Browse Forums Building A New House Re: Who's building with Clarendon?? 7467May 20, 2015 9:25 am Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Who's building with Clarendon?? 7468May 20, 2015 9:29 am Built a Fairmont 35 in Pennant Hills. Completed May 2015. http://www.pennodream.wordpress.com - Blog updated regularly Re: Who's building with Clarendon?? 7469May 20, 2015 9:34 am Built a Fairmont 35 in Pennant Hills. Completed May 2015. http://www.pennodream.wordpress.com - Blog updated regularly Re: Who's building with Clarendon?? 7470May 20, 2015 9:57 am Paddington 29 @ Blue Horizon Estate (Lot 105, Wattleridge Crescent, North Kellyville) Our Build Progress Blog: http://light487.wordpress.com/ Re: Who's building with Clarendon?? 7475May 20, 2015 10:56 am Paddington 29 @ Blue Horizon Estate (Lot 105, Wattleridge Crescent, North Kellyville) Our Build Progress Blog: http://light487.wordpress.com/ Re: Who's building with Clarendon?? 7479May 20, 2015 11:10 am light487 Does anyone know how to determine the size of the windows from the plans? I can't see any dimensions noted on the plans, just coded numbers for the type of windows. For example, I am looking for the exact size of our letterbox windows to see how much a powered external roller shutter might cost but all it says is XAF4-1J on the plans. I've googled for this but can't find anything. I tried the Stegbar website, who do a lot of window things but can't find anything that comes close to the approximate dimensions. Closest fixed window I can find is 600x1210 but I know it's longer than 1.2m.. more like 1.8 but I'm not certain.. Failing that, does anyone know the window supplier Clarendon NSW uses? I'm in qld, they use dowell for windows. Mine were coded: QS1824X which means sliding 1800 high by 2400 width. Or QA which is for awning windows. Failing that, just stick your codes in google and see if it brings anything up! the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 6884 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 8018 |
