Browse Forums Building A New House 1 Jul 06, 2011 2:31 am Re: Off centre front door and other issues help 3Jul 06, 2011 8:05 am The off center door looks d-o-d-g-y. Like it wasn't planned properly and the brickie tried to work around it. I wouldn't be accepting that, they should have moved the doorway. What is the defect in the second picture? It doesn't look great but is it going to be rendered? I would assume they are going to put the missing bricks back at the top of the garage. On my house they broke several of them out so they could put in some scaffolding for the roof, then they replaced them later. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: Off centre front door and other issues help 4Jul 06, 2011 8:57 am Our door was off centre on the plan. They do it so when it's opened it's up to a wall inside. I had them centre it, I'd rather it centred and be further out from the wall. Follow our journey at http://www.notgoingtodreamworld.blogspot.com Our build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=48999 Re: Off centre front door and other issues help 5Jul 06, 2011 12:43 pm Thanks for the feedback. Btherl no it's not going to be rendered, they put up fences around the whole place so it's hard to get to, and it was wet on the day. Now I look at the bricks the base looks terrible, mortar missing and plastic lining sticking out between the mortar and the brick. I searched a lot of homes last night and I haven't seen the front door and brickwork done like this, I hope it is classified as a defect in case they refused to fix it. Re: Off centre front door and other issues help 6Jul 06, 2011 3:16 pm Check your plans... see how the door spacing is on them Follow our journey at http://www.notgoingtodreamworld.blogspot.com Our build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=48999 Re: Off centre front door and other issues help 7Jul 06, 2011 3:25 pm re: door spacing. Just a though - Do you plan on having a front door bell or something light that, you might actually need that extra space to fit that??? Re: Off centre front door and other issues help 8Jul 06, 2011 3:28 pm No ... no ... no ... no ... the door should be as your plan (hopefully centred) and the bottom three rows of bricks look as though they belong somewhere else - they do not match the bricks above. I wouldn't be happy - better say something before they go too far. Good luck!! For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Off centre front door and other issues help 10Jul 06, 2011 4:15 pm Hit them up then... probably better off getting them on to it sooner rather than later.... good luck with it Follow our journey at http://www.notgoingtodreamworld.blogspot.com Our build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=48999 Re: Off centre front door and other issues help 11Jul 06, 2011 5:33 pm Ok, thanks for the feedback. However, they say they won't be stopping construction and will be continuing with the sheet on Monday. Sadly this is a builder where you aren't even allowed access to the construction manager, or give out the name of the contractors. Building Standards; Getting It Right! AS2047 Section 6 Page 31 speaks to Construction/Tolerances of Windows and external glazed doors in buildings Check also New South Wales Guide to Standards and Tolerances,… 12 24830 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6357 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9084 |
