Fyi,
You only need 1 data point in each room because you can buy small switch that cost $25-$40 to extend it.
While true that a switch will be do the same thing, two dedicated points provide a failsafe in case something goes wrong with the cable and it stops working. In which case you can then get a switch and use it on the other point to give you two points
