3 , 2.91 x 3.4, 2.91 x 3.6 what do you think is best option? Re: Just found a metre what would you do? 10Jul 11, 2011 10:35 am kdgirl cmhamilton I'd be thinking with a 10m wide block they would be on the absolute minimum side setback already. If you have very minimal side set backs you may actually want the extra open space. Just another way to look at it As you mentioned in your previous reply there is still an extra 500mm in the backyard anyway, but an extra 5 sq metres inside the house will be more value-adding than an additional 5 sq metres in an already small backyard imo. Prospective buyers looking at a house on a 290 sq metre block will expect a small house with small bedrooms and minimal yard space, so having bigger (almost standard sized) bedrooms like you would see in a larger house will be much more noticeable than 500mm more depth in the rear yard, because a yard of either size is essentially nothing more than a courtyard anyway (you wouldn't look at a 6m x 10m yard and think "wow this is much bigger and more open than I imagined"). Go out into your backyard and peg out 5.5m x 10m vs 6m x 10m on your lawn and you'll see what I mean - I had a similar dilemma when trying to work out how much room we would have in the small yard at the rear of the house (most of our space is more to the side of the house) with different setbacks as well as the easement running down the back of our block while working our the most practical length for the driveway and trust me when I say 500mm isn't much. Some people apparently have nothing better to do than comment on other people's sigs. Re: Just found a metre what would you do? 12Jul 11, 2011 11:02 am City Fringe Due to the configuration of floor plan we have 2 options *Add the .5 to two of the bedrooms making 2 bedrooms 2.91 x 3.6 and leave the 3rd 2.91 x3.1 or *Add .3 in one .2 in another and .5 in another leaving 3 bedrooms - 2.91 x 3.3 , 2.91 x 3.4, 2.91 x 3.6 what do you think is best option? In my opinion it depends. If you have kids and all three bedrooms will be occupied permanently, then I would go with second option (making all bedrooms equal size). However if there are only two of you (or only 1 kid), and third bedroom will be occupied by occasional guests once a year, then we would go 1st option (making guest bedroom the smallest one) Re: Just found a metre what would you do? 13Jul 11, 2011 11:21 am City Fringe Thanks for the replies guys, I am driving my wife crazy with this stuff your opinions help greatly I was thinknig along the same lines about more space in the bedroom, side set backs are 1m either side so not much we can do about that and 5.5 back yard is bigger than what I thought we would end up with so all good!!! now just to throw another question out there ,we have 3 minor bedrooms as mentioned currently 2.91 x 3.1 Due to the configuration of floor plan we have 2 options *Add the .5 to two of the bedrooms making 2 bedrooms 2.91 x 3.6 and leave the 3rd 2.91 x3.1 or *Add .3 in one .2 in another and .5 in another leaving 3 bedrooms - 2.91 x 3.3 , 2.91 x 3.4, 2.91 x 3.6 what do you think is best option? Is it possible to go with a .3/,3/.4 split? I'd probably like the second option if it were me, but if you could go 2.91 x 3.4/2.91 x 3.4/2.91 x 3.5 and have the br's all pretty much the same size that would be nice. Edit: I agree with the post above - if you will only be using two of the bedrooms for children and the third bedroom will be a occasionally-used guest bedroom then having the two main bedrooms larger and the third (guest) bedroom smaller would be fine. Some people apparently have nothing better to do than comment on other people's sigs. Re: Just found a metre what would you do? 14Jul 11, 2011 12:19 pm cmhamilton City Fringe Thanks for the replies guys, I am driving my wife crazy with this stuff your opinions help greatly I was thinknig along the same lines about more space in the bedroom, side set backs are 1m either side so not much we can do about that and 5.5 back yard is bigger than what I thought we would end up with so all good!!! now just to throw another question out there ,we have 3 minor bedrooms as mentioned currently 2.91 x 3.1 Due to the configuration of floor plan we have 2 options *Add the .5 to two of the bedrooms making 2 bedrooms 2.91 x 3.6 and leave the 3rd 2.91 x3.1 or *Add .3 in one .2 in another and .5 in another leaving 3 bedrooms - 2.91 x 3.3 , 2.91 x 3.4, 2.91 x 3.6 what do you think is best option? Is it possible to go with a .3/,3/.4 split? I'd probably like the second option if it were me, but if you could go 2.91 x 3.4/2.91 x 3.4/2.91 x 3.5 and have the br's all pretty much the same size that would be nice. Edit: I agree with the post above - if you will only be using two of the bedrooms for children and the third bedroom will be a occasionally-used guest bedroom then having the two main bedrooms larger and the third (guest) bedroom smaller would be fine. NOt possible to do an even spilt as 2 bedrooms on one side off hallway 1 on the other. 2 kids at this stage maybe a 3rd down the track. I think we will go with option of adding .2 to one, .3 to another and .5 to one. Let's home the builder does not sting me too much cheers guys Re: Just found a metre what would you do? 15Jul 11, 2011 6:08 pm City Fringe Due to the configuration of floor plan we have 2 options *Add the .5 to two of the bedrooms making 2 bedrooms 2.91 x 3.6 and leave the 3rd 2.91 x3.1 or *Add .3 in one .2 in another and .5 in another leaving 3 bedrooms - 2.91 x 3.3 , 2.91 x 3.4, 2.91 x 3.6 what do you think is best option? Unless you will be using all 3 bedrooms, I would go with the first option and have the 3rd smaller bedroom as a study. Re: Just found a metre what would you do? 16Jul 11, 2011 6:18 pm mimi23 Unless you will be using all 3 bedrooms, I would go with the first option and have the 3rd smaller bedroom as a study. I agree, two good size bedrooms and a smaller is the way I would go. The significant date is when receive final payment invoice Check that section of contract Bit of fluff by builders prior to that 1 15952 Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8783 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39751 |
