Browse Forums Building A New House 1 Jun 10, 2011 7:01 pm The builder just completed fitting stage, I am wondering when can I arrange for utility connections? I would prefer to have utilities connection ready so that I can check the electrical (lights etc) and water (taps, sinks) and gas appliances are working properly during pre-handover inspection. Re: When to apply for utility connections? 2Jun 10, 2011 7:38 pm sionghua The builder just completed fitting stage, I am wondering when can I arrange for utility connections? I would prefer to have utilities connection ready so that I can check the electrical (lights etc) and water (taps, sinks) and gas appliances are working properly during pre-handover inspection. The electricity, water will allready be on at the house. The builder would have been using them to build the house. Your appliances probably wont be in ours wont go in until the day we move in. But you can check lights, taps, sinks etc... on the builder. Re: When to apply for utility connections? 3Jun 10, 2011 7:43 pm as deb mentioned above, water & electricity will be sorted out by the builder, and changed over into your name at handover. Check with your builder to find out the process. Give yourself up to two weeks to notify the utility companies where you currently live now, as some may take up to 10 working days to organise the disconnections Re: When to apply for utility connections? 4Jun 11, 2011 9:25 am Gas and water will be sorted by the builder usually but you may have to double check on the electricity. For our build the builder put in a temporary electrical connection to a pole at the front of the property. They needed to do this as I had to organise a new underground power pit (a process that took a couple of months). If you have overhead power it may be ok, but worth checking sooner rather than later. A quick phone call to your builder should sort it out. Re: When to apply for utility connections? 5Jun 11, 2011 10:56 am you may want to add phone to that list... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Building Standards; Getting It Right! It's all good. You can get both wye piece and the coupling with or without thread. The cost difference is negligible and means the plumber only has to carry the single… 1 3810 |
