Browse Forums Building A New House 1 Jun 05, 2011 11:42 am Hi I got a little bit of concrete coming out from the house slab which I would like to get removed. Please click below link to refer attached picture. http://imageshack.us/photo/my-images/21/p1000074w.jpg/ I got couple of guys to have a look but I was asked to use a Jack Hammer mentioning that there is no space to use a concrete cutter. I am reluctant to use Jack Hammer thinking that vibration would affect the house/slab. Any suggestion would be appreciated. Re: How to remove excess concrete 2Jun 07, 2011 8:35 am NiMa Hi I got a little bit of concrete coming out from the house slab which I would like to get removed. Please click below link to refer attached picture. My signature is distracting people from my wise posts ... Re: How to remove excess concrete 3Jun 07, 2011 9:25 am lex this is fairly normal. It basically occurs when a bit of the trench falls in. The form work is only used above ground. Nima, is there a real need to remove it. Can you just cover it up?? Re: How to remove excess concrete 4Jun 07, 2011 9:32 am We had a lot of concrete like that coming out of our outdoor room concrete, which was laid after the slab. And some small bits coming from the main slab, which a chisel dealt with. We dealt with the large parts from the outdoor room with a combination of a crowbar (the heavy 6 foot kind, like a giant chisel), a metal hammer, pick axe and a small chisel for the last bits. And a shovel and a trowel for digging away the dirt underneath first. We had to remove it to lay some drains. Water was pooling over the concrete and would take days to clear. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10247 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11838 |
