Browse Forums Building A New House 1 Jun 14, 2011 4:44 pm HI All, our volume builder does not leave off skirting boards and can only provide timber floor with ugly timber quads around benches etc. They have agreed to let us install ourselves after handover. What allowances do i need to ensure when i get the floor installed myself, it will sit flush with the kitchen bench/cupboards etc. and also will be putting in skirtings around walls myself do i need to allow for anything ?? hope you can help i have no idea about this all other than i hate the look of the timber quads and can't believe that most of the volume builders finish their floors like this. Re: Installing timber floor after handover 2Jun 14, 2011 5:30 pm What sort of floor? floating or solid. Landscape Design & Construction http://cherub.squarespace.com/ Re: Installing timber floor after handover 3Jun 14, 2011 7:00 pm The skirtings cover the gap left at the edges, which allow the timber to expand. Just make sure you skirtings are thick enough to cover the gap. You may still need to have quad along kitchen cabinetry kickboards, however. Perhaps talk to your floor layer about this. Ours managed to avoid this thankfully by doing a pretty neat finish close to the bench and kickers, filling the small gap with flexible caulking matching our wood colour. Another point you may want to consider (if not too late ) is do your kitchen bench heights need to be higher to take into account the height of the flooring installation? Make sure your dishwasher will fit in height wise! This will depend on what type of wooden flooring installation you're doing, and personal preference for bench heights. Re: Installing timber floor after handover 4Jun 14, 2011 7:25 pm thanks for the responses the flooring will be hardwood at this stage but depending on cost we may end up with floating does it make a difference? Re: Installing timber floor after handover 5Jun 14, 2011 8:09 pm We installed our solid timber after handover. Our builder was happy enough to come back after and fit the skirtings, but we have beading around the kitchen. I think you will need it as it allows the floor to expand and contract. I agree that it does look better without the beading, but to be honest, it doesn't bother me around our kitchen. It blends in as it's exactly the same as the flooring timber. Also, you will need some sort of beading to any external doors (like sliding doors). My sister wasn't keen on this, so they made up a board to go across the length of her sliders, but it looks worse as it's a step up and looks out of place. Re: Installing timber floor after handover 6Jun 16, 2011 10:25 am We are getting our builder to do our bamboo flooring and then get the skirtings redone after. They charges us $440 for this and for painting touch ups. We still need to get beading around the kitchen bench but I decided I could deal with this, I just did not want it through the whole house. Melissa Building the Kenthurst by Clarendon at The Ponds Re: Installing timber floor after handover 7Jun 22, 2011 12:10 pm thanks for the responses we have decided to go Hardwood , the installer said I need 12mm ply sheets on the concrete and the floor is 19mm = total 33mm. My housing contract is yet to be signed (tender is next week) what should I ensure is in tender to make sure I get best possible finish ? Do I need level of slab to be 33mm less . door heights to be adjusted? kichten cabinets adjusted? I have no idea about this stuff and this volume builder is not that helpful only to say we are happy for you to install yourself but it is after handover so if any problems not our issue.(yes not happy with builder response but love the house and we are limited to choice due to block size) Re: Installing timber floor after handover 8Jun 22, 2011 12:33 pm For our timber floor the only change that had to be made to o increase the kitchen bench height to 930mm above slab. Our flooring is 18mm thick. This is mainly to ensure that the dishwasher will fit in. Not sure about the door heights so may check that one out. Melissa Building the Kenthurst by Clarendon at The Ponds Re: Installing timber floor after handover 9Oct 31, 2011 1:43 pm kenthurst@blackthorn For our timber floor the only change that had to be made to o increase the kitchen bench height to 930mm above slab. Our flooring is 18mm thick. This is mainly to ensure that the dishwasher will fit in. Not sure about the door heights so may check that one out. hi there, me and my wifey are planning to install it after handover and we are also building at the ponds in the blackthorn release. r u building there what lot number are you on. what precautions do i take for installiung timber after hand over. thanks feel free to email me at zubinvaishnav@gmail.com Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6695 Ask yourself if the insurance company will be aware of the Reno. 4 7369 Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8370 |
