Browse Forums Building A New House 1 May 23, 2011 7:30 pm Our base stage is complete. The stage we are in is frame stage, frame is almost complete, just the roof to go. What generally happens next? Roof tiles, plastic (technical name??), window frames, gutters ... Then I assume brick work and infills. Whats next - I assume insulation, plaster, internal doors, joinery and fitout ... just trying to work out what order it generally goes in. - BJ - ' Less is more and none is perfect ' My thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=41828 Re: Stages to building a new house 2May 23, 2011 9:55 pm This link is a Construction Supervisors check list, it should give you a good idea. http://www.masterbuilders.asn.au/zone_f ... _10_08.pdf The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Yes well there solution is to blame everyone else while I a 65yr old woman with major medical problems have to just continue to boil water and wash myself in a bucket… 2 16049 If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20281 13 6692 |
