Browse Forums Building A New House 1 May 18, 2011 7:34 am Noticed some wet bricks which are not drying out despite the dryer weather. It's around both a gutter down and a stink pipe (DWV) which vents into the roof through the wall. You can see the bricks are wet down at the base and the mortar around where the stink pipe runs is darker than the rest of the wall. I don't know if it's water coming in through the roof around the pipe, or water from under the house coming up, rising damp due to a problem with damp proof coursing around the pipe, or just water that came in through the unfinished brickwork and collected there, though that hasn't happened elsewhere in the house. It doesn't seem to smell but does have a reddish pigment, though that may be seeping colour from the bricks Any idea what would cause it? Is it something likely to be resolved on finishing the wall & capping the stink pipe? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Matt's Brando: viewtopic.php?f=31&t=46340 Started March 30th 2011 PCI July 15th Re: Wet bricks around gutter and stink pipe 2May 18, 2011 2:13 pm That looks pretty unusual. Can you see the reverse side clearly and there's no water source there? My guess would be water comes down from the unfinished downpipe, wets the top bricks (which look a bit damp), but also gets behind the wall and pools at the bottom underneath the weep hole, behind the bricks. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: Wet bricks around gutter and stink pipe 5May 18, 2011 8:09 pm B STAR this is a case of water falling on the ground then splatting onto the lower bricks. More likely to occur if there is a puddle already. If this is the case essentially all I need to do is prop something against the brickwork there to protect it from the water splash and it should go away, yeah? I'll try it and see. Quote: Can you see the reverse side clearly and there's no water source there? All I can see on the reverse side is the wrap. Quote: My guess would be water comes down from the unfinished downpipe, wets the top bricks (which look a bit damp), but also gets behind the wall and pools at the bottom underneath the weep hole, behind the bricks. Even if it pools at the bottom, should the damp proof course prevent this rising? Matt's Brando: viewtopic.php?f=31&t=46340 Started March 30th 2011 PCI July 15th Re: Wet bricks around gutter and stink pipe 6May 19, 2011 9:12 am I'm not assuming that the house has been built correctly here - if you can't see behind the bricks, who knows what's going on there? If it is water splashing up then you can put something there to block it I would think. And ask the SS to make sure it doesn't get moved. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: Wet bricks around gutter and stink pipe 7May 20, 2011 6:45 pm So it seems when the stink pipe was put up through the roof the tiles weren't replaced & sealed around it for a few days and when the rain came through a lot of water ran down along the pipe, picked up a stain from the wood on the frame, pooled and then came out through the weep hole, leaving the stain you can see. The roof is now fixed up so hopefully this won't be a problem when the storm hits on Sunday. The brickie thinks the stain will come off during the clean. Fingers crossed. Matt's Brando: viewtopic.php?f=31&t=46340 Started March 30th 2011 PCI July 15th DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 8988 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4938 Thank you so much. We ended going with the terrain that’s part of our brick. 2 2543 |
