Browse Forums Building A New House Re: Who's building with Clarendon?? 17627Aug 14, 2017 7:42 am Mrs RS Have a question regarding waterproof how high it's done for wall heights. .. If you have a picture please share need to clarify our waterproofing. ...thanks in advance The first stage they do walls, plaster joins and floor, the second stage is as per your picture just floor and it is an epoxy including a lip around the floor basin. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Who's building with Clarendon?? 17629Aug 14, 2017 8:01 am Spooky8080 Mrs RS This is one of our showers. ..they did the same around the whole room is this ok. Balcony second stage waterproofing gives a better example of how it shoukd look in your wet areas. Is that just the upstairs wet areas that should should look like that? I've seen downstairs wet areas (laundry, bathroom & WC) which seem to just be around the perimeter of the room and floor wastes Re: Who's building with Clarendon?? 17630Aug 14, 2017 8:15 am Spooky8080 SnowLeopard Question about tiles. Did anyone ask for porcelain tiles as standard inclusion at Tile Direct? We went on the showroom tour and the staff at Tile Direct said porcelain tiles are not included and it's an upgrade. On the other hand, if you look at the Price List, the Plus Price includes GLAZED PORCELAIN TILES FROM NOMINATED RANGE. Yes we used the included porcelain tiles in the sapphire range but upgraded to a better polished porcelain tile as the included porcelain tiles were not that nice. Thanks Spooky. Do you mean the tiles range wasn't good or quality? Killara 28 Re: Who's building with Clarendon?? 17631Aug 14, 2017 8:23 am iceberg. Spooky8080 Mrs RS This is one of our showers. ..they did the same around the whole room is this ok. Balcony second stage waterproofing gives a better example of how it shoukd look in your wet areas. Is that just the upstairs wet areas that should should look like that? I've seen downstairs wet areas (laundry, bathroom & WC) which seem to just be around the perimeter of the room and floor wastes Our waterproofing guys were really good. They said normally downstairs wet areas, ie on the slab, are just done around the perimeter but they thoroughly did the whole area. Probably because i was there pestering them. I pretty much supervised every aspect of every stage. I was a real pain in the bum for them. But if i hadn't, things would have been missed as the site supervisor was hardly ever there. I always found it amusing when he would ring for the friday weekly update and I already knew new what was happening. He would say things like next week tge second stage waterproofing gets done and I would say ...um..no, that got done yesterday..😁 Re: Who's building with Clarendon?? 17632Aug 14, 2017 8:30 am SnowLeopard Spooky8080 SnowLeopard Question about tiles. Did anyone ask for porcelain tiles as standard inclusion at Tile Direct? We went on the showroom tour and the staff at Tile Direct said porcelain tiles are not included and it's an upgrade. On the other hand, if you look at the Price List, the Plus Price includes GLAZED PORCELAIN TILES FROM NOMINATED RANGE. Yes we used the included porcelain tiles in the sapphire range but upgraded to a better polished porcelain tile as the included porcelain tiles were not that nice. Thanks Spooky. Do you mean the tiles range wasn't good or quality? Both. From memory, they were quite thin and a fairly cheapish tile in the included range. This woukd have been ok if the size and colour we wanted were available. In the end we upgraded to what we wanted in a white polished poecelain in 600 x 600 and we just paid the difference between the included and the upgrade. Re: Who's building with Clarendon?? 17633Aug 14, 2017 8:34 am Spooky8080 SnowLeopard Spooky8080 Yes we used the included porcelain tiles in the sapphire range but upgraded to a better polished porcelain tile as the included porcelain tiles were not that nice. Thanks Spooky. Do you mean the tiles range wasn't good or quality? Both. From memory, they were quite thin and a fairly cheapish tile in the included range. This woukd have been ok if the size and colour we wanted were available. In the end we upgraded to what we wanted in a white polished poecelain in 600 x 600 and we just paid the difference between the included and the upgrade. Was it a huge difference or a few hundred dollars? Killara 28 Re: Who's building with Clarendon?? 17634Aug 14, 2017 8:44 am .[/quote] Was it a huge difference or a few hundred dollars?[/quote] It was about 4k. Mind you, can you believe it started off as 12k difference. But after i checked their measurements, AND also realised they had sneakily neglected to minus the price of the included range, it brought it down to just over 4k. They used the excuse that they were going off earlier plans. Yeh right! I keep telling you guys, you have to check EVERYTHING. Re: Who's building with Clarendon?? 17635Aug 14, 2017 9:09 am Spooky8080 Mrs RS Have a question regarding waterproof how high it's done for wall heights. .. If you have a picture please share need to clarify our waterproofing. ...thanks in advance The first stage they do walls, plaster joins and floor, the second stage is as per your picture just floor and it is an epoxy including a lip around the floor basin. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I thought it should be bit high up will ask ss when at site. ... Re: Who's building with Clarendon?? 17636Aug 14, 2017 9:10 am Spooky8080 SnowLeopard Question about tiles. Did anyone ask for porcelain tiles as standard inclusion at Tile Direct? We went on the showroom tour and the staff at Tile Direct said porcelain tiles are not included and it's an upgrade. On the other hand, if you look at the Price List, the Plus Price includes GLAZED PORCELAIN TILES FROM NOMINATED RANGE. Yes we used the included porcelain tiles in the sapphire range but upgraded to a better polished porcelain tile as the included porcelain tiles were not that nice. Hi Spooky8080, We are also planning to do the same upgrade the polished porcelain..can you please tell what was the upgrade costed you...or the price range for the tile and workmanship Re: Who's building with Clarendon?? 17637Aug 14, 2017 9:15 am we took everything out (carpet and tiles) get refunded around 10k. probably we weill spend 25k in total to do what we want (expensive tiles and floor) which would easily cost another 30k if we upgrade from clarendon. Re: Who's building with Clarendon?? 17638Aug 15, 2017 1:15 pm SnowLeopard Spooky8080 Both. From memory, they were quite thin and a fairly cheapish tile in the included range. This woukd have been ok if the size and colour we wanted were available. In the end we upgraded to what we wanted in a white polished poecelain in 600 x 600 and we just paid the difference between the included and the upgrade. Was it a huge difference or a few hundred dollars? Hi Snow, Porcelain or Ceramics, is depend on your package. Mostly, by default its Porcelain. If not mistaken, Tile Direct only have Porcelain and Marbles, they don't even have Ceramics. You maybe talking to someone new staff there. But when you go to Marbles, its an upgrade. The only problem is that your inclusion only get 450x450. If you like to upgrade to 600x600, the cost is depend on the size of your house. My house cost 10K for the upgrade from 450 to 600. Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Who's building with Clarendon?? 17639Aug 15, 2017 8:23 pm Hi All, hoping some could help me out here . I am committed to purchase a home and Land package from Clarendon (High grove Box Hill ) I had my Land and Building (split) contract reviewed by my Solicitor. I was told that (SC53.1 ,53.2(a) ,54) way the clause is written in contract (in short; land contact says, house must be build with Clarendon home), I would find difficult to get my home loan approved. I had this claim confirmed with my mortgage broker (and he himself got a written confirmation from NAB,CBA, ANZ andWestpac) "not accept split contracts such as what is proposed by Clarendon" My original sales Agent was very helpful, but, unfortunately, he has moved on to another job. Currently I am getting different answers from Sales department people. I am wondering if anyone of you had this problem? . please help...... Thank you in advance Re: Who's building with Clarendon?? 17640Aug 15, 2017 8:36 pm Bernardraj Hi All, hoping someone could help me out here . I am committed to purchase a home and Land package from Clarendon (High grove Box Hill ) I had my Land and Building (split) contract reviewed by my Solicitor. I was told that (SC53.1 ,53.2(a) ,54) way the clause is written in contract (in short; land contact says, house must be build with Clarendon home), I would find difficult to get my home loan approved. I had this claim confirmed with my mortgage broker (and he himself got a written confirmation from NAB,CBA, ANZ andWestpac) "not accept split contracts such as what is proposed by Clarendon" My original sales Agent was very helpful, but, unfortunately, he has moved on to another job. Currently I am getting different answers from Sales department people. I am wondering if anyone of you had this problem? . please help...... Thank you in advance the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 6746 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7872 |
