Browse Forums Building A New House 1 May 22, 2011 11:58 pm We are building a new house and the side yard seems to be filling up with water and getting waterlogged. This will lead to foundation issues at some stage. Ours is a very flat site but there is a gradual elevation on the street (our house being on the lower end) and the two houses on either side of ours are at much higher elevation they seems to have factored this into their build. Should my builder have considered this while determining the height of my slab. Is there a legal requirement for draining water away from the slab? My SS tells me I will need to get some one to install a drain at a late stage at my cost. None of the other houses on the street seem to have this issue. I strongly believe it to be the builders mistake and I should not have to bear this cost for their mistake. Please help!!Having sleepless nights and a stressful time. Anybody? how do I go about dealing with this issue. Tarneit : The Reserve Re: Side yard is Water-logged 2May 23, 2011 7:57 am I think this is a fairly common issue, where builders determine the final levels while the owners still don't understand it. The owner then ends up with a low sitting house, when it shouldn't have been done like that. I doubt there are regulations about this that regulate the planning stage - it all seems to concentrate highlighting the owner's responsibility after the (damage) work is done How much lower your house is? Is the area in question sloping to the back? Or is it easy to make it slope? Any pics? My signature is distracting people from my wise posts ... Re: Side yard is Water-logged 4Jun 21, 2011 5:35 am Some builders seem to include drainage. Mine (the big M) did. However from the photo the site doesn't look too bad. Things always look worse during construction. At the moment the roof is draining onto this area. When the outside plumbing is finished all this water will be taken away. Things will probably improve once you start the gardening and improve the soil. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Side yard is Water-logged 5Jun 21, 2011 7:37 am I agree with the above. The main question to you is: Is it possible to make the future drains to slope (to an existing or future outlet/point)? My signature is distracting people from my wise posts ... Re: Side yard is Water-logged 6Jun 21, 2011 7:46 am I have this problem too and I've moved in already! The builder has filled my site to slope towards my house so when I get concrete installed it will have to slope away from the house and I will possibly have to get the landscapers to remove some soil/dirt... Re: Side yard is Water-logged 8Jun 21, 2011 7:55 am Lex Can you install a drainage pipe that can be sloped to "somewhere safe"?? I'm not sure but I'm trying to keep costs down.. I haven't figured it all out yet! I will probably be tackling the issue later this year ... Re: Side yard is Water-logged 9Jun 21, 2011 10:45 am I am worried about this problem too. Our plans have us reducing our side and rear down by 20-30cm I can only assume excess of both of these neighbours will run onto our block. We are planning on laying ag pipe drainage when we do our landscaping. Re: Side yard is Water-logged 10Jun 21, 2011 2:03 pm I also built with Big M and they didn't care one bit about drainage. They even left dirt up to the weep holes so stormwater would flow directly into the walls! They just said "Uh, usually the landscaper handles drainage" So where did the water go during the build if the landscaper handles drainage AFTER the build? I would check your contract and see if it states the builder needs to handle drainage during construction. My contract said that they have to, even though they totally ignored it. I took photos of the builder's "drainage" so we have evidence in case there are problems later on. After we moved in we fixed it ASAP, which involved a lot of digging and breaking through excess concrete that was hidden underground. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4658 can someone with more experience give me their insight? land is pretty much flat its pretty much at the top of a hill. left and right neighbours are flat in line with my… 0 7453 2 4370 |
