Browse Forums Building A New House 1 Jun 13, 2011 9:24 am Hi Guys I just got a Merbau decking done and noticed that there are untidy areas around screw heads. Please click on below to see a picture. http://imageshack.us/photo/my-images/810/p1000084i.jpg/ The guy who completed this decking said it was unavoidable and asking money to fix it - unscrew screws, sand them and put them back. What do you think? Thanks. Re: Untidy Screw Area - Merbau Decking 2Jun 13, 2011 12:00 pm NiMa this result could have been avoided if they had used countersinking tool, which still can be done now, they just need to remove the screws, and redrill in the holes with the countersinking tool. The end result should be neater like this... Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10976 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8318 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16567 |
