Carpet $1900
Upgraded to Gold range with underlay
Vertical blinds throughout the house $2300
Air con $7100
Fujitsu 15kw
MyAir 5 with 6 zones
Individual temperature sensor in each zone, allows you to have different temperature in each zone
Electrical $10,600
1 power circuit
6 single power points
7 double power points
4 light circuits
8 tread lights pre-wire only
6 external light points pre-wire only
13 light points upgraded to down lights
48 downlights
1 each, 2-way and 3-way switches
2 ducted ceiling exhaust fans
6 ceiling fan pre-wire with timber noggin and fan controller
1 downlights dimmer
Smart home $2200
1 video intercom pre-wire only
1 digital antenna
5 cat5e data points
3 cat6 data points
1 TV wall mount wire conduit
Tiles $4700
450x450 to 600x600porcelain tiles to main areas
30x45 to 30x60 wall tiles in 3 bathrooms
tiled splash back including behind the range hood
wow.. your upgrade for the tiles is considered cheap, but the rest are expensive.
My tile upgrade cost me about 15K.
You must have chosen rectified tiles, they're expensive. We just chose cheapest 600x600
The rest does seem expensive but I had external quotes that we gave to our lender. Looking at these, we got more stuff than we would've got if done after handover so just decided to do it with them and have everything ready when we move in.
I only upgrade to 600x600 standard porcelain tiles for the entire ground floor that cost approx. 10K.
The other 5K is full height tiles standard 30x45 to all 3 bathrooms.
