wildorchid
.................its a little small to see, but whats the bit inbetween study and bed 3?
Gotta run, Should be a "clicky" to a full-sized version ???
P_D
Browse Forums Building A New House Re: Our Blackwood Park hacienda 21Aug 08, 2011 5:44 pm wildorchid .................its a little small to see, but whats the bit inbetween study and bed 3? Gotta run, Should be a "clicky" to a full-sized version ??? P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Our Blackwood Park hacienda 22Aug 08, 2011 8:12 pm wildorchid ....i love the store room from the garage, and the huge laundry (inc toilet)! its a little small to see, but whats the bit inbetween study and bed 3? is that WIR in front of main bed? could you extend and move doorway across or put linen cupboard in the extra bit of hall way I came back The area between the study and bedroom 3 is "split" into two parts. The part in bedroom 3 is a 500mm deep BIR, while the part in the study is slightly shallower, it'll be a bookcase.....For *SOME* of our books, we've got way too many and I just cannot seem to force myself to part with (a lifetimes collection) of them !!! Yes, as you've correctly identified, we've put a WIR in front of the main bedroom. One of the design criteria Mrs P_D has put on the plan is that she wants to be able to get out of bed and leave the bed-room (the room with the bed) and be able to go to the WIR and ensuite and then leave the area without exiting through the bedroom. This is as I'm a shift worker she doesn't want to have to get dressed in the main room, or indeed have to re-enter it. Not sure what you mean with your suggestion, but I do agree that that area needs "more work", but at this stage I think I've reached the limits of my design skills !! Feel free to hack any suggestions for the area on a plan and post it......All help is greatly appreciated !! Cheers, P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Our Blackwood Park hacienda 23Aug 10, 2011 10:29 pm Hi P_D a couple of things to think about... consider putting a door the other end of the garage store - I know it will take away a bit of room but you will probably appreciate it in the future when loaded up with shopping or put one into the laundry as there is loads of space. also the ensuite is very large - the shower looks like it would be almost three metres also there will be no window as the toilet is against that wall which will affect ventilation and natural light. I drew up something really quick that might work but there would be many configurations with that shape room, I would think. You could probably take the ensuite back in line with the main bathroom and it would still be a big room at three metres long by 3m wide approx otherwise lots of great features and good use of space https://forum.homeone.com.au/viewtopic.php?f=31&t=43937&start=0 Bought a block in Golden Grove - Jan 2011 Finally finished our design, Mar 2012, *yay* Signed with ADH council consent June 12 Re: Our Blackwood Park hacienda 24Aug 11, 2011 1:41 am dreamcometrue ...consider putting a door the other end of the garage store - I know it will take away a bit of room but you will probably appreciate it in the future when loaded up with shopping or put one into the laundry as there is loads of space.... Ah, I had a door from the garage to the laundry a couple of versions ago...Don't know where it went, I'll put it back in !! dreamcometrue .........also there will be no window as the toilet is against that wall which will affect ventilation and natural light..... You're right...No window in the ensuite...The reason for that is....umm...errr.....ahhh.......I missed it !! Need to fix that !!! dreamcometrue .......otherwise lots of great features and good use of space Thanks, Really appreciate the suggestions, they'll be in the next version !!! Cheers, P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Our Blackwood Park hacienda 25Aug 11, 2011 2:37 pm Pepsi_Drinker wildorchid ....i love the store room from the garage, and the huge laundry (inc toilet)! its a little small to see, but whats the bit inbetween study and bed 3? is that WIR in front of main bed? could you extend and move doorway across or put linen cupboard in the extra bit of hall way Not sure what you mean with your suggestion, but I do agree that that area needs "more work", but at this stage I think I've reached the limits of my design skills !! I think what wildorchid was saying is that you have used a lot of space (the 2.54m across in front of the entrance to the WIR/main bedroom) as hallway area and you might be able to get better use of space there. Either by pushing out the whole wall down to the stairs coming up from the dining area (and moving the door across) or by moving the door over to the right and using the end of that small L-shape corridor as extra storage for a linen cupboard or similar. I also agree with dct that you should have an entry from your garage, either through the store room or (probably better) through the laundry as you mentioned. Then you can go straight into the kitchen with your shopping bags. You could also consider putting a door to the outside in the laundry (where you have that large window) so that you can walk straight out to the clothesline. Finally, you might also want to reconsider the placement of the AC unit, depending on the unit you plan to buy and your use of airconditioning. If you sometimes run the AC over night it might not be the best position to have it on a bedroom wall as some can be quite noisy and disturb light sleepers. Overall I think you have done well and it looks really good. Judging by the stairs you have your block must have quite a slope. Hope it all works out for you. Have you had any more luck talking to builders yet? Thread: viewtopic.php?f=31&t=52680 SiteStart 19/11/11 Slab 10/12/11 Frame 17/02/12 Roof 3/05/12 LockUp 22/06/12 Handover 31/08/12 Re: Our Blackwood Park hacienda 26Aug 26, 2011 1:22 pm Hi Guys ............. Went and saw another builder yesterday....Slowly the quotes are coming in We're "seriously" considering "owner-building"...Sort of !! To save clogging up this thread, I thought it best to keep this thread for the actual build, I've started a thread on the side, seeking advice about D.I.Y viewtopic.php?f=38&t=50690 I'd appreciate it if you could pop over there, have a look and leave your thoughts ............... Cheers, P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Our Blackwood Park hacienda 27Sep 03, 2011 11:39 am Hi guys ....... We're getting very close to selecting a builder, and we think that we've (almost) finished the plan Please feel free to have a look and give your honest feedback !!! The garage will do double-duty as a photo-studio, also the extra long bit at the end of the garage will be a "workshop", doing away with the need for a shed in the back yard. Not really shown, but at the end of the family room will be an "alfresco" 6.5m wide * 4.0m deep. As the plan is, north run exactly along the left-hand side wall (ie the garage side of the house). We need to get a "designer" to finesse the "interior" of the kitchen and also Bed 1 WIR. As before, Bed 1 is designed so that Mrs P_D can get out of bed and leave the room, and then be able to go to the bathroom, go to the wardrobe, get dressed, do makeup without re-entering the BED-room ..... Thanks, P_D (Clicky below) . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Our Blackwood Park hacienda 28Sep 03, 2011 12:03 pm Will there be someone in bedroom 3 or will it be a spare room? It's a long way from the bathroom. Re: Our Blackwood Park hacienda 29Sep 03, 2011 12:10 pm catjim Will there be someone in bedroom 3 or will it be a spare room? It's a long way from the bathroom. Thanks catjim, There will only be Mrs P_D and myself shortly after we move in, but bed three does have near access to the powder room ........ P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Our Blackwood Park hacienda 30Sep 03, 2011 3:38 pm I think its looking good You have addressed the previous problems, there is a lot of northern aspect in the family area and it is very spacious. The shower and loo are away rom the bedroom wall which will help keep the noise down (in our rental the loo backs onto the bedroom wall and is very noisy when flushed ) You may not need 1600 between the two kitchen benches, I think 1200 is fairly normal, check out some displays with your tape measure to get an idea although it would certainly add to the spaciousness in the kitchen and there is still plenty of room in the dining/family. If you get it priced up and need to save some dollars you could bring the study and bedroom in 500 as it would still be a wide hallway at 1500 but depends on the front door size I guess. Great to hear your close to deciding on a builder then you're on the way! https://forum.homeone.com.au/viewtopic.php?f=31&t=43937&start=0 Bought a block in Golden Grove - Jan 2011 Finally finished our design, Mar 2012, *yay* Signed with ADH council consent June 12 Re: Our Blackwood Park hacienda 31Nov 12, 2011 1:51 pm Progress.................... Of sorts........... As the late, great John Lennon said "Life is what happens to you // While you're busy making other plans " Mrs P_D and I have had a heap of things happen in the last couple of months, so much so that the new home, while not put on the "back burner" has definitely been put on a "low simmer" !! Be that as it may, we have made a decision.......To make a decision We have picked a builder to do the "Preliminary Work", a small 20-homes-a-year family business, and from all indications they seem pretty good. The sales dude has not been at all pushy, seems to of been bending over backwards to actually help us. Being such a small home-builder you can actually talk to the people you need to talk to, to this end I've talked on the phone to "The Boss" a couple of times, and it turns out that their construction manager has been best friends with a friend of ours since they both wore short pants to school.......Adelaide's a small place So, we've got an appointment to see them on Monday, we'll be having a meeting with "The Boss" as well as the sales dude and also their draughtsman and the construction manager said he'd pop in and say "G'Day" while we're there. The main thing for us, is that we recognise that the design I've managed to bash out on the 'puter is "pretty good" for us but needs technical help, so we need to get a feel that the draughtsman sees our vision and has confidence that he can turn our ideas into a practical house design. If we're happy with that, and "The Boss" seems as reasonable in real life as he has been on the 'phone to date, then we'll get out the cheque-book and let them do what it is they do at the preliminary stage !! I've been through the "Things you forgot thread" viewtopic.php?f=31&t=5823 , and have made a list of things that are appropiate to us, that'll be coming along, as will nearly 100 pages of Power Point slides of things we have seen at various display homes / forums / shops / showrooms of "things we like". Not all of them will be able to be incorporated in our design, but we're hoping that by showing the builder a wide variety of things that we do like that they will get a feel for our "vision" and more easily incorporate our vision in their plans !!! Question for the day........Apart from taking our plans and vision with us to this meeting, what else should we take with us...And what questions do we need to be asking them ? Thanks, P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Our Blackwood Park hacienda 32Nov 12, 2011 4:06 pm Hi P_D looks like you're in the same place we are at the moment. Remember to find out how the company will address the 6 star energy requirement. If you don't know already - check which companies they use for the various selections. (joinery, tapware, doors, windows, bathroom accessories, tiles, bricks etc) wishing you all the best for Monday. https://forum.homeone.com.au/viewtopic.php?f=31&t=43937&start=0 Bought a block in Golden Grove - Jan 2011 Finally finished our design, Mar 2012, *yay* Signed with ADH council consent June 12 Re: Our Blackwood Park hacienda 33Nov 14, 2011 3:42 pm Pepsi_Drinker Progress.................... Of sorts........... As the late, great John Lennon said "Life is what happens to you // While you're busy making other plans " Mrs P_D and I have had a heap of things happen in the last couple of months, so much so that the new home, while not put on the "back burner" has definitely been put on a "low simmer" !! Be that as it may, we have made a decision.......To make a decision We have picked a builder to do the "Preliminary Work", a small 20-homes-a-year family business, and from all indications they seem pretty good. The sales dude has not been at all pushy, seems to of been bending over backwards to actually help us. Being such a small home-builder you can actually talk to the people you need to talk to, to this end I've talked on the phone to "The Boss" a couple of times, and it turns out that their construction manager has been best friends with a friend of ours since they both wore short pants to school.......Adelaide's a small place So, we've got an appointment to see them on Monday, we'll be having a meeting with "The Boss" as well as the sales dude and also their draughtsman and the construction manager said he'd pop in and say "G'Day" while we're there. The main thing for us, is that we recognise that the design I've managed to bash out on the 'puter is "pretty good" for us but needs technical help, so we need to get a feel that the draughtsman sees our vision and has confidence that he can turn our ideas into a practical house design. If we're happy with that, and "The Boss" seems as reasonable in real life as he has been on the 'phone to date, then we'll get out the cheque-book and let them do what it is they do at the preliminary stage !! I've been through the "Things you forgot thread" viewtopic.php?f=31&t=5823 , and have made a list of things that are appropriate to us, that'll be coming along, as will nearly 100 pages of Power Point slides of things we have seen at various display homes / forums / shops / showrooms of "things we like". Not all of them will be able to be incorporated in our design, but we're hoping that by showing the builder a wide variety of things that we do like that they will get a feel for our "vision" and more easily incorporate our vision in their plans !!! Question for the day........Apart from taking our plans and vision with us to this meeting, what else should we take with us...And what questions do we need to be asking them ? Thanks, P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Our Blackwood Park hacienda 34Nov 14, 2011 3:45 pm Thanks d_c_t .......... We had our meeting today, things went well. The meeting went for over two hours and they seemed to be ahead of the game for all the "structural" questions I asked them, so that was a good thing. I asked about underground a rain-water tank, we have been thinking about a 5,000 litre plastic one, he said they do a 9,000 litre concrete one cheaper. I asked about "recessing" the tracks for the stacker sliding patio doors, he said that was the way they always did it. I asked them what sort of plasterboard they used for various areas and their answers met the ones I had on my "cheat-sheet" of things to check !! We asked many things like that and I don't think we surprised them once It's fair to say that generally they had the answers off of the top of their heads (regarding feasibility / options and a "ball-park" price ) so that gave us a lot of confidence too. I also gave them (our customised) list from the "Things you forgot thread" viewtopic.php?f=31&t=5823 , and just left it with them, along with our 100 or so PP slides........They can have fun reading those and seeing what (if any ) sense they can make out of them. We'll go through them with a fine-tooth comb at our next (more formal) meeting !!! So.......we're going to give them the $$'s for the PWA (apparently that's a Preliminary Work Agreement). That's going to get us ................ Design and drafting fees for the proposed new development Preliminary footing design by qualified engineer Site level and drainage plan by qualified engineer Structural plans by qualified engineer Application fee for council planning consent "Let the games begin" P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Our Blackwood Park hacienda 35Nov 14, 2011 4:30 pm P_D, we just paid $$ too, also for the prelim works, so they will do the bore holes on the block, a contour plan and windspeed assessment. Hopefully that will give us a fixed footing price before we sign the contract. https://forum.homeone.com.au/viewtopic.php?f=31&t=43937&start=0 Bought a block in Golden Grove - Jan 2011 Finally finished our design, Mar 2012, *yay* Signed with ADH council consent June 12 Re: Our Blackwood Park hacienda 36Nov 14, 2011 7:39 pm PD, Congratulations you found a builder, we did the same going with a smaller company in the end. We had our own plans and Mitcham council approval allready and had 6 companies quote. The communication and flexability was by far a huge plus. Similarly I investigated the underground tank possibility with supply and sit prices of $3500 for a 5000 litre upto $5000 for a 13640 litre concrete from RI Industries (got full price details if you want). This did not include the earth works. that would would blow that out particularly as our back yard is cut to the rock, so we considered putting it out front which was mostly fill. (Our , B/Park block has a 2.5m rise over 40m depth). Check what the builders idea of 'recessing the stacker track' is as it may not be what you picture. We specified this and still have a small lip, and slight drop to alfresco. nothing we would trip on, so we are happy. What street are you on? Slab poured 21/04/2011 Frame finished 27/05/2011 Moved in 07/11/2011 Re: Our Blackwood Park hacienda 37Nov 14, 2011 9:02 pm dreamcometrue P_D, we just paid $$ too, also for the prelim works, so they will do the bore holes on the block, a contour plan and windspeed assessment. Hopefully that will give us a fixed footing price before we sign the contract. LOL....Sounds like we're about at the same place in time, hope things go well for you !! 71monaro ..... The communication and flexability was by far a huge plus. Similarly I investigated the underground tank ... from RI Industries (got full price details if you want)......Check what the builders idea of 'recessing the stacker track' is as it may not be what you picture. We specified this and still have a small lip, and slight drop to alfresco. nothing we would trip on, so we are happy.......What street are you on? Thanks 71' .......... Be interested in further info about the (large) tank, and we'll pass that on to the builder. Made a note to check what they mean by recessing the track, I hadn't thought to question just what they do mean......But I will now We're actually not that far from you, PM sent ....... Cheers, P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Our Blackwood Park hacienda 38Nov 28, 2011 8:14 am Been up to "the block" a couple of times in the last couple of weeks................. (G'Day 71monaro ) Something's been happening up there, looks like we've had some sort of burrowing animal move in ................. His hole ...................... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And his poop .............. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Our Blackwood Park hacienda 39Nov 28, 2011 10:52 am looks like the same critter as the one burrowing in our block https://forum.homeone.com.au/viewtopic.php?f=31&t=43937&start=0 Bought a block in Golden Grove - Jan 2011 Finally finished our design, Mar 2012, *yay* Signed with ADH council consent June 12 Re: Our Blackwood Park hacienda 40Nov 28, 2011 3:47 pm dreamcometrue anyone interested in seeing a pic of a core hole and contents? (very technical description ) We have had action on the block............. dreamcometrue looks like the same critter as the one burrowing in our block I noticed that !! That's where I got the idea to post my piccy.... You didn't think I was smrt enuff to fink ov that meself now did yous P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 of course there are legal avenues. You've already mentioned it. Sue them. I find it odd that lawyers wouldnt be willing to take on the case, given CCT evidence and… 1 14682 "Losers" "humanity" "off time" "your" "top notch" "love symbol" Sounds like ponzo is done using other people's toilets 37 14045 |
