Browse Forums Building A New House 1 Jun 24, 2011 9:28 pm We're building a split level house. Slabe was poured last week, frames went up today, so we had a quick sticky beak.... The frame at the end of the upper level rests on the floor of the lower level. However, this frame isnt against the upper level slab, meaning that the upper level slab ends, there's some empty space mid air, and then there's frame. Is this a concern? I dont think they can move said frame against the wall as it would probably push everything in front of it on the upper level off the edge of the slab. How is something like this rectified? Is some sort of flooring board put in to cover the gap? Is some extra timber attached to the frame to bring the wall in line with the edge of the slab? Re: split level screwup? 2Jun 24, 2011 10:26 pm How big is the gap? Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 split level screwup? 4Jun 25, 2011 2:24 am We have this also in our split level that we took handover of thurs arvo, except our gap is MUCH smaller. Most of the frame meets the split but of the areas of gap, mostly 2-3cms in the majority of spots, the worst spot is an area of about 5cm gap about 6 cm long. Thankfully the gap that is the biggest is located in what will be our guest bedroom BIR. They did not cover any of the gaps (but ours are smaller), flooring will just be laid over top. Megan and John Signed with Oakford 8/8/10 Plans at council 25/8/10 FINAL COUNCIL APPROVAL 29/11/10 Site start - 17/1/11 Cut & Fill commence - 21/1/11 Follow my build here: viewtopic.php?f=31&t=41283 Move your linen into laundry and access laundry from your present linen space 1 8008 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6585 |
